ozark23 Samba Member
Posted: Wed Jun 02, 2021 12:54 pm Post subject: I hate drum brakes. |
65 split bus.
stock drum brakes with dual master
bled correctly, stars are all adjusted (recently)
was pulling badly to the right/passenger when i hit the brakes
and now today...pulling even harder to the Drivers side/Left
NOTHING has changed since two days ago when last driven?
possible the Master is going bad? I am perplexed.
Thanks for the Help! |
turkis-deluxe Samba Security
Posted: Wed Jun 02, 2021 12:59 pm Post subject: Re: I hate drum brakes. |
When did you change your flex lines last? Pulling is either brakes out of adjustment or a bad line. Check that and should be an easy fix. Good luck! |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
74 Thing Samba Member
Posted: Wed Jun 02, 2021 2:06 pm Post subject: Re: I hate drum brakes. |
Did you pull back the boots on the wheel cylinders to make sure it was not leaking or pitted or corroded?
That was my problem-one of my brake cylinders was corroded with a bunch of build up under the boot. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Wed Jun 02, 2021 4:45 pm Post subject: Re: I hate drum brakes. |
Wheel cylinder that leaks just a bit, makes that set of brake pads more grabby. Like one does when wetting finger tips when counting money.
Wheel cylinder that leaks more, lubricates up the brake shoes in that drum, making the bus veer to the other side. _________________ In Stereo, Where Available! |
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Wed Jun 02, 2021 5:32 pm Post subject: Re: I hate drum brakes. |
Eric&Barb wrote: |
Wheel cylinder that leaks more, lubricates up the brake shoes in that drum, making the bus veer to the other side. |
exactly what I was thinking. I bet the right is getting wet. _________________ .
Wanted:
MrVWGuy Samba Member
Joined: February 21, 2010 Posts: 643 Location: North of Pittsburgh PA
Posted: Thu Jun 03, 2021 4:51 am Post subject: Re: I hate drum brakes. |
I had this exact problem. Solved it with a disc brake kit from Wagenswest:
_________________ '63 Bus (camper of unknown origin)
'62 Beetle
'68 Kombi
'76 Westfalia camper, the wife's |
6sixTinBox Samba Member
Joined: September 30, 2007 Posts: 539 Location: Confinement
Posted: Thu Jun 03, 2021 6:08 am Post subject: Re: I hate drum brakes. |
turkis-deluxe wrote: |
I concur that the adjuster screw probably needs to be adjusted. If it's in your budget, I recommend disc brakes. Check out the Empi ones, my friend has them on his 67 split and loves them. I have Porsche 944 disc brakes. Obviously they brake night and day. Good luck! _________________ 1966 13 Window Deluxe
It is what it is |
Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3343 Location: Talos IV, Piedmont Arizona
Posted: Thu Jun 03, 2021 6:24 am Post subject: Re: I hate drum brakes. |
Also went disc. Easy peasy. _________________ LEARN TO SELF RESCUE
.....................All Current....................... |
PEPPE Samba Member
Joined: August 24, 2003 Posts: 1068 Location: Roma Italy
Posted: Thu Jun 03, 2021 6:46 am Post subject: Re: I hate drum brakes. |
check the exact inner diameter of the drums. often differences left to right or too much machining or non bed-in brake shoes cause uneven braking. |
NUTSFORBUSES Samba Member
Joined: December 08, 2016 Posts: 560 Location: I don't recognize it anymore
Posted: Thu Jun 03, 2021 7:15 am Post subject: Re: I hate drum brakes. |
Front and Rear disc's
Stops like a Yugo about to hit a Pinto in front of an orphanage. |
mykillcykill Samba Member
Joined: March 06, 2012 Posts: 50 Location: LOs Angeles
Posted: Thu Jun 03, 2021 7:52 am Post subject: Re: I hate drum brakes. |
All good advice and variables have been covered and I would advocate discs as well. I did the CSP kit almost 15 years ago spending more on the kit than I spent for my SC. Best money ever spent. If you do insist on staying with drums, know that any small amount of contamination on the shoes will cause grabbiness and this will be magnified if you have any slop in any of the steering components. |
Manfred58sc Samba Member
Posted: Thu Jun 03, 2021 11:04 am Post subject: Re: I hate drum brakes. |
Having real German drums with ATE components makes a real difference, hard to come by these days, but worth the effort. My 58 stops great with everything sorted out.
That disc set up looks mighty sweet. _________________ Fat chick owner/operator |
Posted: Thu Jun 03, 2021 4:41 pm Post subject: Re: I hate drum brakes. |
PEPPE wrote: |
Problem with that is it is not going to change sides suddenly without anything changed by the mechanic/owner. _________________ In Stereo, Where Available! |
PEPPE Samba Member
Posted: Thu Jun 03, 2021 11:16 pm Post subject: Re: I hate drum brakes. |
Eric&Barb wrote: |
Problem with that is it is not going to change sides suddenly without anything changed by the mechanic/owner. |
Yes, probably in the meantime there have been also a leak |
MrWhoopee Samba Member
Joined: October 24, 2005 Posts: 177 Location: Shingletown, CA
Posted: Fri Jun 04, 2021 9:16 am Post subject: Re: I hate drum brakes. |
I'm another one who went discs on my '63, over 20 years ago. I went with the Wolfgang Int'l setup, largely because it was the only bolt-on replacement available that retained wide-fives. The only mod was to the calipers, which had to be ground to clear the rims. Even with no assist and after 20k miles, the difference is still shocking.
After chasing problems like you describe and numerous close calls on the road, it was well worth the money spent. _________________ Craig ('51 WASP)
Rosie ('63 Double Cab) |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Sat Jun 05, 2021 11:38 am Post subject: Re: I hate drum brakes. |
Well, I like drums just fine.
AS FAR AS ONE CAN EXPECT.
I live in the US MIDWEST.
Certainly with a bigger engine, or lots of mountain stopping.
I have a 1970 Westy project. I don't think it will ever get discs. UNLESS in a future life I drive it in mountains a lot.
Neither in my 56 single cab that will not even go 55mph.
Careful replacement of parts and especially brake hoses and hydraulics should make the drums work fine. The same failures will make disc brakes work poorly as well. _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
