Ossipon Samba Member
Posted: Wed Jun 02, 2021 3:26 pm Post subject: Stupid Question Time: Did some 1500S models not have a K engine? |
I just realized my 1964 Notch1500S does not have a K engine. It has a 1500/1500A engine. I know origin details (Purchased in Spain, 1964) and know the history of PO and OO. (I am the third owner)
It has all the other bits of being an S with Dual Solex and License tag cover saying 1500S. But the engine number is 10178058. That would make the engine being built in 1963 by my guess. The front plate number would have it built in March 1964 (0414261).
Am I missing something obvious? Or when I tear into the engine, should I just plan on it being a 1500? _________________ Ossipon
VWs in my life:
Air
Type 1 - 59, 62, 63, 71 Super 68 KGhia/ Type 2 - 59 Single Cab / Type 3 - 64 Notch
Water
GTI 83, Jetta 81, 85, 87, 91 TDI, 98 TDI, 09 / New Beetle 99 / SportWagen 05, 13 / Tiguan 18 / T3 92 |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13271 Location: Tejas!
Posted: Wed Jun 02, 2021 3:47 pm Post subject: Re: Stupid Question Time: Did some 1500S models not have a K engine? |
Engine #10178058 is June of 1965, not sure where you got 63 from or why you thought a 64 should have a "K motor"
https://www.thesamba.com/vw/archives/info/serialnumberst3.php
it's very common for these cars to have replacement motors and non original parts inside the case. It is much rarer and special when they have their original engine |
Posted: Wed Jun 02, 2021 4:33 pm Post subject: Re: Stupid Question Time: Did some 1500S models not have a K engine? |
Erik G wrote: |
Thanks
Like I said, stupid question on my part. I was using a Haynes reference and not Samba.
Attached is the picture I took after taking possession of it.
VWs in my life:
Air
Water
Slow 1200 Samba Member
Posted: Thu Jun 03, 2021 6:26 am Post subject: Re: Stupid Question Time: Did some 1500S models not have a K engine? |
is that a 1 or a T? |
260KMN Samba Member
Joined: January 17, 2014 Posts: 236 Location: Devon UK
Posted: Thu Jun 03, 2021 6:32 am Post subject: Re: Stupid Question Time: Did some 1500S models not have a K engine? |
Looks like it could be a T and to the left of the T is what could be the vw recon roundel. Give it a wipe and re photo so we can see better. |
Erik G Samba Member
Posted: Thu Jun 03, 2021 9:40 am Post subject: Re: Stupid Question Time: Did some 1500S models not have a K engine? |
Agreed, that looks to be a T0 case |
Posted: Thu Jun 03, 2021 11:06 am Post subject: Re: Stupid Question Time: Did some 1500S models not have a K engine? |
260KMN wrote: |
Thanks all for making me look at the OO documentation. I have many but not all the OO docs. Unfortunately, receipts past 67 are gone.
Indeed it is a reconditioned engine. And it is even documented. Two images. Insurance receipt from 1964 with original motor #. Then a Service chit from the service manual for June 1967 with the comment "Engine Repl." Unfortunately, I have no further detail.
Thanks all
VWs in my life:
Air
Water
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22413 Location: Kimball, Mi
Posted: Fri Jun 04, 2021 1:39 pm Post subject: Re: Stupid Question Time: Did some 1500S models not have a K engine? |
Ossipon wrote: |
260KMN wrote: |
Thanks all
The way Russ Wolfe explained it to me was the engine was pulled, the ancillary items (gen, cooling tin, distributor, etc)would be removed, then placed into a crate for shipping back to VW in Germany. A recycled engine would have been removed from that very same crate, and built up getting the old engine number complete with "recycle" stamp. Keep in mind VW would do a very complete (almost total) remanufacture of the engine. Both case halves would be re-machined to be like new, and the same was applied to ALL bearing surfaces (cam and crank), along with re-machining the oil pump opening. All other surfaced were refreshed, and then the engine could be rebuilt. They even got case savers installed. When done, it was basically a brand new long block, as the heads were redone as well. Those engines received an expensive overhaul, but done under factory warranty.Then all of the removed items were re-installed and run was done before returning the car to the owner.
I only mention this, because my old 70 Square had a recycled engine put into it back when it was in Texas. It had it's engine replaced due to having dealer installed AC, which caused it to die a horrible death before I got it. I had asked the type 3 forum about it and Russ explained it to me, and how it all worked, as he was a factory trained dealer mechanic back when these cars were new. He was the FI guy, along with doing AC installs after work at his dealership for extra money.
I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
janerick3 Samba Member
Posted: Fri Jun 04, 2021 11:00 pm Post subject: Re: Stupid Question Time: Did some 1500S models not have a K engine? |
VW engine numbers did not gain the letter prefix until the start of the 1966 model year.
Sometime during the 1965 model year, cases started getting stamped with the engine type letter, together with the VW logo, near the engine number, but not immediately in front of it.
For what it's worth:
K = 1500N
R = 1500S
T = 1600
U = 1600 FI
The 1500S required premium fuel, as indicated under the hood. Otherwise, you risked burning a hole through one of the domed pistons. The 1600 ran on regular octane gas. _________________ Thanks,
Jan K. |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Thu Jun 10, 2021 12:09 am Post subject: Re: Stupid Question Time: Did some 1500S models not have a K engine? |
Your engine looks to be an early August 1965 1600, one of the first ones.
Don't despair that it's not the "original" as it looks to be a dealer documented replacement. These things happened more than people realize. If the original owner was a confirmed Pennzoil or Quaker Sludge oil guy... that crap killed VW engines FAST!
I have a September 1965 912 here with an engine with NO engine number, and the Certificate of Authenticity from Porsche stating that the engine number for this car is "not known". We think that the original engine possibly developed an issue just as it was leaving the factory, and someone grabbed this "no number" engine off the line and stuck it in.
Sometimes weird things happened, both before and at the dealer. It's all part of the history. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
