Danny604 Samba Member
Joined: October 09, 2019 Posts: 89 Location: Port Coquitlam BC Canada
Posted: Fri Jun 04, 2021 10:18 pm Post subject: Cylinder head temp idiot light |
Reading the Bill Fisher, How to hotrod your VW book. They mention using a Corvair head temp sensor/switch that turns on an idiot light when they are getting too hot. I searched for the sensor online but only came up with NOS ebay parts and out of stock items. Is anyone doing this anymore? modern solution for an idiot light?
Thanks |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Fri Jun 04, 2021 10:21 pm Post subject: Re: Cylinder head temp idiot light |
Those little sensors you put on the head and wired to the idiot light have long ago been discontinued. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Wreck Samba Member
Posted: Fri Jun 04, 2021 11:13 pm Post subject: Re: Cylinder head temp idiot light |
Not a cheap option but a good one . MGL TC-1 gauge has an adjustable alarm for over temp . It can be configured for different thermocouples from memory .
photo for reference , I've set mine at 180C (well under max allowable)
dubman67 Samba Member
Joined: April 10, 2003 Posts: 273 Location: Big Sky Country
Posted: Sat Jun 05, 2021 7:42 am Post subject: Re: Cylinder head temp idiot light |
I was planning to have a boss welded to the head and thread it into that. Thanks for the link. I agree with not wanting to have a gauge, I feel the same way. |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Sat Jun 05, 2021 12:50 pm Post subject: Re: Cylinder head temp idiot light |
I still have one, somewhere, I used it on my bus engine, never see ed to work like it should have, never really warned me of anything the other gauges didn't. Even a GB227 would be better, in my opinion. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9960 Location: Huntington Beach, CA
Posted: Sat Jun 05, 2021 2:03 pm Post subject: Re: Cylinder head temp idiot light |
I run a dipstick sensor and a head temp gauge.
Dipstick sensor is a brilliant idea. You can check it out here.
https://www.busdepot.com/gb228 _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Sat Jun 05, 2021 10:32 pm Post subject: Re: Cylinder head temp idiot light |
It should not be too hard to make "something" that works like this reliably.
A few ways to do it. Something like these just for an example of what to look for.
https://www.wika.us/tfs135_en_co.WIKA
Hundreds of sizes, configurations and temperatures. Its just a bi metallic switch tjat is normally open. When it hits temp it closes and turns on your warning light.
Ray |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2769 Location: The World's Motor Capital
Posted: Sun Jun 06, 2021 4:58 am Post subject: Re: Cylinder head temp idiot light |
Westach publishes the MV output for their Type J thermocouples (with the cold junction at 75º F).
A creative electronics wiz could assemble a circuit to trigger a relay for a dashboard warning light at a given MV output from the thermocouple. |
Posted: Sun Jun 06, 2021 7:45 am Post subject: Re: Cylinder head temp idiot light |
mondshine wrote: |
Yes....but....without cold leg temperature compensation.....the temperature that TC causes the alarm or warning light to go off at..... will vary widely.
Just stating the above fact for the record ......because you are right.... a thermocouple is a good and cheap idea.
The reason I did not suggest using a thermocouple.....is because I figured those looking at this thread wanted one that was dirt simple.....like single wire simple?
If one has enough electronics know how to design a logic circuit to trigger a relay or open a circuit for an LED or light bulb.....when the TC is sending the exact current level that corresponds to whatever temperature you consider too high.......you can easily build the small circuit I found the plans for on line last year for a compensation circuit for almost any TC so any gauge can be temperature compensated.
If you can solder.....its about $20 in parts or I think the guy is selling kits.
But......if you can do all of that.....you are basically building a gauge.
Ray |
Posted: Sun Jun 06, 2021 7:54 am Post subject: Re: Cylinder head temp idiot light |
raygreenwood wrote: |
Ray |
Yep; that's why I use a gauge.
I assumed that the OP did not want to clutter (or hack) his IP with non-stock
instruments. |
