How many amp hours of aux battery to charge a phone?
8 amp hours
0%
 0%  [ 0 ]
6 amp hours
0%
 0%  [ 0 ]
4 amp hours
0%
 0%  [ 0 ]
2 amp hours
20%
 20%  [ 1 ]
1 amp hours
80%
 80%  [ 4 ]
Total Votes : 5
crazyvwvanman
crazyvwvanman is offline
PostPosted: Sat Jun 05, 2021 2:59 pm    Post subject: How many amp hours of aux battery to charge a phone? Reply with quote
If my iPhone 11 battery runs very low, how many amp hours of my aux battery capacity are needed to full charge it?
kourt
kourt is offline
PostPosted: Sat Jun 05, 2021 4:07 pm    Post subject: Re: How many amp hours of aux battery to charge a phone? Reply with quote
Too many variables. What amperage is your USB charging port? Or the charger itself? Are you disabling wifi and cellular while charging?
This question is useless without details.
kourt
SSWesty
SSWesty is offline
PostPosted: Sat Jun 05, 2021 4:21 pm    Post subject: Re: How many amp hours of aux battery to charge a phone? Reply with quote
I think you're in the 2 amp hour range +/-1
DanHoug
DanHoug is offline
PostPosted: Sat Jun 05, 2021 4:31 pm    Post subject: Re: How many amp hours of aux battery to charge a phone? Reply with quote
iPhone 11 batteries are ~3100mAH. so... figure a charge conversion efficiency of a conservative 60% therefore:
XmAH x .60 = 3100mAH
XmAH = 5100mAH or 5.1AH
that's for a fully discharged phone batt, which few let get that low but this is all armageddon scenario figuring a dead batt and poor charge efficiency.
-dan
'87 Westy, ratty but drive anywhere.
'89 Westy, gorgeous but hasn't been gone thru to drive anywhere.
crazyvwvanman
PostPosted: Sat Jun 05, 2021 5:01 pm    Post subject: Re: How many amp hours of aux battery to charge a phone? Reply with quote
I didn't ask how long it would take, just how much energy would be needed from the aux battery. The phone battery only holds a certain amount of energy and that is roughly how much must come from the aux battery. I realize there losses and some small variables.
Mark
kourt
crazyvwvanman
PostPosted: Sat Jun 05, 2021 6:43 pm    Post subject: Re: How many amp hours of aux battery to charge a phone? Reply with quote
You missed a key aspect which is the relative voltages of the 2 batteries in question. That puts your 5.1ah number way off, too high.
I'd say your efficiency assumptions are off too, but don't know that for certain.
Mark
kamzcab86
kamzcab86 is offline
PostPosted: Sat Jun 05, 2021 6:49 pm    Post subject: Re: How many amp hours of aux battery to charge a phone? Reply with quote
I don't have an iPhone, but I do have a USB amp meter in my van. I think my Android is something like 1.3 amps... I'll double-check when I get home next week.
~Kamz Anxious
2016 Golf GTI S
"I fear the day that technology will surpass our human interaction; the world will have a generation of idiots." ~Albert Einstein
Sodo
Sodo is offline
PostPosted: Sat Jun 05, 2021 7:58 pm    Post subject: Re: How many amp hours of aux battery to charge a phone? Reply with quote
For $13 you can read how many mAh passed thru this device.
a "USB Meter" on Amazon
The USB outlet adds some losses but it's probably not much different than the power that departed your aux battery.
'07 EJ25 with '12 longblock, (Peloquin TDB on the shelf), locker, transaxle oil cooler/filtration system. LiFePO
....KTMs, GasGas, and a Stumpjumper
Abscate Premium Member
Abscate is offline
PostPosted: Sun Jun 06, 2021 4:49 am    Post subject: Re: How many amp hours of aux battery to charge a phone? Reply with quote
It took more energy to makes these posts than the energy in a phone.
Laughing
Just looking at my battery meter, it charged from 2100-2300 to full cap last night ona 1 amp brick at 5 volts, thatís 10 watt hours
So fir your 12 volt battery, thatís less than 1 amp hour
Itís marginally on par with the self discharge rate of a flooded lead scid battery!
.ssS!
DanHoug
DanHoug is offline
PostPosted: Sun Jun 06, 2021 6:51 am    Post subject: Re: How many amp hours of aux battery to charge a phone? Reply with quote
Mark
ack!! you're right!! need to equivalent everything to watt-hours, which accounts for the voltage diff. oops!
-dan
jimf909 Premium Member
jimf909 is offline
PostPosted: Sun Jun 06, 2021 7:09 am    Post subject: Re: How many amp hours of aux battery to charge a phone? Reply with quote
Mark
As best as I can tell, iPhone 11 batteries are 3.7 volts and 3100 mAH so charging one from zero will consume 11.5 watt hours or .9 amps from your aux battery assuming it's @ 12.7 volts.
Abscate wrote:
Current: 1990 Westy Camper - Bostig RG4, 2wd, manual trans w/Peloquin, NAHT high-top, Flash Silver, seam rust, bondo, etc., etc.
crazyvwvanman
PostPosted: Sun Jun 06, 2021 3:03 pm    Post subject: Re: How many amp hours of aux battery to charge a phone? Reply with quote
I think you meant to say .9 amphours so I'll agree, plus a little more for efficiency losses.
What meager info I have found for car charger efficiency indicates a 5% to 10% loss, far less than many home wall chargers waste.
Mark
DanHoug
DanHoug is offline
PostPosted: Sun Jun 06, 2021 4:30 pm    Post subject: Re: How many amp hours of aux battery to charge a phone? Reply with quote
so, Mark.... what's the application for determining the rilly small demand? curiousity? running an array on the edge? off grid budget balance? inquiring minds and all that.
-dan
