ronnyhotrod Samba Member
Joined: August 03, 2020 Posts: 7 Location: Bakersfield Ca
Posted: Sat Jun 05, 2021 9:34 pm Post subject: VW engine chirps when when it runs |
VW engine chirps when it was running I shut it down what was making this noise should I just pull it apart is it dead hurt or fixable Thanks for any help |
Danwvw Samba Member
Posted: Sat Jun 05, 2021 9:40 pm Post subject: Re: VW engine chirps when when it runs |
The tips on a stock muffler chirp!
Some Dual Carbs chirp. They are normal. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Sat Jun 05, 2021 11:52 pm Post subject: Re: VW engine chirps when when it runs |
There are numerous reasons why your engine will make a chirping noise. Absent more information about exactly where the chirping is coming from, maybe even a decent quality video to demonstrate the issue, it's impossible to say one way or the other whether it's something to be concerned about or not. _________________ 1960 Ragtop w/Semaphores "Inga" |
oprn Samba Member
Joined: November 13, 2016 Posts: 12714 Location: Western Canada
Posted: Sun Jun 06, 2021 6:36 am Post subject: Re: VW engine chirps when when it runs |
I had one like that, the fan was not spaced right and rubbed on the fan shroud. Also check the clearance between the engine pulley and the tins around it. It's not very likely to be an internal issue. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Sun Jun 06, 2021 8:48 am Post subject: Re: VW engine chirps when when it runs |
The engine was running at idle then chirping started got louder and closer together engine started to run slower then quit. I have pulled engine out of the dune buggy and I can move engine with a pinch bar at the flywheel end a small amout at a time its not froze up but a bit tight. I'm going to pull it apart to inspect it inside hope it not to hurt wish me luck one locale person side it pinched a bearing |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22648 Location: NYC/Upstate/ROW
Posted: Sun Jun 06, 2021 11:46 am Post subject: Re: VW engine chirps when when it runs |
It is a quality control problem in the lubrication of camshaft under stem thrust surfaces afflicting the 1949 proptype enigne, the 1966 1300 cc, the subsequently the 1983, 2000, and 2017 water cooled engines.
It’s been bugging Vw engineers like a plague. _________________ .ssS! |
gt1953 Samba Member
Posted: Sun Jun 06, 2021 7:06 pm Post subject: Re: VW engine chirps when when it runs |
Vacuum leaks do have a chirp sound as well. Like right below the carb. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Zundfolge1432 Samba Member
Posted: Sun Jun 06, 2021 7:19 pm Post subject: Re: VW engine chirps when when it runs |
Go do this
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Sun Jun 06, 2021 7:29 pm Post subject: Re: VW engine chirps when when it runs |
if it has a stock style muffler, remove the exhaust tips. if it goes away, your fine. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Posted: Mon Jun 07, 2021 4:00 am Post subject: Re: VW engine chirps when when it runs |
Zundfolge1432 wrote: |
Go do this
How will 3 gallons of gas help?
oprn Samba Member
Posted: Mon Jun 07, 2021 4:56 am Post subject: Re: VW engine chirps when when it runs |
ronnyhotrod wrote: |
That is a completely different story from your first one!
Good luck with the tear down and tell us what you find. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
