NAES Samba Member
Joined: September 10, 2003 Posts: 2121 Location: AREA-52 Southern Killafornia
Posted: Sun Jun 06, 2021 3:44 pm Post subject: Unable to close Long spoon popout latch. |
As the title says, the long spoon popout latches fold onto themselves and jam up.
This is on a 61 Kombi with 6 the popout option. Happens with "real" and repop latches and I am using the spacer on the rear window.
I've never had this happen before and I'm sure I'm doing something really obvious once you point it out to me.
Thanks all for any help you can offer.
NAES _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
John Ghia Samba Member
Posted: Sun Jun 06, 2021 4:25 pm Post subject: Re: unable to close Long spoon popout latch. |
Try adjusting the latch screws/bolts where they attach to the frame. _________________ BUS BOYZ |
NAES Samba Member
Posted: Mon Jun 07, 2021 10:35 pm Post subject: Re: Unable to close Long spoon popout latch. |
Yeah I tried moving everything around. I'll mess around with them again and take a few pics so you can see what I'm dealing with. _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
jonny1309 Samba Member
Posted: Tue Jun 08, 2021 10:10 am Post subject: Re: Unable to close Long spoon popout latch. |
How are your seals? I think there needs to be a small gap between the two arms of the latch which would allow it to begin close. Once it cams over and latches, the gap closes. If the arms are fully mated too early, I think they bind. The seals keeps the gap open. _________________ Jonny
Barndoor Mafia wrote: |
Add a cop mustache, some cholo shades and a Doyers cap to the guy in the suit .......... Tocayo. |
scottvw wrote: |
kiss my ass Tom....I'm without centercaps right now. |
OgCalLook wrote: |
nothin' wrong with: Nose down - Ass up!! |
Ragman wrote: |
Did you tell her that Al Reed painted them? |
lonslo wrote: |
My tailbone still hurts like hell. |
patjones Samba Member
Posted: Sun Feb 06, 2022 12:40 pm Post subject: Re: Unable to close Long spoon popout latch. |
Did you ever get these to work/ close? I'm having the same issue. Ive got spacers and it doesn't seem to help. The arm inside never gets far enough over into the latch for it to close. The "elbow" doesn't get behind the part that it levers against and binds way before it gets close.
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Mon Feb 07, 2022 8:50 am Post subject: Re: Unable to close Long spoon popout latch. |
Take the entire latch off and do a "test" open and close. Watch carefully how the front and rear pivots interact- the "wrist" cannot pivot on the same plane as the "shoulder" and still fold flat. Press both mounting plates of the latch against a flat surface to watch what happens. All you get is a fold at the elbow as shown. Now lift the rear latch plate 2mm above the flat surface and re-work the latch. Now it folds flat.
That's why the rear spacer is necessary. It staggers the rear pivot from the front one- allowing it to overlap. _________________
EverettB wrote: |
FU#5 |
Navydave73 Samba Member
Joined: March 09, 2017 Posts: 414 Location: Alta Loma/Los Angeles
Posted: Mon Feb 07, 2022 4:20 pm Post subject: Re: Unable to close Long spoon popout latch. |
patjones wrote: |
I know what you are talking about, the trick is nice fresh sponges rubber to force a cam over spring type function. This pic looks like the latch base is way too far back. Add the spacer and slide them as far forward as they will go. You may have to loosen the two screws on the pop out frame that hold the latch also. The screw plate on the rear window has slots in the wi Dow frame sheet metal that allow you to slide it towards the front or rear of the bus. You may have to poke a different hole in the headliner if it’s that far off.
Definitely take the latch off and operate it in your hand to see where the rounded edge guide has to lock in with the hinge pin carrier as it closes. Another Germanly simple completely complex device. Awesome |
Posted: Mon Feb 07, 2022 4:22 pm Post subject: Re: Unable to close Long spoon popout latch. |
patjones wrote: |
I just realized you are missing the rubber that slips on the window lip around the perimeter of the window. Without that, here is nothing to force the latch to “spring” or cam over. |
Posted: Tue Feb 08, 2022 8:15 pm Post subject: Re: Unable to close Long spoon popout latch. |
Rubber installed, spacer installed. Its def closer but the little grooved lever part wont go in far enough to let it latch. You can see it tweak the window frame as it tries to close the gap but I really dont want to force it.
The opposite window was also tight but not as bad, the glass already had a small crack and when I closed it all the way the glass cracked a lot more.
The mounting holes and hinges are original but the popout and the frame are repro. Perhaps they are a bit off....
Posted: Tue Feb 08, 2022 11:05 pm Post subject: Re: Unable to close Long spoon popout latch. |
patjones wrote: |
If you loosen the three screws, there should be a half inch or so of adjustment. Looks like you need to slide the base of the latch as far towards the window as you can, then re tighten. |
