VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Tue Jun 08, 2021 3:03 pm Post subject: Tunnel Conduit Measurements |
I just wanted to post these notes I took, before I throw away the information. Hoping it may help someone else out in the future. I purchased all of the tubing through McMaster Carr.
https://www.mcmaster.com/metric-stainless-steel-tubing/
On my 54 Standard Bug the cable conduit tubing is as follows.
Clutch cable conduit.
- Outside diameter 12mm
- Inside diameter is 10mm
- 1mm thick wall
- 1696mm length
Accelerator cable conduit.
- Outside diameter 8mm
- Inside diameter is 6mm
- 1mm thick wall
- 1728mm length
Left side heater cable conduit.
- 1mm thick wall
- 1320mm length
Right side heater cable conduit.
- 1mm thick wall
- 1320mm length
Emergency cable conduit to the front. Both left and right same.
- 1mm thick wall
- 2337mm length
Emergency cable conduit to the rear. Both left and right same.
- 1mm thick wall
- 2345mm length
Choke cable conduit
- Outside diameter 10mm
- Inside diameter is 8mm
- 1mm thick wall
- 2029mm length
Let me know if you know something I measured wrong, but pretty certain I got it!
Hope it helps someone! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Dan22 Samba Member
Joined: August 30, 2019 Posts: 470 Location: Battle Ground, WA
Posted: Tue Jun 08, 2021 7:19 pm Post subject: Re: Tunnel Conduit Measurements |
Dan22 wrote: |
Thanks Jimbo! |
You are welcome! _________________ Jimbo
TDCTDI wrote: |
