What gas tank
y2kbaja
y2kbaja is offline
PostPosted: Tue Jun 08, 2021 4:59 pm    Post subject: What gas tank Reply with quote
I just got my buggy and the hole in the hood for the gas tank is centered. The tank I got with the car is on the left (or right) back (or front). I looked up gas tanks on Moore parts and didn't see any with a center cap. What tanks have the center cap? Otherwise more glass work as I move the hole.
edit: not me pictured nor the car in it's current state.
KAmes
KAmes is offline
PostPosted: Tue Jun 08, 2021 5:44 pm    Post subject: Re: What gas tank Reply with quote
I would modify a new (never had gas in it) tank. No need to mess up the fiberglass unless you're doing some of that anyway. None came with a center fill, unless maybe the gauge sender hole has been modified into the fill. New tanks are relatively cheap.
sailtexas186548
sailtexas186548 is offline
PostPosted: Tue Jun 08, 2021 6:14 pm    Post subject: Re: What gas tank Reply with quote
There is a lot out there to turn the fuel sending hole into a filler neck if that lines up right for u
it's more fun loud and dirty
Dale M.
Dale M. is offline
PostPosted: Tue Jun 08, 2021 7:18 pm    Post subject: Re: What gas tank Reply with quote
Modify tank to fit opening in buggy hood or modify buggy hood to fit openings in tank.....
IF paint job and design are sacred, you have to go with first choice....
In my situation I had about three opening in hood where various people over years modded hood a lot, my solution was to remove all the bad crap, decide where I wanted opening for hood and tank, cut neck off new tank set tank in body dropped hood in place and drilled hole (1/8 inch) through hood and tank as a locator and fabbed/moded as necessary...
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
y2kbaja
y2kbaja is offline
PostPosted: Tue Jun 08, 2021 7:39 pm    Post subject: Re: What gas tank Reply with quote
https://www.pacificcustoms.com/mm5/graphics/00000001/ac750218-1_2_350x350.jpg
Something like this? But lose the gas gauge. No biggie I guess. Thanks all
YDBD
YDBD is offline
PostPosted: Tue Jun 08, 2021 8:49 pm    Post subject: Re: What gas tank Reply with quote
This is my gas tank with a center fill and gas gauge is mounted:
'56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing"
jspbtown
jspbtown is offline
PostPosted: Wed Jun 09, 2021 6:45 am    Post subject: Re: What gas tank Reply with quote
Something like this? But lose the gas gauge. No biggie I guess."
If you are gonna modify and weld then why lose the gas gauge?
Get the right tank, cut off the filler neck, install the tank and mark where the filler neck should go, drill a hole for the new neck, and bring it somewhere that can weld the old filler hole and weld in the neck to the new location.
Manxdude
Manxdude is offline
PostPosted: Wed Jun 09, 2021 2:37 pm    Post subject: Re: What gas tank Reply with quote
Acme car company sells already modified center fill gas tanks.
