samm1 Samba Member
Joined: August 20, 2012 Posts: 217 Location: Saskatoon,Sask.
Posted: Wed Jun 09, 2021 9:49 am Post subject: Gasket here? |
Pulled off my alternator stand and there’s no gasket just wondering if there’s supposed to be one here or not it wasn’t leaking.Maybe I could put a slight smear of RTV on here or something.
_________________ Hella ya! |
Maddel Samba Member
samm1 Samba Member
Posted: Wed Jun 09, 2021 10:14 am Post subject: Re: Gasket here? |
Ok, thanks Maddel I’ll see if I can find one 👍🏽 _________________ Hella ya! |
Starbucket Samba Member
Posted: Wed Jun 09, 2021 2:41 pm Post subject: Re: Gasket here? |
cip1.ca |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5994 Location: Brooklyn
Posted: Wed Jun 09, 2021 2:53 pm Post subject: Re: Gasket here? |
And throw away the RTV, it doesn't belong anywhere on that engine! _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Maddel Samba Member
Posted: Wed Jun 09, 2021 9:44 pm Post subject: Re: Gasket here? |
samm1 wrote: |
Ok, thanks Maddel I’ll see if I can find one 👍🏽 |
You're welcome...
When installing the new gasket mind the correct orientation of the louvers.
Like in the pic you posted above.
IIRC original gaskets had "TOP" stamped on them. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9638 Location: Pearl River, NY
Posted: Sat Jun 12, 2021 12:48 pm Post subject: Re: Gasket here? |
Noteworthy is that item #45 is the paper gasket for the generator support. However- the application lists the engines prior to the US 1600 cc dual-port which was rated at 50 PS (DIN spec equiv. for 60 hp SAE). And- for those engines, only a single gasket is needed. So- for the OP's DP engine- the parts list implies (and Maddel states) that the gasket #45 is not needed, only the #46 deflector plate. |
