Frodge Samba Member
Posted: Wed Jun 09, 2021 10:59 am Post subject: 73 shift rod bushing |
How does one get the shift rod out of a 73 super beetle to clean the rust off? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Wed Jun 09, 2021 11:02 am Post subject: Re: 73 shift rod bushing |
It comes out the front. _________________ Glenn
Member #1009
#BlueSquare |
OTTO 1303 Samba Member
Joined: March 17, 2020 Posts: 636 Location: Louisiana
Posted: Wed Jun 09, 2021 2:06 pm Post subject: Re: 73 shift rod bushing |
You can YouTube it, there are plenty for Standard Beetle and a few for Super Beetle, as they are a little different.
SLADE has a pretty good one for the Super.
If you already had planned to replace bushing, GREAT!!
If not, you may want to do so while the rod is out, save some trouble later. _________________ 74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG |
Frodge Samba Member
Posted: Wed Jun 09, 2021 6:01 pm Post subject: Re: 73 shift rod bushing |
I have a standard. My neighbor has a super. Where is the access panel on a super? Pics? |
Glenn Mr. 010
Posted: Wed Jun 09, 2021 7:08 pm Post subject: Re: 73 shift rod bushing |
Look under car behind front apron and you should see a reinforcement plate like this mounted with several bolts
Remove the bolts, and behind the 2 bolts at rear (these holes for reference) is the access hole.
Note, you may have a fan there instead, in either case, the access hole is in same place. _________________ 74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG |
