SlowRhode Samba Member
Joined: July 05, 2018 Posts: 12 Location: Providence, RI
Posted: Wed Jun 09, 2021 1:58 pm Post subject: 1972 002 transmission won’t go into gear but shifter feels fine? |
My 1972 bus recently had the transmission stop working. A friend was borrowing it and got stranded. Shifter (Scat) feels as if it’s going into gears at it should but it doesn’t. I checked all the couplers/linkages and they seem to work fine. I pulled engine/trans today & was hoping I would find something obvious with the nose cone off. But everything looks as it should.
Any recommendations on next steps to take? I’m kind of at a loss as to why it might act this way ???
I searched the forum and couldn’t find a similar problem so I’m stumped (and probably not very good at searching!) |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Wed Jun 09, 2021 2:15 pm Post subject: Re: 1972 002 transmission won’t go into gear but shifter feels fine? |
If it shifts fine with the engine off but not with the engine running a place to look is the pilot bearing _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Wed Jun 09, 2021 3:08 pm Post subject: Re: 1972 002 transmission won’t go into gear but shifter feels fine? |
Excellent. Thank you. It actually seemed to shift just fine either engine running or not, which had me perplexed. I’m going to separate the engine and transmission tomorrow and see what I find. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Wed Jun 09, 2021 3:40 pm Post subject: Re: 1972 002 transmission won’t go into gear but shifter feels fine? |
So you get the “detent” of the shifter going into gear, you release the clutch, and bus doesn’t move? Check the CV joints, their bolts, and the rear axle splines in its hub.
www.airschooled.com |
Posted: Wed Jun 09, 2021 3:48 pm Post subject: Re: 1972 002 transmission won’t go into gear but shifter feels fine? |
airschooled wrote: |
Robbie |
Exactly this. CV joints, bolts etc are all in good order (new Axles less than 500 miles on them). Nothing external spins with engine running, in gear and clutch out. |
cmonSTART Samba Member
Posted: Wed Jun 09, 2021 3:52 pm Post subject: Re: 1972 002 transmission won’t go into gear but shifter feels fine? |
I suppose while then engine is pulled you could rotate one output shaft and see if the other turns the opposite direction while you do. _________________ '78 Bus 2.0FI
de K1IGS |
Posted: Wed Jun 09, 2021 4:18 pm Post subject: Re: 1972 002 transmission won’t go into gear but shifter feels fine? |
Not particularly unusual for a Type 1 flywheel to spin on the crankshaft. I kind of remember someone having this problem on a Type 4 as well. Should be pretty obvious once you separate the engine and tranny. |
Posted: Thu Jun 10, 2021 6:31 am Post subject: Re: 1972 002 transmission won’t go into gear but shifter feels fine? |
Wildthings wrote: |
How would the starter work? _________________ Learn how your vintage VW works. And why it doesn't!
danfromsyr Samba Member
Posted: Thu Jun 10, 2021 8:33 am Post subject: Re: 1972 002 transmission won’t go into gear but shifter feels fine? |
the splined coupler on the trans input shaft can unscrew from the stud if it's not an updated version
sorry I don't know the technical names
but you may find that the input shaft is going to come out on it's own when you pull the engine.
https://www.thesamba.com/vw/forum/viewtopic.php?p=5717907
Abscate wrote: |
Posted: Thu Jun 10, 2021 10:43 am Post subject: Re: 1972 002 transmission won’t go into gear but shifter feels fine? |
**Solved**
Separated the engine and transmission, removed the pressure plate to reveal….
No clutch lining on pressure plate side and barely any on the flywheel side.
New kit on the way. Thanks everyone! |
Posted: Thu Jun 10, 2021 11:35 am Post subject: Re: 1972 002 transmission won’t go into gear but shifter feels fine? |
It could be a lot worse!
Glad you found it. _________________ '78 Bus 2.0FI
de K1IGS |
Oil Phil-M Samba Member
Joined: October 08, 2005 Posts: 541 Location: Vancouver, BC
Posted: Thu Jun 10, 2021 12:35 pm Post subject: Re: 1972 002 transmission won’t go into gear but shifter feels fine? |
Quote: |
A friend was borrowing it |
This is the true root cause of your problem |
Posted: Thu Jun 10, 2021 4:39 pm Post subject: Re: 1972 002 transmission won’t go into gear but shifter feels fine? |
SlowRhode wrote: |
**Solved**
Pictures would be wonderful |
Posted: Thu Jun 10, 2021 5:22 pm Post subject: Re: 1972 002 transmission won’t go into gear but shifter feels fine? |
Check the flywheel for damage. It might need to be machined. Might be a good opportunity to replace the main oil seal too _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Thu Jun 10, 2021 7:44 pm Post subject: Re: 1972 002 transmission won’t go into gear but shifter feels fine? |
Oil Phil-M wrote: |
indeed, friends don't let friends drive their vintage VWs. _________________
Abscate wrote: |
