volkaholic1 Samba Member
Posted: Wed Jun 09, 2021 5:04 pm Post subject: new dual port cylinder tins |
i also have an ad placed, so if you want pricing, go there, the intent of this post is to discuss the cylinder tins and answer any questions you may have
I wanted to get you quick this brand new product I am getting ready to roll out.
I have recreated the VW dual port cylinder tins.
As you know, the dual port tins sold by SCAT and EMPI have many shortcomings.
I think these tins will ge a total game changer - now you don’t have to make due with SCAT/EMPI
parts and you don’t have to spend hours fixing vintage tins.
I have fixed all the issues with the SCAT/EMPI tins by having my people make
very good copies of the VW tins. I told them to not cut any corners.
First of all, I AM NOT DEALING WITH THE CHINESE! Yep, I am working with the Tiwanese
The difference in mentality in incredible, these guy really work hard to make good parts.
In fact, I think my tins might actually be better than VW, let me tell you why.
As you know, the SCAT/EMPI tins have no internal air vane, the mounting holes for
other tins do not line up, the curves are wrongs and two of the flanges are too short.
my tins are better because:
1 my tins have the internal air vane
2 my holes all line up
3 my flanges are in the right places
4 all of the curves are correct
5 thicker metal can hold up to more abuse, stock VW is 0.026" thick, mine is 0.040" thick, and extra 0.016" makes a huge difference
think about it, thicker metal = more difficult to dent, more difficult to crack
6 I give you the option on if you want threaded inserts or not for the carb preheat insulator
7 I give you a choice, you can get my parts in silver primer or powdercoated, stock is considered satin black, but I have 90 + colors
Today I ordered 100 sets of tin, it will take 2 months to get here. I would like you to be the first to see these parts.
You can get just the cylinder tins, or make it part of a complete kit, what ever you need. _________________ Volkaholic |
Zundfolge1432 Samba Member
Posted: Wed Jun 09, 2021 5:47 pm Post subject: Re: new dual port cylinder tins |
I like it but as you know VW people are cheap to a fault. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Wed Jun 09, 2021 5:53 pm Post subject: Re: new dual port cylinder tins |
Will you offer versions that clear dual carb manifolds?
Yes, VW people are cheap, but time is money. Searching through greasy stacks of tins only to find most are for single ports and the dual ports usually have the spark plug holes cut up.
Match it to the "Cooled" fan shroud and it makes the top of the engine .. nice.
But some times you get lucky and find NOS.
_________________ Glenn
Member #1009
#BlueSquare
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Wed Jun 09, 2021 5:57 pm Post subject: Re: new dual port cylinder tins |
Yeah they are more pricey, but how many hours of labor will someone save reworking old tins or getting cheap ones to fit?
The guy rebuilding his stocker on the cheap will pass, but the guys building 6k + engines might pull the trigger.
I have one set of OG tins in good shape, but that's it. I used to scour Pomona swap for decent tins and always came up empty. Just a bunch of aftermarket garbage or OG tins that were hammered/rusted to death. |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Wed Jun 09, 2021 6:12 pm Post subject: Re: new dual port cylinder tins |
I really like them but if I had to give one piece of constructive criticism it would be that the number font is different. It's subtle overall, but the big giveaway is the "1" on originals do not not have the little horizontal line at the bottom. _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
b-man Samba Member
Posted: Wed Jun 09, 2021 6:15 pm Post subject: Re: new dual port cylinder tins |
Dual port tins that clear dual carb manifolds would really be a big seller I would think.
I really like the tins you’re bringing to market but wouldn’t want to have to heavily mod them for my Skat-Trak tall 48IDA manifolds.
Hoping you’ll consider offering a version that clears most of the popular aftermarket dual carb intakes. _________________ 1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle |
Posted: Wed Jun 09, 2021 6:37 pm Post subject: Re: new dual port cylinder tins |
well at this point, we copied the stock parts, so if you have thicker manifolds, yes they would need trimmed, i do offer that as 1 of my services, but i will keep that in mind for future options. _________________ Volkaholic |
Posted: Wed Jun 09, 2021 6:47 pm Post subject: Re: new dual port cylinder tins |
It's easy enough for the engine builder to trim them. If you have trouble trimming them you probably shouldn't be building an engine to begin with Plus the best way to do it is trim based on the specific manifolds being used. Making universal high clearance tins would not work so well as it would leave a large gap with some combos, and probably not enough with the real radical welded ones.
I still like a good original set, however these are a game changer so nice job. Original ones are getting harder to find. The previously available repros are all pure garbage but these look real solid basically an exact replica. I like that they are a bit thicker gauge material too.
Someone needs to make a little set of various sized VW logo punch stamps, you know... for that show winning kind of restoration. Ok just kidding, well kinda _________________ 1967 Bug ( the daily rod )
Posted: Wed Jun 09, 2021 7:13 pm Post subject: Re: new dual port cylinder tins |
well the difficulty to finding good used tin is was drove this, i have never been happy with the scat empi stuff, but it is good enough for a baja, but will not use on a street car. i spent over a year making this happen, these are really nice, heavy duty items.
but yes, i have folks send me 1 manifold for mock up, as like you say, there are so many differnet manifolds, making a generic cutout would almost never be right. _________________ Volkaholic |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Wed Jun 09, 2021 7:30 pm Post subject: Re: new dual port cylinder tins |
judging my the photos, id say the quality is better than stock because,
A. most vw tins have wrinkles, these dont.
B. the finish will last longer.
HOwever, if you made tins that accept thicker manifolds, you would be selling these left and right. id even buy a pair. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Posted: Wed Jun 09, 2021 7:53 pm Post subject: Re: new dual port cylinder tins |
i hear you, but i am starting with stock, and as i am sure you know, there are many manifolds out there, so trimming for 1 or even a few will not work for all, again, i do offer that service. i think many folks can use the stock setup. _________________ Volkaholic |
Posted: Wed Jun 09, 2021 8:08 pm Post subject: Re: new dual port cylinder tins |
Trim them to fit
He can't produce a cover that will be snug around all the aftermarket manifolds produced in the last 50 years. Let alone a welded set.
Your starting with a better than new tin set. |
Posted: Wed Jun 09, 2021 8:11 pm Post subject: Re: new dual port cylinder tins |
Pruneman99 wrote: |
Trim them to fit
like a set with a larger opening, but a flexible seal that wraps around the manifold? _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Trevor P Samba Member
Joined: January 21, 2004 Posts: 863 Location: Saskatoon, SK, Canada
Posted: Thu Jun 10, 2021 6:16 am Post subject: Re: new dual port cylinder tin |
Glad to hear more people stepping up to the plate to fill a void with a quality product. Having just recently re worked some cheap garbage Empi tins I’ll be sure to keep you in mind on the next one. Now if someone would offer a rear breast tin that would fit an early car with a 1600 or larger engine!😳 _________________ 53 Canadian standard oval
56 Wolfsburg PG/SG
57 Oval, 2332 & Berg 5
70 911T
91 Westy |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3817 Location: Georgia
Posted: Thu Jun 10, 2021 6:47 am Post subject: Re: new dual port cylinder tins |
Just sent you an email. I’m very appreciative of your efforts.
Why did you wait 40 years though? 😉 _________________ Volkswagen!
(Compression 8.7:1) |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Thu Jun 10, 2021 7:36 am Post subject: Re: new dual port cylinder tins |
My 1835cc DP engine sports my factory 1970 SP tins that I cut to fit back in 1976. I did pick up two used dual port cylinder tins to install next time I have the engine out/apart, but this engine hasn't been apart since 1986.
That "someday" will also include painting the tins black.....
I'd like to return the non-doghouse fan shroud left air outlet to stock from the dealer-butchered AC type, but don't know if a part exists to do this....let me know if there's a way !!! Thanks. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Thu Jun 10, 2021 8:46 am Post subject: Re: new dual port cylinder tins |
Dang it Cusser!
I just removed my outlets last year.
Unfortunately, I threw them away.
jimmyhoffa Samba Member
Joined: February 16, 2014 Posts: 1056 Location: St. Louis
Posted: Thu Jun 10, 2021 10:43 am Post subject: Re: new dual port cylinder tins |
Just e-mailed for a basic set. Went out in the shop with calipers and found some .040" sheet metal and came back and e-mailed immediately. .040" is not messin' around. _________________ 1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous. |
mikemck Samba Member
Posted: Thu Jun 10, 2021 11:19 am Post subject: Re: new dual port cylinder tins |
Can someone explain what the carb preheat insulator is? |
Posted: Thu Jun 10, 2021 11:39 am Post subject: Re: new dual port cylinder tins |
mikemck wrote: |
seals and insulates the breast plate tin against the heat riser on stock single carb manifolds. There's a little pipe attached to the main intake runner tube. It runs down and connects to the #2 & #4 mini "header" tubes via a small flange. So effectively you have exhaust gases passing through a little tube thats heats up the manifold to promote better fuel atomization and prevent carb icing. _________________ 1967 Bug ( the daily rod )
