samm1 Samba Member
Joined: August 20, 2012 Posts: 217 Location: Saskatoon,Sask.
Posted: Thu Jun 10, 2021 5:34 pm Post subject: V-Belt size? |
So I bought this belt today and it’s too small yet that’s what it calls for the Alternator model. Supposed to be a wider belt for this model. I had to put the old one back on its narrower 3/8 vs 1/2”. I think I need a longer belt than what the parts store says . Any ideas would be appreciated.
_________________ Hella ya! |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Thu Jun 10, 2021 5:53 pm Post subject: Re: V-Belt size? |
it should take vw part # 111-903-137-e 73-79 beetle .
11.3mm x 912mm. the one you got looks slightly wider 12mm and shorter. 911mm . not much . maybe enough to make a difference? is the old belt marked? _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Thu Jun 10, 2021 5:54 pm Post subject: Re: V-Belt size? |
I use a 890mm belt on my engine with alternator.
I find belt size varies from engine to engine.
_________________ Glenn
Member #1009
#BlueSquare |
OTTO 1303 Samba Member
Joined: March 17, 2020 Posts: 636 Location: Louisiana
Posted: Thu Jun 10, 2021 7:52 pm Post subject: Re: V-Belt size? |
Try Gates 7355
9's kinda look like 7's _________________ 74 Super Sun Bug - OTTO
74 Super - DANZIG
74 Super - HERZOG |
samm1 Samba Member
Posted: Thu Jun 10, 2021 8:35 pm Post subject: Re: V-Belt size? |
Thanks for all your replies,When I put the belt on I had to pull all the shims out and it still wouldn’t work. _________________ Hella ya! |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Thu Jun 10, 2021 9:13 pm Post subject: Re: V-Belt size? |
samm1 wrote: |
Thanks for all your replies,When I put the belt on I had to pull all the shims out and it still wouldn’t work. |
Pulling shims out is what you do to make the belt tighter. Do you mean you put all your shims in between the pulley halves, and it still didn't fit?
That's exactly what has happened every time I try to put on an 11.3x912 belt on my alternator. Good old 9.5x905 works fine, except
for the new Continental brand belts (made in India) of that size, which are noticeably smaller than the previous German belts of
the "same" size. The India ones do not fit. The Gates 7355 also is good. My local FLAPS were gouging for that belt, wanted
almost 3 times what I paid Rock Auto for one. _________________ '67 bug: seized by the authorities
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Thu Jun 10, 2021 11:31 pm Post subject: Re: V-Belt size? |
Kree, I’ve found the exact same problems as you’ve described. New Continental belts suck. The alternator belt, and the generator belt.
I settled for a Gates 7355, but even that belt doesn’t sink down low enough in the alternator pulley. It rides too high, which reduces the fan spin a bit. But, at least it fits and offers the proper 5/8 inch slack at the midway point between pulleys. Also, I don’t overheat, so it’s okay, I guess.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
