soloyosh Samba Member
Joined: February 24, 2021 Posts: 28 Location: LHC, AZ
Posted: Fri Jun 11, 2021 9:34 am Post subject: Type 4 fan shroud fasteners |
Hi all,
I was working in the garage last night on our new-to-us 1800.
The fan shroud we have seems to be missing a number of fasteners. I forgot to bring them to work to order them. I remember they were M6 but can anyone confirm the length of 29 and 31 in the view below?
Thank you
Brett and Aaron _________________ Brett (dad) and Aaron (son) |
obieoberstar Samba Member
Posted: Sat Jun 12, 2021 5:41 pm Post subject: Re: Type 4 fan shroud fasteners |
I believe #29 is M8. Unsure of the length of the M6 and M8 fasteners on that shroud. |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Sat Jun 12, 2021 7:34 pm Post subject: Re: Type 4 fan shroud fasteners |
This is what I found (from the general forum in the hardware sticky).
ivwshane wrote: |
I've never been to this part of the forum but hopefully this info helps.
This applies to a 77 type IV engine but it could cover other type IV model years.
Sizes are either exact or the closest sizes currently available new. Most hardware can/was purchased from boltdepot, belmetric, and fastenal.
Nuts and bolts
Clutch pressure plate
- 8mmx18.5mm 1.25 @6 hex tap
Engine mount
- 8mmx20mm 1.25 @4 serrated flange (fastenal #11115901)
Plenum-case mount
- 8mmx83?mm 1.25 @2 hex tap
EGR
- 6mmx10mm 1.0 @2 pan head
EGR valve
- 6mmx16mm 1.0 @2 hex tap
EGR valve to plenum
- 6mmx55mm 1.0 @2 Allen head cap
Throttle body
- 6mmx25mm 1.0 @2 pan head
EGR/exhaust
- 8mmx30mm 1.25 @2 hex tap
Heat exchanger left
- 6mmx14mm 1.0 @1 serrated flange (fastenal # 11115895-16mm # 111115894-12mm)
Booster fan
- 6mmx15mm 1.0 @2 hex tap
Fan guard
Alternator bracket
- 8mmx18mm 1.25 @2 hex tap
Fan housing
- 6mmx20mm 1.25 @8 pan Phillips
- 8mmx16mm 1.25 @1 hex tap
- 8mmx45mm 1.25 @2 hex tap
- 8mmx45mm 1.25 @1 hex
- 8mmx30mm 1.25 @3 hex tap
Starter bolt
- 10mmx70mm 1.5 @1 hex
Exhaust EGR side
- 8mmx20mm 1.25 @1 hex
Engine carrier bolts
- 8mmx65mm 1.25 @4 hex
Bumper
- 10mmx25mm 1.5 @4 hex tap
Fan hub
- 8mmx30mm 1.25 @1 serrated flange
Transmission (fastenal # 11115903)
- 10mmx75mm 1.5 @1 hex
Transmission mount
- 10mmx45mm 1.5 @2 hex
CV bolts
- 8mmx48mm 12 point
Cooling tin
- 6mmx12mm 1.0 @1 hex tap (fastenal # 0128747)
Cylinder cooling tin
- 5mmx12mm 1.0 @2 hex tap (fastenal # 1138543)
Oil temp plate
- 6mmx10mm 1.0 @2 hex tap (fastenal # 11113804)
Valve lifters
- 7mm nut @8 (fastenal # 0161929)
- 6mm square nut @4 (fastenal # 0161910)
Thermostat
- 8mmx10mm 1.25 @1 hex tap (fastenal # 11552374)
Engine case top
- 8mmx88mm 1.25 @1 hex
- 8mmx93mm 1.25 @1 hex
Alternator tin
- 6mmx30mm 1.0 @1 hex tap (fastenal # 0153965)
Control flaps cable holder
- 4mmx8mm @1 hex tap (fastenal # 0162373)
- 4mm square nut
Fan housing cooling flaps (non stock item and a mod to keep flaps from falling off)
- 1/8" spring e-clips x4 (fastenal # 0401249)
Stud length for cross over pipe
28.5mmx8mmx1.25 |
_________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Mon Jun 14, 2021 2:22 pm Post subject: Re: Type 4 fan shroud fasteners |
ivwshane wrote: |
ivwshane wrote: |
Nuts and bolts
Fan housing
Cooling tin
Alternator tin
Interesting. All my tin screws on both engines that I have are slotted cheese heads (M6x10) and the non-hex screws on the fan housing are also slotted cheese heads. I was going to change them out because I hate slotted fasteners but the list above said they should be Phillips and hex respectively. Is that what you guys have been seeing on other Type 4 engines?
Cheers _________________ Brett (dad) and Aaron (son) |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Jun 14, 2021 2:31 pm Post subject: Re: Type 4 fan shroud fasteners |
Slot changed to Phillips ~76 IIRC, earlier ones are all slot and some hex all over the tin. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Jun 14, 2021 8:15 pm Post subject: Re: Type 4 fan shroud fasteners |
next time my engine is out I will replace all the fan housing hardware with some socket head screws. Mostly for cosmetic reasons, but they easier to get a proper torque on.
while i am at it, I might cut off that little flat area that sticks out just above the alternator. It gets in the way when trying to turn the engine over using a wrench on the alternator pulley. |
Posted: Mon Jun 14, 2021 8:48 pm Post subject: Re: Type 4 fan shroud fasteners |
obieoberstar wrote: |
while i am at it, I might cut off that little flat area that sticks out just above the alternator.. |
Isn't that going to make belt adjustment (more) challenging? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Jun 14, 2021 9:08 pm Post subject: Re: Type 4 fan shroud fasteners |
never used that spot to adjust the belt.
i use a serpentine belt tool that has a 90 degree hook on the end of it to pull on the upper socket head screw to tension the belt. |
Posted: Tue Jun 15, 2021 1:48 am Post subject: Re: Type 4 fan shroud fasteners |
I like flange head screws with a hex for holding the tin as it makes removal easier. I like to use my tiny little 1/4" ratchet for installing as it keeps me from being prone to overtightening them. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12687 Location: on a bike ride somewhere
Posted: Tue Jun 15, 2021 8:36 am Post subject: Re: Type 4 fan shroud fasteners |
busdaddy wrote: |
Isn't that going to make belt adjustment (more) challenging? |
Can't you just stab a screwdriver into the tin and bend it all to shit instead?
+1 for flanged or Phillips tin screws, MUCH easier to instal than flat-head when working upside down or horizontally.
www.airschooled.com |
Posted: Tue Jun 15, 2021 9:27 am Post subject: Re: Type 4 fan shroud fasteners |
airschooled wrote: |
busdaddy wrote: |
Robbie |
An impact hammer is easier to use with a Phillips head as well, as it's hard to keep a bit centered in a slotted head screw. |
edhnb Samba Member
Joined: December 02, 2011 Posts: 210 Location: El Dorado Hills, California
Posted: Wed Mar 20, 2024 2:23 pm Post subject: Re: Type 4 fan shroud fasteners |
When assembling the 2 halves of the fan shroud, is there a need for any form a gasket type sealant? Also, anyone know the torque specs for the shroud fastening bolts? _________________ 1977 Asi Riviera |
Posted: Wed Mar 20, 2024 3:19 pm Post subject: Re: Type 4 fan shroud fasteners |
No sealant required, but some Neverseez on the fastener threads isn't a bad idea.
Torque specs are in the Bentley, maybe not for those particular bolts, but find 2 or 3 other 6mm bolts or machine screws and see what's recommended for them, preferrably ones used in magnesium or aluminum castings.
Hint: there's some similar fasteners securing the throwout bearing guide sleeve to the bellhousing on 71+ transmissions so look in the end of the transmission section. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Mar 20, 2024 7:46 pm Post subject: Re: Type 4 fan shroud fasteners |
for the 6mm screws I would not go past 80 in/lbs. 8mm, 10 ft/bs, max.
just make sure the halves are coming together evenly. they need to be snug, and just a little more.
best practice would be to run a tap/thread chaser on all the threaded fittings while you have it apart.
some Blue thread locker would be good too. |
