zoti Samba Member
Joined: December 26, 2007 Posts: 2061 Location: Plano, TX USA
Posted: Fri Jun 11, 2021 4:47 pm Post subject: What's the difference between Syncro front brakes and 2wd front |
brakes?
Will syncro rotors work on 2wd?
Are they better than 2wd? Can you upgrade 2wd front brakes to syncro front brakes if they are better?
Part# 251 407 615Q
Mine is an 88 2wd Westfalia. |
4Gears4Tires Samba Member
Posted: Sun Jun 13, 2021 1:22 pm Post subject: Re: What's the difference between Syncro front brakes and 2wd front |
I doubt it. Aren't the brake rotors for a 2wd also used for the bearing? The wheel bearing is a sealed press fit bearing for the Syncro. _________________ '87 Syncro
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Sun Jun 13, 2021 3:53 pm Post subject: Re: What's the difference between Syncro front brakes and 2wd front |
Syncro rotors are different than 2wd but calipers and pads are the same |
clift_d Samba Member
Joined: December 02, 2012 Posts: 265 Location: Hackney innit, UK
Posted: Mon Jun 14, 2021 1:56 am Post subject: Re: What's the difference between Syncro front brakes and 2wd front |
candyman wrote: |
If I recall correctly, some versions of the 2WD South African Microbus had a separate hub that fitted to the front wheel bearing in place of the disc/rotor, and which allowed you to use standard Sycnro discs/rotors, with the same calipers/pads. This hub conversion also meant that the same components for the vented brake option (SA big brakes) could be fitted to either 2WD or Syncro vans. _________________ 1988 LHD T25 1.6TD Westfalia Club Joker syncro |
