gimli497N Samba Member
Posted: Sat Jun 12, 2021 8:17 am Post subject: Fuel running from throttle pump spout after car shutdown |
Hi everyone,
So i have a brand new EMPI Pict 34/3 carb. I have adjusted the throttle pump and i have no flat spots. There are no vacuum leaks. I have checked the fuel pump pressure and it sits nicely at 2.9 psi I have checked the float bowl and its not overflowing and the needle valve is working properly.
So after the cars had a run and has stopped say after about 5- 10 mins i can hear fuel running in the throat of the carb and smell petrol. SO i took off the air filter and had a look to see where it was coming from and its was running out of the fuel pump spout. I check the idle cut off and all was working as it should. I also backed off the throttle pump adjustment to see if it stopped it, but it just gave me a nasty flat spot and it still did it!!
Thing is it doesnt do it straight away it starts after about 5 - 10 mins, so if i stp the car and start her virtually straight away she starts right up and purrs like a kitten, however if i walk away for 10 mins and come back she needs more cranking to start and a wide open throttle when up to temp. I know that the VW manual states that when starting from hot you should hold the throttle open until she fires and thats normal but she is strugglng even with that. My theory is that the engine is flooding from this and thats why she is harder to start after its done it. I am at a loss and really dont know what to look at here. I had over heating issue which i got sorted (see my other topic) and she always starts and drives beautifully so not sure how to fix this any help would be great!! |
Michael Ambrozik Samba Member
Joined: October 17, 2020 Posts: 631 Location: San Jose, CA
Posted: Sat Jun 12, 2021 9:48 am Post subject: Re: Fuel running from throttle pump spout after car shutdown |
what is happening is after 5-10 stop it is flooding. Have you checked the fuel tank vent to make sure it is not plugged. If it is it can cause the fuel line to pressurize and send fuel past the pump and into the carb and pass the needle and straight to the accelerator pump and down the carb |
vernonc Samba Member
Joined: April 23, 2012 Posts: 681 Location: Parkersburg, WV..yes, I sold the boat
Posted: Sat Jun 12, 2021 10:03 am Post subject: Re: Fuel running from throttle pump spout after car shutdown |
Michael Ambrozik wrote: |
First time I've ever heard of that happening..........seems like violating the laws of physics.
ol' mort _________________ "Those who don't read newspapers are un-informed. Those who do read newspapers are mis-informed." Will Rogers
'69 sedan, low mileage, all original.....currently being 'freshened-up' for road trips and daily driving...just not every day
Freshening-up link http://www.thesamba.com/vw/forum/viewtopic.php?t=617386 |
Starbucket Samba Member
Posted: Sat Jun 12, 2021 11:31 am Post subject: Re: Fuel running from throttle pump spout after car shutdown |
Post a picture of motor, I bet the gas line from the tank isn't mounted to the fan shroud instead it's laying on the tin and is getting hot and boiling the gas in the line forcing it past fuel pump and flooding the carb. |
Posted: Sat Jun 12, 2021 1:15 pm Post subject: Re: Fuel running from throttle pump spout after car shutdown |
Hi thanks for the replies. I know for a fact that the vent on the tank isnt plugged as i have checked, also the tank has all new fuel lines and vent hoses.
The steel fuel line that comes through the bell housing tin into the engine bay runs along the top of the intake manifold to the pump. I suspected it might be something like this causing the problem, and looking at it now its close to the heat riser pipes. Can anyone post a pic or point me to one as to how this should be routed?
I have tried to upload a pic but am not having much luck, as soon as i can i will get one posted. |
lboos Samba Member
Joined: November 20, 2015 Posts: 410 Location: Marietta GA.
Posted: Sat Jun 12, 2021 2:15 pm Post subject: Re: Fuel running from throttle pump spout after car shutdown |
gimli497N wrote: |
Here's a pic. of how I routed mine, I used a plastic elect. tie to hold the fuel line off the intake for #3 cly. if you look close you can see the black plastic tie att. to the tin about 2" down and to the left of the coil on the heater connection.
I also put a piece of fuel hose split [1 1/2 " to keep the metal fuel line off of the intake connection screws.
My prob. was while at idle for a long time [3-4 min's] the engine would just shut off, but would start up right away. it has not done this since I raised the fuel line off the engine around #3 cly. |
frenchroast Samba Member
Posted: Sat Jun 12, 2021 9:07 pm Post subject: Re: Fuel running from throttle pump spout after car shutdown |
Did you just fill the tank? Check the vent hose in the trunk is in place and not pinched by the hinge. If you just filled the tank with cool gas from an inground tank, as it warms and expands it will flow out the vent hose. Speculating here but if that hose is pinched, it could be forcing it through the pump and into the carb. |
bomberbob Samba Member
Posted: Sun Jun 13, 2021 5:19 am Post subject: Re: Fuel running from throttle pump spout after car shutdown |
I had issues similar to yours, after a shutdown I could look down the carb throat and see gas dripping. Stunk up the garage with gas fumes. I routed my fuel line way out of the way of anything hot. This may have overdid it, but its out of the way for sparkplug changes.
_________________ 1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa |
mukluk Samba Member
Posted: Sun Jun 13, 2021 12:00 pm Post subject: Re: Fuel running from throttle pump spout after car shutdown |
Sounds like symptoms of heat soak. Modern gasoline and gas/ethanol blends can start to boil at temps as low as 135°F, so all it takes is a little time post shutdown for heat to creep into the fuel pump and carburetor to get things percolating. Best you can do is try to insulate the fuel line, maybe install a phenolic spacer between the carb and intake manifold, and do what you can to help get heat out of the engine compartment. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Mon Jun 14, 2021 3:11 am Post subject: Re: Fuel running from throttle pump spout after car shutdown |
thanks for the pics thsts a big help… so heres how it was..
Posted: Mon Jun 14, 2021 3:14 am Post subject: Re: Fuel running from throttle pump spout after car shutdown |
heres how it is now…
The steel line runs up the side of the fan shroud and the braided fuel line runs from the pump under the coil bracket to the too of the steel line on the side of the fan shroud… so far so good i think… |
Lemons 4 Gigi Samba Member
Posted: Mon Jun 14, 2021 4:32 pm Post subject: Re: Fuel running from throttle pump spout after car shutdown |
gimli497N wrote: |
Did this solve your hard start problem? I had the same routing of the fuel line as you did and just moved it today. Have not had a chance to drive her yet so just curious if this helped you... Thanks! _________________ 1971 Super Convertible "Gigi", Lemon Yellow (Factory Zitronengelb L-11E)
1970 Dodge Challenger R/T "Jezzy", 440, 4-spd, pLuM cRaZy!
A couple of Jeeps.. |
Posted: Mon Jun 14, 2021 11:35 pm Post subject: Re: Fuel running from throttle pump spout after car shutdown |
It seems to.. I still have to have my foot right down on throttle when shes up to temp to start but its taken much less cranking. Im not sure about the fuel leaking from the throttle spout issue though… so far it seems to have stopped… hope it has helped with yours |
