missing e brake parts, 68 standard
bomberbob
bomberbob is offline
PostPosted: Sat Jun 12, 2021 8:41 am    Post subject: missing e brake parts, 68 standard Reply with quote
E brake cables were frayed, so I decided to replace. When I put the torque meister on the nut to pull the drum, it was only hand tight. There was a cotter pin in there though. Puilled drums, and I found the axles were wet, so the seals are bad. OK, order seal kit. Then when I pulled the backing plate & brakes off I realize I am missing parts. So much maintenance malpractice on this car, it doesn't surprise me any more.
OK, previous owner vent done. While I have it torn down to this point, should I replace the bearings? Looks like I need to make my own tools to pull them.
1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa
sjbartnik
sjbartnik is offline
PostPosted: Sat Jun 12, 2021 11:23 am    Post subject: Re: missing e brake parts, 68 standard Reply with quote
Those bearings are pretty indestructible because they're quite heavy duty for the application.
I wouldn't replace them unless they were bad, those old German bearings were very good quality and you'd be unlikely to get something as good new on the market today.
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Sat Jun 12, 2021 11:49 am    Post subject: Re: missing e brake parts, 68 standard Reply with quote
x2
Jimbo
TDCTDI wrote:
67rustavenger wrote:
bomberbob
PostPosted: Sun Jun 13, 2021 5:01 am    Post subject: Re: missing e brake parts, 68 standard Reply with quote
OK, I will leave them alone. I did order new brake lines, previous owner didn't have the right length of lines so they put these cute pig tail coils in there. Might as well fix it right while I am in there.
Marion, Iowa
