JW33 Samba Member
Posted: Sun Jun 13, 2021 2:54 pm Post subject: Steering column bearing |
The picture below is from the top of the steering column from a buggy. I'm hoping someone can help me identify the correct bearing or bushing that fits. The current bearing fits in the tube that covers the steering column, but there is a ton of space between that and the column itself. Hence the steering wheel has a lot of movement.
I tried the bearing from a '67, but the diameter was too small. Could it be the tube and the steering column are from different cars altogether?
The spline measures about 18mm in diameter, and a 24mm nut fits on the threads.
sailtexas186548 Samba Member
Joined: December 01, 2014 Posts: 423 Location: Kemah, Tx
Posted: Sun Jun 13, 2021 6:33 pm Post subject: Re: Steering column bearing |
My buggie had the stock vw steering rod inside a 2” PVC pipe painted silver, no bearings... I’m not saying that yours is that bad, but don’t just assume it was ever “correct” _________________ it's more fun loud and dirty |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
JW33 Samba Member
Posted: Sun Jun 13, 2021 6:49 pm Post subject: Re: Steering column bearing |
I tried the part from Wolfsburg West (113415585A) for the 67s and earlier, but it is too small in diameter. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon Jun 14, 2021 6:06 am Post subject: Re: Steering column bearing |
Possibly 111-5350....
https://www.westcoastmetric.com/c-1169949-vw-bug-1...parts.html
EVfun Samba Member
Posted: Mon Jun 14, 2021 10:41 am Post subject: Re: Steering column bearing |
I was wondering if perhaps that is a '60-'61 column. I don't see that bearing listed at any VW parts house. The columns look the same from the outside and have the same steering wheel splines as the '62-'67, but have some internal differences. _________________
Wildthings wrote: |
