Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Mon Jun 14, 2021 9:57 am Post subject: Distributor #3 lobe retard discussion |
There has been some discussion if you do a further search on whether some VW distributors have a retrd of @ 3 degrees built into the #3 lobe of the points cam to attempt to keep the engine cooler since the fan shroud on original single port type 1 and 2 engines has the oil cooler interfering in cooling air flow. I don't believe it has ever been fully researched "in the flesh" which distributors have this feature and which ones do not. As above there is some manual documentation out there but nothing with extensive real testing. I will attempt here to do some real world testing and post the results.
I plan on testing the following distributors on my 1949 Sun MSD Distributor Tester. I'm open to some educated suggestions if you believe there's another distributor version I should test.
ZV PAU 4 R 5 big cap 40 hp (March 1962) NO
ZV/PAU 4 R 6 big cap type III (Feb 1962) [NO)
ZV/JU 4 R 3 20 degree advance (9U Sept 1963) YES
113 905 205 B Garbe Lahmeyer (no date) maybe
111 905 205 N 20 degree advance (502 Feb 1965) YES
113 905 205 K short cap 25 degree advance (805 May 1968) YES
131 905 205 as above but exclusively for Bus (Sept 1968) YES
113 905 205 M short cap 32 degrees advance 1968 (708 Aug 1967) YES
113 905 205 T tall cap 32 degrees advance (Oct 1969) [YES]
315 905 205 B Service replacement (126 June 1971) YES
113 905 205 P autostick Beetle 1968
113 905 205 AJ DVDA Beetle (029 Sept 1970) NO
211 905 205 Q DVDA Bus 1971
113 905 205 AN DVDA Beetle YES tested 2 still a YES
113 905 205 AL SVDA for Europe (225 May 1972) maybe
0 231 174 001 1973 Porsche 914 NO
0 231 178 009 omnipresent (624 April 1976 German manufacture) NO
0 231 129 010 later 1960 Bus production (no date) NO
0 231 129 019 later 36 hp bus production (326 June 1973) NO
I will have to do some assembly to prepare 311 905 205, D,E,F,G, P, AD. UPDATE; I have 11x 311 SVA cores some dual spring but every single one of them will require some tear down before they will read stable enough on the Sun Machine to yield accurate results. I already know the results of some of these tests from experience but I will do the test and post the results none the less. Maybe one of the reproduction "034"' which I don't believe I have.
Edit: I'm using a distributor machine that is seventy - two years old and it's demarcated in one degree increments as found at the distributor rotation so 3 degrees of spark advance at the crank equals 1 1/2 degrees at the machine. That small of an increment is open to some error especially with my limited visual acuity. One should also consider the ware on points cam lobes. I've run NOS distributors and the difference is clear but on used distributors we are open to some interpretation. Maybe = need a second closer look. _________________ Roads Scholar &
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76897 Location: Sneaking up behind you
Posted: Mon Jun 14, 2021 11:45 am Post subject: Re: Distributor #3 lobe retard discussion |
Please post the results in your first post so its all in one place.
If you can't edit it, pm me and I'll edit it.
Thus way it's easy to find the results. _________________ Glenn
Member #1009
#BlueSquare |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Mon Jun 14, 2021 12:00 pm Post subject: Re: Distributor #3 lobe retard discussion |
The 113 905 205 T is the tall cap version of the M no?
If you happen to have a 311 905 205 F single or dual spring I'd like to see the results on that one.
tommiebsmith Samba Member
Posted: Mon Jun 14, 2021 12:28 pm Post subject: Re: Distributor #3 lobe retard discussion |
I'd be interested in the results also..
Great start to answers that a bunch of people ASSUME they know already..
thanks for the time and effort.
I think a specific answer to start the thread to verify exactly where #3 should located on the distributor - based on the indicator on the housing and the location of the drive gear ..
we all know many have drive gears dropped in all over the place .. and to note the specifics of what "SHOULD" be may offset what is out there and what people are working with. |
Posted: Mon Jun 14, 2021 12:56 pm Post subject: Re: Distributor #3 lobe retard discussion |
Respectfully, I'd like to post here as the other topic title will not lead anyone to this data while this title does. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33991 Location: Conejo Valley, CA
Posted: Mon Jun 14, 2021 12:59 pm Post subject: Re: Distributor #3 lobe retard discussion |
I've always though it odd that a Type 3 motor would have #3 retarded, since the cooling air issues is not the same as for the upright engines.
But perhaps the slight bleed off of oil cooler air (though it exits independently) makes #3 run hotter there, too?
Elfrink's manual makes it clear it does so. It will be good to see it in practice. |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Mon Jun 14, 2021 1:19 pm Post subject: Re: Distributor #3 lobe retard discussion |
tasb wrote: |
Respectfully, I'd like to post here as the other topic title will not lead anyone to this data while this title does. |
Not postive but I think Glenn simply suggested to edit the first post in this thread so all the results are right at the top of the page and easy to find. _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
Glenn Mr. 010
Posted: Mon Jun 14, 2021 1:20 pm Post subject: Re: Distributor #3 lobe retard discussion |
tasb wrote: |
That's what I meant.
The first post here. Please add the results under each model.
That way all the data is in the first post and people don't need to wade through all the noise that follows. If too much time.passes and you can't edit the first post, pm me.and I'll add it. It will still be your post/topic.
I'll add it to the FAQS Sticky at the top of the forum. _________________ Glenn
Member #1009
#BlueSquare |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5994 Location: Brooklyn
Posted: Mon Jun 14, 2021 3:19 pm Post subject: Re: Distributor #3 lobe retard discussion |
My Type 3 has the 311 905 205 D and I can confirm it *does* have the built-in retard on cylinder #3.
Verified it with timing light vs. #1. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Onceler Samba Member
Posted: Mon Jun 14, 2021 3:44 pm Post subject: Re: Distributor #3 lobe retard discussion |
I’ve never understood why VW would purposely try and burn no.3 exhaust valve with less timing. I guess if there’s a knock due to lack of cooling maybe _________________ 1972 Karmann Ghia |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51121 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Jun 14, 2021 4:18 pm Post subject: Re: Distributor #3 lobe retard discussion |
I eagerly await the results of this, so much speculation and so few facts right now. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Jun 14, 2021 4:23 pm Post subject: Re: Distributor #3 lobe retard discussion |
Pruneman99 wrote: |
If you happen to have a 311 905 205 F single or dual spring I'd like to see the results on that one. |
Yes, 113 T is tall cap fixed, thanks. My 311 cores are limited since that crowd found me years ago, they've cleaned me out several times. _________________ Roads Scholar &
Posted: Mon Jun 14, 2021 4:26 pm Post subject: Re: Distributor #3 lobe retard discussion |
Onceler wrote: |
I’ve never understood why VW would purposely try and burn no.3 exhaust valve with less timing. I guess if there’s a knock due to lack of cooling maybe |
It's a little more complicated than that as valve tappet clearance should be figured in. It does add to the need for the clearance warning being checked regularly. _________________ Roads Scholar &
Frederik Samba Member
Posted: Mon Jun 14, 2021 4:53 pm Post subject: Re: Distributor #3 lobe retard discussion |
I've posted this before, but this thread might be good to have it in as well:
Quote: |
The following is from a service bullitin from Bosch February 2nd 1965 pointing out changes in Bosch distributors for vw.
Loosly translated:
Formerly VW 1500N [type 3] was fitted with distributor ZV/PAU 4 R 4 and ...R 6. This distributor types was from chassie No 0221975 (aug. 63) replaced by the distributor 0 231 147 002 (ZV/JU 4 R3) with vacuum only regulation and smaller vacuum can.
From the start of the year 1964 vw 1200 [type 1] and vw transporter [type 2] also are fitted with this new type of distributor and in August it was introduced under the designation 0 231 147 002 -JU4 (R) for vw 1200, all type 2 models and 1500N with one carburetor. The vacuum can on this distributor is 65mm. At the same time of the above distributors an asymmetric points cam shaft was introduced, ie the angle between the highest points of the cam is located, starting from No1 cylinder, 0-90-182-270 degrees [My note: 2deg at distributor=4deg at engine]. Timing must therefore always be done on No1 cylinder.
The introduction of this new distributor also brought a change of the carburetor. From carburetor number 238 225 the vacuum port has been moved 8mm closer to the throttle plate. In the vacuum connection a drossel jet is fitted. This in combination with the new distributor entails to even out the pulsating vacuum signal.
The following combination can be made:
The new carburetor with the new distributor (smaller vacuum can)
The new carburetor with the old distributors (bigger vacuum can)
But the old carburetor should not be used with the new distributor
Change for 1500S:
Before 1500S was fitted with distributor 0 231 150 001 (ZV/JCU 4 R 3) with centrifugal- and vacuum regulation. This distributor was from Augustr 1964 replaced by distributor 0 231 147 007 -JU4(R) with asymmetric points cam shaft as described above, but with a bigger vacuum can of 85mm.
[/u]
Posted: Mon Jun 14, 2021 5:41 pm Post subject: Re: Distributor #3 lobe retard discussion |
So according to the above documentation the asymetric ( I like that term better than retarded) cam began with the 111 905 205 M. i don't think there was any difference between the 111 M and the ZV/JU 4 R 3 designation other than the part number but I will have to dig out one and run it to confirm. so far except for the above my finidngs are in line with the documentation. _________________ Roads Scholar &
Posted: Mon Jun 14, 2021 7:26 pm Post subject: Re: Distributor #3 lobe retard discussion |
This is great stuff. Thank you Tasb. There was always the mystery of the #3 retard, but the information was always so vague and unreliable. It's great to have actual test data.
Maybe try some 009s? I've heard both ways, especially on the non-Bosch aftermarket ones. It would be nice to see a sampling there. |
Posted: Mon Jun 14, 2021 9:07 pm Post subject: Re: Distributor #3 lobe retard discussion |
Yeah, the uh oh nine conundrum. I try to keep the 009 cores to a minimum. Sold one at Prado for $10 yesterday just so's I didn't have to look at it anymore. _________________ Roads Scholar &
Zundfolge1432 Samba Member
Posted: Mon Jun 14, 2021 9:14 pm Post subject: Re: Distributor #3 lobe retard discussion |
Sounds cool about the 009. I put out a call saying I would buy 009 cores a few years back. As expected talk is cheap all crickets out there in samba land. |
Posted: Mon Jun 14, 2021 11:24 pm Post subject: Re: Distributor #3 lobe retard discussion |
tasb wrote: |
So according to the above documentation the asymetric ( I like that term better than retarded) cam began with the 111 905 205 M. i don't think there was any difference between the 111 M and the ZV/JU 4 R 3 designation other than the part number but I will have to dig out one and run it to confirm. so far except for the above my finidngs are in line with the documentation. |
It might be my translation, but I think the text refers to that all the above (in the text) have asymmetric cam, starting with ZV/JU 4 R 3 on type 3 in aug -63, followed by type 1 and 2 from the beginning of the year 1964 (mid modell year). And by August 1964 the distributor model name change to 0 231 147 002 -JU4 (R).
ZV/JU 4 R 3 got the same long/new Bosch part number 0 231 147 002, but I think for vw part numbers they got L (ZV/JU 4 R 3) and M (0 231 147 002 -JU4) endings?
The asymmetric cam was not a vw specific feature, in 1964 Opel also got a change so the distributor have a cam that was 0-92-180-272 degrees, the same 4deg retard as vw on No3 but also No2 (I think Opel has 1-3-4-2 firering order?). |
oprn Samba Member
Joined: November 13, 2016 Posts: 12703 Location: Western Canada
Posted: Tue Jun 15, 2021 4:28 am Post subject: Re: Distributor #3 lobe retard discussion |
Excellent! Thanks for this! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
