tristanblue Samba Member
Posted: Wed Jun 16, 2021 4:26 pm Post subject: Re: Spring spacer under CV flange which direction? 002 bus trans |
airschooled wrote: |
Type 1 and early 002 transaxles also have threaded output shafts. (Not sure about late 002/091). I have had to compress the part in question on T1 transaxles, using the exact oil pump tool shown in Ray's diagram.
Colin @ Itinerant Air Cooled shows the correct orientation here:
Airschooled, beautiful post and pic! Now if someone else down the road searches for the answer to this same question, there it is laid out plain as day. Thanks man! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
Posted: Wed Jun 16, 2021 5:47 pm Post subject: Re: Spring spacer under CV flange which direction? 002 bus trans |
Moderator note:
I did some clean up, let's stay away from insulting others.
If you don't like someone's posts, put them on ignore so you don't see it or skip over it. This is pretty easy when it's super long. _________________ How to Post Photos
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Wed Jun 16, 2021 10:14 pm Post subject: Re: Spring spacer under CV flange which direction? 002 bus trans |
Just for the info of those who might be thinking they need to acquire one of those special tools to get
their joint flanges back on, all I ever needed was a deep socket that goes over the diff stub axle and rests
on the circlip. A medium rap on the socket will "compress" the spacer/spring/thrustring/whatever underneath
and allow the circlip to snap into its groove. I just wish getting that damn circlip off was as easy. _________________ '67 bug: seized by the authorities
