Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2311 Location: Adobe Jungle USA
Posted: Mon Jun 14, 2021 10:16 pm Post subject: Rabbit ’78 identify these struts |
Vintage diesel Rabbit needs front end work. Entire struts are a little costly, but new shocks are affordable. How much work is involved putting shocks inside that spring, with the struts out? Is there any other worn out parts that say I should buy the whole strut assembly? Can a standard car shop do it successfully if I bring in the struts and shocks?
EDITed the subject line as I figure this out _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit
Joined: August 31, 2013 Posts: 12815 Location: North Carolina
Posted: Tue Jun 15, 2021 4:55 am Post subject: Re: Rabbit ’78 pros and cons of new struts vs shocks |
You cannot put shocks on the front of your Rabbit. You can get strut inserts or strut assemblies & most shops should be able to install them. You will also need to get upper mounts and bump stops.
Rock auto has the inserts starting at $17 each.
I would suggest that you remove the assemblies yourself & let the shop install the inserts. The upper bolt attaching the strut to the steering knuckle has an eccentric cam on it for camber adjustment, inevitability, the tech school flunkies put the impact gun in the bolt side & destroy this difficult to find bolt.
In addition to this, there is a 1”-ish collar/spacer that is fitted into the strut mount, under the top nut. These are usually tossed with old strut mounts by the inattentive impact jockeys who then just hammer the nut down until tight, binding the part that’s supposed to turn freely. |
Tvättbjörn Samba Member
Posted: Tue Jun 15, 2021 3:24 pm Post subject: Re: Rabbit ’78 pros and cons of new struts vs shocks |
better to use a torque wrench for the large strut nut. If too tight the shock will bind and not move freely in / out. Too loose other trouble is going to happen.
$ 280 for a complete pair of sachs shocks / struts / springs units ready to install is not bad. By the time you buy all parts and have them installed at a shop i doubt you are going to save any money.
Note: I have also seen rusted thru lower spring seats on old struts. They are only 40 years old ! |
Posted: Wed Jun 16, 2021 5:02 pm Post subject: Re: Rabbit ’78 pros and cons of new struts vs shocks |
Before I take it apart, trying to figure out which struts I have in there, internal or externally threaded? I got a picture with my cellphone of the top, can anyone identify this type?
There is one notch on a sort of thick round washer welded onto the top, I think. This is a 1978, the first year of Rabbit in the USA, if it makes a difference. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Wed Jun 16, 2021 5:08 pm Post subject: Re: Rabbit ’78 identify these struts |
Since the top is on the outside of the housing, that would be externally threaded.
BUT, there is the possibility that those have been replaced before and that they are aftermarket ones that are sealed/welded. Clean the housing just below the cap & see if there are any threads visible. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Jun 16, 2021 5:49 pm Post subject: Re: Rabbit ’78 identify these struts |
Thanks, that’s what I suspected. Not too likely these were ever worked on since the car only has 55,000 miles on it. Should I be able to unscrew that cap with a pipe wrench? Can I put a new “insert” in there? _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Wed Jun 16, 2021 6:21 pm Post subject: Re: Rabbit ’78 identify these struts |
I use two chain wrenches, one on the housing, & the other on the cap & even then, it can take quite a bit of force to separate them. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Wed Jul 07, 2021 12:15 pm Post subject: Re: Rabbit ’78 identify these struts |
Thanks everyone for the support! I took the struts in to a local shop along with new Monroe inserts. They installed them and I was surprised to see some upgraded top nuts:
I guess they came with the inserts but I didnt open the box.
Does anyone know what plastic anti-squeak tubing to put over the springs? For next time I take it apart. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2525 Location: formerly NY currently NC
Posted: Wed Jul 07, 2021 5:18 pm Post subject: Re: Rabbit ’78 identify these struts |
looks like you just put the destroyed bump stops back on so i assume you didnt buy the upper strut bearings like tdctdi told you either...so to save you the time of posting again that bang you still hear when you hit bumps will be cured by those parts |
Posted: Thu Jul 08, 2021 6:40 pm Post subject: Re: Rabbit ’78 identify these struts |
This car only has 50,000 miles on it so everything is in good condition, as you can see. Just that all the oil came out of the cylinders! But it was parked in my grandpa's machinery shed for 32 years so I'll let it go. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Thu Aug 05, 2021 7:05 am Post subject: Re: Rabbit ’78 identify these struts |
Just wanted to update you all, the little car is put back together and running well! No more dipping and knocking on bumps! handles much better. Thanks for the advice. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
oprn Samba Member
Joined: November 13, 2016 Posts: 12632 Location: Western Canada
Posted: Sun Aug 08, 2021 4:57 am Post subject: Re: Rabbit ’78 identify these struts |
Nice car! Not often you find a low mile older diesel. That one was still built in Germany by the was so fit, finish and the interior are much better than the later USA assembled ones.
Oh, and '78 was not the first year, '75 was. My Buddy had a '75 diesel 1.3 liter and I still have a '76 gas one. '78 was a good year though, it had some nice upgrades. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
vwoldbug Samba Member
Posted: Thu Dec 16, 2021 11:40 pm Post subject: Re: Rabbit ’78 identify these struts |
I know this is an old post but it still needs new bump stops unless you did change them. Good Luck |
