White smoke?
donald.lemay
donald.lemay is offline
PostPosted: Tue Jun 15, 2021 2:33 pm    Post subject: White smoke? Reply with quote
So I’m at the point where I have done my 20 min break in changed the oil put break in oil ( Brad Penn 30 weight break in oil) I’ve driven it probably 20 mi to get an inspection- now I have white smoke. Fortunately no noises should I proceed with my 100 mi break in?
Thanks
66 13 window deluxe
2085cc
9to1compression
ported polished heads 40x36 valves
010 distributor
VS 42mm exhaust
40 IDF carbs
busdaddy
busdaddy is offline
PostPosted: Tue Jun 15, 2021 2:43 pm    Post subject: Re: White smoke? Reply with quote
Are you babying it?, or driving it hard?, what brand of rings did you use?
Слава Україні!
donald.lemay
PostPosted: Tue Jun 15, 2021 2:47 pm    Post subject: Re: White smoke? Reply with quote
Yah didn’t do the hundred mile break in yet- but wasn’t smoking after 20 minute break in- deves rings
Thanks
66 13 window deluxe
2085cc
9to1compression
010 distributor
VS 42mm exhaust
40 IDF carbs
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Tue Jun 15, 2021 3:53 pm    Post subject: Re: White smoke? Reply with quote
… don't go over 50 mph for first 500 miles - drive your-baby, like a baby - z
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
donald.lemay
PostPosted: Tue Jun 15, 2021 3:57 pm    Post subject: Re: White smoke? Reply with quote
Like a baby Laughing but y no smoke then smoke
66 13 window deluxe
2085cc
9to1compression
010 distributor
VS 42mm exhaust
40 IDF carbs
busdaddy
busdaddy is offline
PostPosted: Tue Jun 15, 2021 4:00 pm    Post subject: Re: White smoke? Reply with quote
Wrong, drive it hard the first 10-20 miles, hard pulls (preferably up hills) followed by foot off the gas in gear decels (preferably down the other side of the hill) back down to a low speed, repeat, repeat, repeat.
donald.lemay wrote:
deves rings
Oh........., sorry to hear that. Crying or Very sad
https://www.thesamba.com/vw/forum/viewtopic.php?t=610525&highlight=deves
Слава Україні!
Clara Premium Member
Clara is offline
PostPosted: Tue Jun 15, 2021 4:04 pm    Post subject: Re: White smoke? Reply with quote
What I hear is keep changing the revs, as in drive on streets where you shift gears. Do rev it to a normal place where you'd shift up, then shift up.
Just don't stay at a constant rev for more than ~ 5 mins.
As in don't get on the freeway for more than an exit or two. Feel free to drive at normal cruising speed. Don't lug it.
I hear it can burn oil until the rings are 'set'. Burning oil means white smoke. So don't worry. Drive around until 300 miles, then adjust the valves and change the oil.
busdaddy
busdaddy is offline
PostPosted: Tue Jun 15, 2021 4:28 pm    Post subject: Re: White smoke? Reply with quote
Exactly, you have to force the rings against the cylinder walls followed by decels to pull some oil through and wash out the scrapings. Get out and drive it hard, if anything was going to let go it already would have, there's a chance you may still get those rings to seat with enough work.
Слава Україні!
Culito
11010101
Culito is offline
PostPosted: Tue Jun 15, 2021 8:38 pm    Post subject: Re: White smoke? Reply with quote
New build?
Sure it isn't just some paint burning off the exhaust?
Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
donald.lemay
PostPosted: Wed Jun 16, 2021 9:00 am    Post subject: Re: White smoke? Reply with quote
Thanks for the replies, funny you say condensation. When I started up I have water coming out of the pipe. My garage is cold when I take my bus outside it’s fogged up. I’m gonna go beat on it tonight. I’ll report back with my findings.
66 13 window deluxe
2085cc
9to1compression
010 distributor
VS 42mm exhaust
40 IDF carbs
don.ville Premium Member
Samba YardMan
don.ville is offline
PostPosted: Thu Jun 17, 2021 3:05 am    Post subject: Re: White smoke? Reply with quote
donald.lemay wrote:
... I’m gonna go beat on it tonight. I’ll report back with my findings.
Keep that to yourself man!!!
Be sure to drive the bus when you are done
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
donald.lemay
PostPosted: Sat Jun 19, 2021 9:52 am    Post subject: Re: White smoke? Reply with quote
Ok did my 100mi drive- smoke 💨 only lasted the first 5mi. then went away. She’s running smoke free and smooth now. Thanks for the replies
66 13 window deluxe
2085cc
9to1compression
010 distributor
VS 42mm exhaust
40 IDF carbs
busdaddy
busdaddy is offline
PostPosted: Sat Jun 19, 2021 10:49 am    Post subject: Re: White smoke? Reply with quote
Sweet!, now change the oil.
Слава Україні!
donald.lemay
PostPosted: Sun Jun 20, 2021 4:22 am    Post subject: Re: White smoke? Reply with quote
Oil change complete- running VR1 10-30 great - break in and first 100 abusive mi Brad’s Penn 30 break in oil.
66 13 window deluxe
2085cc
9to1compression
010 distributor
VS 42mm exhaust
40 IDF carbs
busdaddy
busdaddy is offline
PostPosted: Sun Jun 20, 2021 8:27 am    Post subject: Re: White smoke? Reply with quote
Excellent!, should be good to go now. Cool
Слава Україні!
donald.lemay
PostPosted: Thu Dec 30, 2021 2:16 pm    Post subject: Re: White smoke? Reply with quote
Just a follow up 1100 smoke free miles this season- I’m pretty stoked with this build.
66 13 window deluxe
2085cc
9to1compression
010 distributor
VS 42mm exhaust
40 IDF carbs
Bonesberg55
Bonesberg55 is offline
PostPosted: Thu Dec 30, 2021 4:18 pm    Post subject: Re: White smoke? Reply with quote
The rings should have no problem seating if the cylinders were round and properly honed.
