buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Fri Sep 17, 2021 5:34 pm Post subject: Re: More power please |
Paul.H wrote: |
madmike wrote: |
Ha,, had a tiny bit when I had a Weber Sidedraft
upgraded ,, no 'Lag' with a Holley 680 Quickfuel ,runs 11.85 @113mph(17 psi boost) and gets 26-28 mpg on Premium Pump gas,, I do spray water/meth(pissor juice) aka: windshield solvent |
Ah that's slow as f*** are you sure you had all the plug wires on ? |
What are you working with that makes an 11.80 slow?! Especially a street driven car on pump gas! |
Paul.H Samba Member
Posted: Fri Sep 17, 2021 6:16 pm Post subject: Re: More power please |
buguy wrote: |
Paul.H wrote: |
madmike wrote: |
First the meme gets taken seriously now this
It's just an old pit joke |
buguy Samba Member
Posted: Fri Sep 17, 2021 7:33 pm Post subject: Re: More power please |
Thank goodness! My wallet can't take too many more hits! |
StefansBus Samba Member
Joined: November 20, 2015 Posts: 242 Location: Germany
Posted: Fri Sep 17, 2021 11:43 pm Post subject: Re: More power please |
Paul.H wrote: |
First the meme gets taken seriously ... |
Just to be clear: I didn't really take the meme all that seriously but when you posted "can't argue with that" in response to the meme I felt the silly urge to post that yes, it could indeed be argued with. That's all. Meme or not, I think it would be just as funny but more factual it i read something like: Turbo lag, the brief moment when the other guy thinks he still has a chance... Or something like that. |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
challomoner Samba Member
Joined: October 13, 2010 Posts: 1216 Location: IRELAND
Posted: Sun Feb 06, 2022 3:05 am Post subject: Re: More power please |
UK Luke 72 wrote: |
What's the latest on this Baz?
Assume you've got it back together now? |
Hi Luke, haven't got the heads and manifolds back from torben yet so it's still gathering dust right now. 😐 |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7219 Location: Videbaek Denmark
Posted: Sun Feb 06, 2022 8:12 am Post subject: Re: More power please |
UK Luke 72 wrote: |
Exciting stuff.
What work has been done and what are the expected gains? |
Will wait and see once I have it back together but hopefully a worthwhile increase. |
Posted: Sun Apr 03, 2022 12:48 pm Post subject: Re: More power please |
Very close now to finding out how much we have gained
Intakes now 44mm. Ports straightened. Exhaust rockers switched to 1.25s. Intake manifolds greatly improved and correctly shaped. Cam advanced 2 degrees. Map sensor added.
Old dyno reading was 155hp, shooting for 170 now and better mid range. |
Posted: Sun Apr 10, 2022 8:57 am Post subject: Re: More power please |
Rocker side play is only thing left to do other than some more assembly, should be running next weekend 😁 |
Posted: Sun Apr 10, 2022 9:00 am Post subject: Re: More power please |
Nice work from torben on the heads
Posted: Mon Apr 11, 2022 1:02 pm Post subject: Re: More power please |
UK Luke 72 wrote: |
They look spicy
Look forward to results from this one. How do you imagine it should compare to the generic FK8/86b kinda builds with off the shelf heads? |
I really couldn't tell you as its my first and only hot engine. The aim was to get everything to work together as best we could, it wasn't a bad engine to begin with really but should definitely be quite a bit better now.
Stuff like the intake manifolds being corrected should help, the IE ratio will be closer to ideal with the 1.25s on exhausts. The porting work should help airspeed. Better ring seal with properly honed cylinders. So long as I get it tuned correctly it should be much nicer all over.
I should get to find out over the coming weekend 😁
Once it's up and running we're looking at building a better exhaust system that should help a little more. |
Posted: Mon Apr 11, 2022 11:03 pm Post subject: Re: More power please |
UK Luke 72 wrote: |
What exhaust do you have? |
Speedshop sidewinder |
Posted: Tue Apr 19, 2022 6:56 am Post subject: Re: More power please |
I think it's fair to say we have made some decent improvements, clutch won't hold above 4k in second or third. And it's still not fully tuned.
Near disaster has stopped play for a few days though, the oil pump to filter hose blew off the pump! I won't be using push lok fittings again. |
74 Thing Samba Member
Posted: Thu May 05, 2022 12:53 pm Post subject: Re: More power please |
Any updates on this engine?
Performance, how does it compare to the older version after putting some more mileage on it etc.. |
