Olli from NJ Samba Member
Posted: Wed Jun 16, 2021 6:50 am Post subject: Ghia lift points |
Can someone post pictures of a Ghia or Bug on a two post lift? I have a two post lift and would like to lift my Ghia. I figure the torsion bar housing in the rear but where in the front? The pan, towards the outboard side, roughly in front of where the door hinge post is? Pictures would help. I have been jacking and putting Ghias and Bugs on jackstands for 40 years but never raised one with a two post lift. Thanks. |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Wed Jun 16, 2021 7:16 am Post subject: Re: Ghia lift points |
Yes I can. Give an hour or so. I have my Bug up in the air currently.
The simple answer is basically along the rails under the heater channel. _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Wed Jun 16, 2021 7:32 am Post subject: Re: Ghia lift points |
agree...for the front also can use the frame head at outside points |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Wed Jun 16, 2021 7:34 am Post subject: Re: Ghia lift points |
On my lift I put the short arms under the caps for the torsion bars, long ends, I put the pads under the ends of the napolian hat bolts (nice flat spot on pan that wont fold over). Have a ghia on it now but wont be home for a couple hours to take picture _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Posted: Wed Jun 16, 2021 9:26 am Post subject: Re: Ghia lift points |
That would be awesome if you guys can post pictures later. Thank you! |
Teeroy Samba Member
Posted: Wed Jun 16, 2021 4:11 pm Post subject: Re: Ghia lift points |
Outstanding pictures! Thank you very much!
Olli |
