Rear heater valve
RBEmerson
RBEmerson is offline
PostPosted: Thu Jun 17, 2021 11:59 am    Post subject: Rear heater valve Reply with quote
Which direction is "no heat"? Bottom of the lever forward or toward the motor?
Lord, give me coffee to change the things I can change, and wine to accept the things I can't change.
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Thu Jun 17, 2021 12:15 pm    Post subject: Re: Rear heater valve Reply with quote
Pretty sure it is the forward location of the valve access "hole" in the cabinet, pushing it back lets the flow through. I have to dig in my back seat box later today, my PO wrote the directions on the top of the cover... If I find I have mislead you, I will edit this.
harvgwen
harvgwen is offline
PostPosted: Thu Jun 17, 2021 12:33 pm    Post subject: Re: Rear heater valve Reply with quote
Bobbyblack may be correct but my memory says the opposite.
1986 Westfalia Vanagon, 2.2 Subaru
British Columbia, Canada
PostPosted: Thu Jun 17, 2021 3:26 pm    Post subject: Re: Rear heater valve Reply with quote
Pic, on toward front, from PO's days
cmayna
cmayna is offline
PostPosted: Thu Jun 17, 2021 5:14 pm    Post subject: Re: Rear heater valve Reply with quote
Yes forward is on.
'90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig
RBEmerson
PostPosted: Thu Jun 17, 2021 6:56 pm    Post subject: Re: Rear heater valve Reply with quote
Thanks for checking. I'd do the obvious thing, run the engine, turn on the blower, and be enlightened. At the moment, our Westy's grounded while I do some "getting ready for the next road trip" projects.
jlrftype7
jlrftype7 is offline
PostPosted: Fri Jun 18, 2021 1:57 pm    Post subject: Re: Rear heater valve Reply with quote
I'm no help since I switched over to the GoWesty Valve version and never turn off the Rear Heater Core coolant flow. I could, probably should,,,, but I don't..... Razz Razz Wink Wink
‘84 Tin Top - Hilga....Auto
