rusty_74_bug Samba Member
Joined: November 22, 2019 Posts: 320 Location: Vancouver, WA
Posted: Thu Jun 17, 2021 12:02 pm Post subject: New SVDA no notch indicating cylinder #1 |
I'm finally switching over to an SVDA and trying to static time it but the new one has no notch indicating cylinder #1. I thought that other than the vacuum advance, it's essentially the same as a 009, which I'm familiar with. I can't get it to start, am I doing something wrong? _________________ '74 Standard Bug |
Paul Windisch Samba Member
Joined: September 02, 2009 Posts: 2546 Location: Clinton Township, Michigan
Posted: Thu Jun 17, 2021 12:08 pm Post subject: Re: New SVDA no notch indicating cylinder #1 |
The notch on a 009 is generally 90° off from a stock distributor.
In the end, it doesn't really matter. Set the engine at TDC of the compression stroke on cylinder #1. Wherever the rotor is pointing, that is cylinder #1. Then, follow the firing order for the rest of the plug wires. _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-L3 Heads 35x32 valves 52cc chambers
-0.040" deck for about 9.1:1 Compression
-Engle W110 cam
-CB Super Stock 1.1:1 Rockers
-Stock Heat Exchangers w/ Tri-Mil Muffler
-Dual Weber IDF 40s w/ 26mm venturis
-034 SVDA Distributor
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6
MAHLE Service Solutions
Applications Engineer |
Posted: Thu Jun 17, 2021 12:17 pm Post subject: Re: New SVDA no notch indicating cylinder #1 |
Paul Windisch wrote: |
In the end, it doesn't really matter. Set the engine at TDC of the compression stroke on cylinder #1. Wherever the rotor is pointing, that is cylinder #1. Then, follow the firing order for the rest of the plug wires. |
Thanks. Maybe I'm on the wrong stroke or I got the plug wires mixed up...wouldn't be the first time I'll keep trying. _________________ '74 Standard Bug |
Posted: Thu Jun 17, 2021 12:24 pm Post subject: Re: New SVDA no notch indicating cylinder #1 |
In general, if the distributor gear is in the proper position, and the distributor drive dog is on correctly, it will look like this:
1984 Mexican Beetle
-1914cc
-Engle W110 cam
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Thu Jun 17, 2021 12:53 pm Post subject: Re: New SVDA no notch indicating cylinder #1 |
THIS!
I always tell people to forget about the notch. Just make sure your on TDC #1 and see where the rotor is pointing. That's #1. Many times the distributor drive gear was not installed in the proper place and it changes the location of the terminals.
You can go and relocate the distributor drive gear, but it's not necessary. |
Posted: Thu Jun 17, 2021 1:58 pm Post subject: Re: New SVDA no notch indicating cylinder #1 |
Huh? I thought the firing order was 1-2-4-3? Your pic looks like 1-4-3-2..? _________________ '74 Standard Bug |
Posted: Thu Jun 17, 2021 2:31 pm Post subject: Re: New SVDA no notch indicating cylinder #1 |
It is indeed 1-4-3-2. It should be cast into the bottom of your generator stand, assuming it’s stock. _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-Engle W110 cam
Posted: Thu Jun 17, 2021 2:53 pm Post subject: Re: New SVDA no notch indicating cylinder #1 |
It is indeed 1-4-3-2. It should be cast into the bottom of your generator stand, assuming it’s stock. |
I wonder where the hell I got 1-2-4-3 from. _________________ '74 Standard Bug |
Posted: Thu Jun 17, 2021 3:59 pm Post subject: Re: New SVDA no notch indicating cylinder #1 |
I had to stop for the day but it appears I know what I did wrong. For some reason I was incorrect about the firing order. I'll take another crack at it this weekend but I'd bet that's what was wrong. Thanks for everyone's help! _________________ '74 Standard Bug |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15975 Location: North Florida, USA
Posted: Thu Jun 17, 2021 4:22 pm Post subject: Re: New SVDA no notch indicating cylinder #1 |
Pruneman99 wrote: |
Agree with the above.
Rotate the crank while watching the #1 cylinder rocker arms. When both #1 valves are closed AND the crank pulley shows TDC... you are at the end of the compression stroke for #1 cylinder. That cylinder is now expecting a spark. The distributor needs to be set up to deliver that spark to the #1 spark plug wire.
The other thing to consider with an SVDA/DVDA distributor is placement of the vacuum canister. The above pic shows the stock position for the vacuum canister. If your canister is somewhere else, now is the time to remove the distributor (if needed) and rotate the distributor body to get the canister in the correct (or close to correct position). Placing it as shown above will give you the best range of motion for adjusting the timing.
Next, set your point gap and static time the distributor. Add a paint mark or notch into the rim of the distributor where the rotor is pointing. You can use this mark going forward as a reference for where the #1 plug wire should be installed around the cap. Marking the cap with cylinder numbers is also good but you will loose these markings when you next change the cap. _________________ AshMan40
Posted: Thu Jun 17, 2021 5:42 pm Post subject: Re: New SVDA no notch indicating cylinder #1 |
The top center case stud is missing a nut as well. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Thu Jun 17, 2021 5:50 pm Post subject: Re: New SVDA no notch indicating cylinder #1 |
FYI, location of #1 on a German Bosch 0231 170 034
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Jun 18, 2021 5:51 am Post subject: Re: New SVDA no notch indicating cylinder #1 |
In Glenn's pic above, 034 is on the left, 009 is on the right.
And yes, that case stud was missing a nut.
I was originally going to mount the coil there, but didn't, and forgot to put the nut on. _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-Engle W110 cam
Marinablau703 Samba Member
Joined: January 09, 2021 Posts: 169 Location: Hudson Valley/LI, NY
Posted: Fri Jun 18, 2021 6:23 am Post subject: Re: New SVDA no notch indicating cylinder #1 |
rusty_74_bug wrote: |
I wonder where the hell I got 1-2-4-3 from. |
Turning the engine backwards as a shortcut for adjusting the valves, probably.
Firing order is also cast into the gen/alt pedestal. "Zundfolge." |
Glenn Mr. 010
Posted: Fri Jun 18, 2021 7:28 am Post subject: Re: New SVDA no notch indicating cylinder #1 |
Marinablau703 wrote: |
Backwards is 1-2-3-4 _________________ Glenn
Member #1009
#BlueSquare |
