napgonz Samba Member
Posted: Thu Jun 17, 2021 5:00 pm Post subject: 64 bug rear seat support bar/rail |
Hi all,
I've been trying to buy the rear seat support bar but seems like no one sells them new. Any other sources you guys know? I know they sell them used but I would really like to buy it new.
thank you!
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Fri Jun 18, 2021 4:23 am Post subject: Re: 64 bug rear seat support bar/rail |
https://www.thesamba.com/vw/classifieds/search.php...r+seat+bar
Try and find a VW wrecker in Ca. These are not hard to find. You just have to know where to look. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
downsbs1 Samba Member
Posted: Fri Jun 18, 2021 8:01 am Post subject: Re: 64 bug rear seat support bar/rail |
He's looking for a new one.
I don't know that I've seen anyone repopping these. |
Posted: Fri Jun 18, 2021 9:22 am Post subject: Re: 64 bug rear seat support bar/rail |
downsbs1 wrote: |
I get that. I have never seen a repop of the rear seat support bar. Hence the classifieds post. _________________ I have learned over the years.
Buy Once, Cry Once!
obnoxiousblue Samba Member
Joined: February 21, 2007 Posts: 2940 Location: East Northport, NY
Posted: Fri Jun 18, 2021 9:32 am Post subject: Re: 64 bug rear seat support bar/rail |
But used. Media blast and powder coat to your preferred color.
Haven’t seen anyone building new and I just finished putting my 64 back together. _________________ Mike
1964 Beetle
2001 Eurovan Camper |
Posted: Fri Jun 18, 2021 4:33 pm Post subject: Re: 64 bug rear seat support bar/rail |
thank you all for the feedback. Maybe the only option will be getting a used and sand and paint. |
lardawge Samba Member
Joined: October 05, 2020 Posts: 355 Location: California
Posted: Fri Jun 18, 2021 6:29 pm Post subject: Re: 64 bug rear seat support bar/rail |
What is the difference with these between years? _________________ 11/2/54 L227 Strato Silver Ragtop - Soon to be L41 Black - Build Thread
1/7/55 L275 Light Beige |
Posted: Sat Jun 19, 2021 6:23 pm Post subject: Re: 64 bug rear seat support bar/rail |
I don't really know, maybe none. I'm pretty new on the vw culture. I'm looking for a mechanic so I can learn but for now I'm ordering the "bugme" videos to get started on the most basic things. |
Posted: Sat Jun 25, 2022 7:01 pm Post subject: Re: 64 bug rear seat support bar/rail |
Hi all,
finally found it! All the way from Texas
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Tue Jun 28, 2022 7:14 am Post subject: Re: 64 bug rear seat support bar/rail |
made one out of angle iron from Lowe's _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Scott65Beetle Samba Member
Posted: Tue Jun 28, 2022 7:19 am Post subject: Re: 64 bug rear seat support bar/rail |
"bug Me" vids is how I started too. Very helpful. |
DesertG Samba Member
Posted: Sat Dec 17, 2022 3:48 pm Post subject: Re: 64 bug rear seat support bar/rail |
Hi Guys, are these rails supposed to have padding on them to protect the bottom edge of the vinyl seat? On the 65 I just bought, there is no padding and the vinyl is gouged and torn just on the bottom edge. Rest of seat is fine. _________________ 1965 Beetle, 1970 1600cc DP 60HP, 12v |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sat Dec 17, 2022 6:23 pm Post subject: Re: 64 bug rear seat support bar/rail |
DesertG wrote: |
Hi Guys, are these rails supposed to have padding on them to protect the bottom edge of the vinyl seat? On the 65 I just bought, there is no padding and the vinyl is gouged and torn just on the bottom edge. Rest of seat is fine. |
The only insulation is a strip of felt along the bottom of the channel, it can be seen clearly in the reference photo above.
It is common for the seat upholstery to get torn or cut along the bottom outer edges. This happens when the seat cushion is removed/installed for normal battery service/inspection. Stock the seat cushions can be a tight fit but they can get even worse if they use too much padding when the seat is reupholstered. Normally the damage gets hidden when the seat is back down in it's rest position. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
Posted: Sat Dec 17, 2022 6:25 pm Post subject: Re: 64 bug rear seat support bar/rail |
Thanks Bruce. I wish I could fix so it does not get worse. _________________ 1965 Beetle, 1970 1600cc DP 60HP, 12v |
Slow-N-Rusty Samba Member
Posted: Sat Dec 17, 2022 6:26 pm Post subject: Re: 64 bug rear seat support bar/rail |
My car had a strip of thin felt (or maybe jute?) padding. It was maybe 1/8" thick and ran the length of the rail. |
