marc_music_mich Samba Member
Joined: October 14, 2018 Posts: 65 Location: New Brunswick
Posted: Fri Jun 18, 2021 11:50 am Post subject: Wiring Harness |
I'm looking for a new complete wiring harness for my 1975 Bus (fuel injection). Anyone know where to find one? I saw this one on bus depot : https://www.busdepot.com/211971028l.
And this one from CIP one: https://www.cip1.ca/ProductDetails.asp?ProductCode=C17%2DWK%2D213%2D75%2D79
Anyone tried them?
I would prefer to find one that includes all the wiring for under the dash ( lights, radio, heater, etc...) and the "motor wiring" (FI, starter etc...) What would you recommend? I don't want to spend countless hours changing each wires one by one when I could just find a good harness that I can just unplug everything and start fresh.
The PO did all sort of repairs and changed wire colors, added plugs, kill switches, etc...and the bus right now is a mess (I can find at least 20 wires nots connected to anything). _________________ 75 Bay window Bus (Clementine)
New bus owner
Not a mechanic and trying to learn! |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12686 Location: on a bike ride somewhere
Posted: Fri Jun 18, 2021 12:21 pm Post subject: Re: Wiring Harness |
BusDepot’s harness “includes fuel injection but not ECU harness…”
Which one is it?? _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
mfemenel Samba Member
Joined: August 03, 2014 Posts: 273 Location: Matthews, NC
Posted: Fri Jun 18, 2021 12:34 pm Post subject: Re: Wiring Harness |
Ratwell lists this guy: http://kyleautomotivespecialties.com but he seems to only show 76 and up. Might be worth calling him. _________________ '79 Westy FI/AC/Auto
'78 Tin Top FI/Manual
'71 Ghia Coupe Project - FOR SALE! |
Posted: Fri Jun 18, 2021 1:02 pm Post subject: Re: Wiring Harness |
Kyle made a ‘75 for BigEmma, and we installed it last week. As always, it fits and works flawlessly.
Don’t forget the throttle position switch! Electric EGR is black, (OG was blue,) and don’t confuse it with an injector plug.
Posted: Mon Jun 21, 2021 3:41 am Post subject: Re: Wiring Harness |
airschooled wrote: |
Robbie |
Does His harness includes radio, lights, fuel gauge, speedometer etc...? Or only the basics to run the bus... _________________ 75 Bay window Bus (Clementine)
New bus owner
Posted: Mon Jun 21, 2021 4:57 am Post subject: Re: Wiring Harness |
Only the fuel injection. Those stock wires can be damaged from heat and vibration. The main chassis harness is so hard for manufacturers to replicate properly I’ve always repaired what’s there. Too many slight variations; if I have to spend four hours fixing its issues, I might as well spend four hours fixing the OG harness.
Posted: Mon Jun 21, 2021 5:07 am Post subject: Re: Wiring Harness |
Robbie |
I'm new to this.... What is OG harness? _________________ 75 Bay window Bus (Clementine)
New bus owner
Posted: Mon Jun 21, 2021 5:18 am Post subject: Re: Wiring Harness |
OG = original German. Parts built by folks who showed up to work in a good mood, constructed using the proper tools and supplies, and ruthlessly inspected by eagle-eyed engineers.
Most new parts today are built to quality standards undetectable by human technology. Kyle’s harnesses are an exception, and some of the best parts out there.
You will buy the same part twice to try to get a good one. New parts will break in your hand. They will be made in factories that don’t have rulers, let alone micrometers. You will pull your hair out a few times. Double your budget, then add a little more to be safe.
Start here to repair your existing wires:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...+terminals
Got the color wiring diagram for your car?
Posted: Mon Jun 21, 2021 5:28 am Post subject: Re: Wiring Harness |
Robbie |
Haha In like the "parts built by folks who showed up to work in a good mood" !!!
Thanks for the input. I will try to take a picture of the mess i'm in . The PO add kill switches, fixed some wires 2-3 times and did not take in consideration the colors so... A black wire can be black then red, then green then brown... What a mess! That's why I wanted to start from scratch.
I have the Bentley manual but I've seen somewhere a "real color" diagram (printed in color) to make my life a little easier. I don't want to mess everything up and end up to have to be stuck for 2 years at home either working on the van and not running it. the front dash is basicly a rats nest and I don't know where to start haha. _________________ 75 Bay window Bus (Clementine)
New bus owner
Posted: Mon Jun 21, 2021 6:27 am Post subject: Re: Wiring Harness |
I also have to change my Cyl head temp gauge. Looking at the Dakota Digital one. Should I buy the 1\2 inch ring terminal or the 14mm spark plug?... I'm planning on just putting it under the spark plug. (18' lenght) _________________ 75 Bay window Bus (Clementine)
New bus owner
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Mon Jun 21, 2021 7:54 am Post subject: Re: Wiring Harness |
just for clarity, away from the samba, OG= Original.
in this case, yes, it is original german, but an OG model T is origanal detroit. |
Jetfxr69 Samba Member
Joined: December 28, 2018 Posts: 1293 Location: White mtns nh
Posted: Mon Jun 21, 2021 8:34 am Post subject: Re: Wiring Harness |
alman72 wrote: |
And here I thought OG meant..Original Gangsta
Of course I live in the mountains and the closest thing to a gangsta I know is a pissed off bear when her cubs get too close to you. _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
‘72 tintop bastard westy Hudson |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Mon Jun 21, 2021 10:06 am Post subject: Re: Wiring Harness |
alman72 wrote: |
Only 12,000 T's were OG Detroit. The rest were OG Highland Park or other regional US and International plants. |
Posted: Mon Jun 21, 2021 10:56 am Post subject: Re: Wiring Harness |
those michiganders that dont actually live in the D, consider Highland park as the D. |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3547 Location: San Diego (Encinitas)
Posted: Mon Jun 21, 2021 2:44 pm Post subject: Re: Wiring Harness |
The Technical section of theSamba has bus schematics in color (even 1979), in JPG format that you can download and print. Some years even have highlighted versions for specific functions (headlights, turn signals, etc.) _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
