What am I missing - fresh air connection pipe (photos)
markeaton
markeaton is offline
PostPosted: Sat Jun 19, 2021 6:29 am    Post subject: What am I missing - fresh air connection pipe (photos) Reply with quote
All-
It's been awhile since I hooked one up. The connection pipe coupling will not seat into the top.
Both diameters are the same. Am I missing a part? Should I cut a piece of metal and fold over?
Thanks
Mark
karl h
karl h is offline
PostPosted: Sat Jun 19, 2021 7:24 am    Post subject: Re: WHat am I missing - fresh air connection pipe (photos) Reply with quote
if the parts are not both OG VW they might not fit
you can widen the lower part to fit the upper part into it, thats how it should fit
you are missing the rubber donut on the outside
61 panel: http://www.thesamba.com/vw/forum/viewtopic.php?t=465022
68 ghia vert
arctic alice (63 on irs): http://cal-look.no/lounge/index.php/topic,27456.0.html
86 Caravelle
04 new beetle vert
markeaton
PostPosted: Sat Jun 19, 2021 8:10 am    Post subject: Re: WHat am I missing - fresh air connection pipe (photos) Reply with quote
Thanks Karl.... I do have the rubber "donut" adapter....
Now you mention it, I think I do remember one of my last restores the lower section was cut...
Thanks again
von_hansel Premium Member
von_hansel is offline
PostPosted: Sat Jun 19, 2021 9:32 am    Post subject: Re: WHat am I missing - fresh air connection pipe (photos) Reply with quote
I had a similar issue. Use a rubber mallet and you should be able to get it in without cutting anything. Make sure to hit it evenly.
Good luck with the donuts. Once you tighten the fresh air boxes to the heater boxes, the donuts do not fit in the apron appropriately.
Mugatu wrote:
von_hansel is so hot right now
Eric&Barb
Eric&Barb is offline
PostPosted: Sat Jun 19, 2021 8:51 pm    Post subject: Re: What am I missing - fresh air connection pipe (photos) Reply with quote
Have used a Crescent wrench to carefully work around and around the heater bubble opening to work the hole a tad bit bigger so the pipe will tightly fit.
In Stereo, Where Available!
