72VWSB Samba Member
Joined: August 06, 2018 Posts: 707 Location: New Mexico
Posted: Sat Jun 19, 2021 6:29 am Post subject: Weber doors? |
Anyone know how to search the forum for Weber door installations? I've typed it in the search area but get nothing specific...it's like looking for a needle in a haystack! _________________ 72 VW Super Beetle |
72VWSB Samba Member
Posted: Sat Jun 19, 2021 6:48 am Post subject: Re: Weber doors? |
I did find a link on Samba...they used GAB FAB windows but it appears these are no longer available anywhere!? _________________ 72 VW Super Beetle |
Michael Ambrozik Samba Member
Joined: October 17, 2020 Posts: 631 Location: San Jose, CA
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sat Jun 19, 2021 9:17 am Post subject: Re: Weber doors? |
Same as the Limebug Hi-pacs. But direct from the manufacturer. And cheaper too!
https://www.hookyspanelshop.com/product/hipacs-high-performance-access-covers/ _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1669 Location: Niagara Region, CANADA
Posted: Sat Jun 19, 2021 10:03 am Post subject: Re: Weber doors? |
Weber windows??? |
Fiddlestyx Samba Member
Posted: Sat Jun 19, 2021 1:53 pm Post subject: Re: Weber doors? |
Dougy Dee wrote: |
Weber windows??? |
Appears to be a hole cut under the fender to facilitate reaching dual carb setups. _________________ 1983 Vanagon Westfalia Air-cooled
1973 Super Beetle |
Posted: Sat Jun 19, 2021 2:12 pm Post subject: Re: Weber doors? |
They are called access panels. See links I left |
72VWSB Samba Member
Posted: Sat Jun 19, 2021 3:32 pm Post subject: Re: Weber doors? |
Dougy Dee wrote: |
Weber windows??? |
I've heard them referred to weber doors or windows...lol _________________ 72 VW Super Beetle |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76941 Location: Sneaking up behind you
Posted: Sat Jun 19, 2021 3:34 pm Post subject: Re: Weber doors? |
I have IDAs and didn't need to cut up my wheel wells, so they must be an IDF issue. _________________ Glenn
Member #1009
#BlueSquare |
72VWSB Samba Member
Posted: Sat Jun 19, 2021 3:45 pm Post subject: Re: Weber doors? |
I ordered a set of these from England...they show them being installed from inside engine bay...I believe I will try to install them from fender side... _________________ 72 VW Super Beetle |
Paul Windisch Samba Member
Joined: September 02, 2009 Posts: 2546 Location: Clinton Township, Michigan
Posted: Sat Jun 19, 2021 5:09 pm Post subject: Re: Weber doors? |
Glenn wrote: |
I have IDAs and didn't need to cut up my wheel wells, so they must be an IDF issue. |
Yes, particularly the idle jets and mixture screws. They are difficult to get to while mounted in the car. Not impossible, but access panels make it much easier. _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-L3 Heads 35x32 valves 52cc chambers
-0.040" deck for about 9.1:1 Compression
-Engle W110 cam
-CB Super Stock 1.1:1 Rockers
-Stock Heat Exchangers w/ Tri-Mil Muffler
-Dual Weber IDF 40s w/ 26mm venturis
-034 SVDA Distributor
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6
MAHLE Service Solutions
Applications Engineer |
Igpoe Samba Member
Joined: February 24, 2019 Posts: 853 Location: South Boston, VA
Posted: Sat Jun 19, 2021 7:52 pm Post subject: Re: Weber doors? |
IMO the Gab-Fab are barely large enough, therefore must be positioned perfectly. _________________ '73 super. |
Tvättbjörn Samba Member
Posted: Sat Jun 19, 2021 9:52 pm Post subject: Re: Weber doors? |
Glenn wrote: |
Not really an IDF issue. Depends more on the type of manifold and the size of hands doing the adjustment. It is worse with a 911 or 915 transmission installed, because the engine will sit a little further back.
Easier to drill two 1" or slightly larger holes with a hole saw and install rubber plugs later on. |
Posted: Sun Jun 20, 2021 5:08 am Post subject: Re: Weber doors? |
The bigger doors/windows/access panels make it easier to get to the 'sparking bolts'... |
Glenn Mr. 010
Posted: Sun Jun 20, 2021 6:39 am Post subject: Re: Weber doors? |
Tvättbjörn wrote: |
Glenn wrote: |
Like this?
Member #1009
#BlueSquare |
Posted: Sun Jun 20, 2021 10:57 am Post subject: Re: Weber doors? |
Glenn wrote: |
Tvättbjörn wrote: |
Glenn wrote: |
Like this?
yes. Just needs flat rubber plugs to keep the street dirt out. |
72VWSB Samba Member
Posted: Mon Jun 21, 2021 9:58 am Post subject: Re: Weber doors? |
Tvättbjörn wrote: |
Glenn wrote: |
Tvättbjörn wrote: |
Glenn wrote: |
Like this?
Glenn, where are the holes you're talking about? I don't see any rubber plugs but this sounds like a much better idea than investing in the Access holes which is a problem with the engine still in the bay! How do you pinpoint the hole locations so they'll line up with each spark plug? I tried to get my had in there to even grasp the spark plug wire...NO WAY! I'd need a baby hand to get in there! _________________ 72 VW Super Beetle |
Posted: Mon Jun 21, 2021 3:43 pm Post subject: Re: Weber doors? |
The hole Glenn is talking about is for carb adjustment only. The spark plug/wire is completely different issue. That is what the access panel is for. |
Posted: Tue Jun 22, 2021 9:38 am Post subject: Re: Weber doors? |
72VWSB wrote: |
Tvättbjörn wrote: |
Glenn wrote: |
Tvättbjörn wrote: |
Glenn wrote: |
Like this?
Glenn, where are the holes you're talking about? I don't see any rubber plugs but this sounds like a much better idea than investing in the Access holes which is a problem with the engine still in the bay! How do you pinpoint the hole locations so they'll line up with each spark plug? I tried to get my had in there to even grasp the spark plug wire...NO WAY! I'd need a baby hand to get in there! |
The rubber plugs are not installed. You can see the carb adjusting screws. Best way - mark location with carbs installed - remove carbs and drill from inside out, You can do the same for your spark plugs if really needed
However, with the correct tool you will get the plugs out. Just a magnetic socket + short wobble extension and a flex ratchet. |
Glenn Mr. 010
Posted: Tue Jun 22, 2021 12:34 pm Post subject: Re: Weber doors? |
Michael Ambrozik wrote: |
No... the hole is to access #1 and #3 plug. Carb adjustments are done from the engine compartment. _________________ Glenn
Member #1009
#BlueSquare |
