Glenn Mr. 010
Joined: December 25, 2001 Posts: 76941 Location: Sneaking up behind you
Posted: Tue Jun 22, 2021 12:35 pm Post subject: Re: Weber doors? |
Tvättbjörn wrote: |
The rubber plugs are not installed. You can see the carb adjusting screws. Best way - mark location with carbs installed - remove carbs and drill from inside out, You can do the same for your spark plugs if really needed
However, with the correct tool you will get the plugs out. Just a magnetic socket + short wobble extension and a flex ratchet. |
I use the top wrench to get to the plugs.
_________________ Glenn
Member #1009
#BlueSquare |
Junkyardjockey Samba Member
Posted: Tue Nov 30, 2021 6:48 am Post subject: Re: Weber doors? |
But what about us with late supers with those shock bumper mounts? where are the access panels for that?? _________________ Romans 10:9-10
SAVE THE SUPERS!!
1974 Super Beetle Sunroof
2022 Subaru Outback Limited XT in crystal white pearl
2022 Subaru Outback Limited XT in cinnamon brown pearl |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2388 Location: Seekonk,Massachusetts USA
Posted: Tue Nov 30, 2021 6:53 pm Post subject: Re: Weber doors? |
Junkyardjockey wrote: |
But what about us with late supers with those shock bumper mounts? where are the access panels for that?? |
Did you see Glenn photo on page 1?? 74-79 same rear shock mounts. _________________ Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan |
Glenn Mr. 010
Posted: Tue Nov 30, 2021 7:00 pm Post subject: Re: Weber doors? |
Actually the 1.5" holes are for accessing #1 and #3 spark plugs, #2 and #4 can be accessed from inside the engine compartment.
Currently I have Weber IDAs and the adjustment screws are on a 45* angle and I can get a long screwdriver on them from the top and between the inside of the fender well and the carb. Previously, I had Dellortos and drilled a few small holes so I can run a screwdriver in from under the fender to the screws... I have since welded them shut since I no longer need them. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Nov 30, 2021 7:22 pm Post subject: Re: Weber doors? |
APPLEGREENVW wrote: |
Did you see Glenn photo on page 1?? 74-79 same rear shock mounts. |
I saw some holes sir, but they looked pre existing. I didn't see any other that would allow access to the plugs. Unless they were hidden or I didn't see them.... _________________ Romans 10:9-10
SAVE THE SUPERS!!
Glenn Mr. 010
Posted: Tue Nov 30, 2021 7:26 pm Post subject: Re: Weber doors? |
I saw some holes sir, but they looked pre existing. I didn't see any other that would allow access to the plugs. Unless they were hidden or I didn't see them.... |
Big round hole in the middle.
Member #1009
#BlueSquare |
Posted: Tue Nov 30, 2021 7:28 pm Post subject: Re: Weber doors? |
Glenn wrote: |
that hole just above where that blue wire goes across the inner fender? _________________ Romans 10:9-10
SAVE THE SUPERS!!
Glenn Mr. 010
Posted: Tue Nov 30, 2021 7:33 pm Post subject: Re: Weber doors? |
Glenn wrote: |
that hole just above where that blue wire goes across the inner fender? |
yes, a straight shot at the spark plug. _________________ Glenn
Member #1009
#BlueSquare |
virusdoc Samba Member
Joined: August 13, 2018 Posts: 525 Location: Durham, NC, USA
Posted: Wed Dec 01, 2021 12:49 pm Post subject: Re: Weber doors? |
Cut them above the bumper mount and make your own covers out of sheet steel (or aluminum) like mine:
_________________ 1976 Convertible Super Beetle, "June Bug".
FI-->34PICT3 carb conversion-->now dual 40 IDFs
Self-rebuilt 1904 (after totally botching a 1641 rebuild, cussing a lot, and throwing lots of cash in the fire) |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Wed Dec 01, 2021 2:03 pm Post subject: Re: Weber doors? |
virusdoc wrote: |
I made a cover similar to this (but not as good looking) in mid-1970s to access the #3 and #4 spark plugs on my 1835cc DP engine which had the dealer-installed DPD air conditioning. Mine removed from under the fender though. Back in those days with leaded gasoline, the spark plugs needed to be changed way more often. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
