vanis13 Samba Member
Joined: August 15, 2010 Posts: 3101 Location: ABQ NM USA.... Except when not
Posted: Sat Jun 19, 2021 8:35 am Post subject: Bad front wheel bearing? play even after tightening. |
Wondering what else to check before committing to a wheel bearing replacement.
Tightened wheel bearing.
replaced upper ball joint (tested fine but boot was cracked and part was under warranty)
lower ball joint shows no play (OEM it seems)
after that still play.
tested with helper moving wheel at 12/6 and determined there is play between the rotor and the spindle/ball joint assembly.
can retighten since I have the Mercedes nut but I've very sure I got it right.
https://www.thesamba.com/vw/forum/viewtopic.php?t=755355&highlight=mercedes
Anything else to check? _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9620 Location: Western WA
Posted: Sat Jun 19, 2021 8:40 am Post subject: Re: Bad front wheel bearing? play even after tightening. |
Yikes if the nut doesn't take up the slop directly, immediately....
you gotta look inside before driving it.
Sounds like a worn out spindle 🙀 _________________
....KTMs, GasGas, SPOT mtb |
Posted: Sat Jun 19, 2021 10:58 am Post subject: Re: Bad front wheel bearing? play even after tightening. |
well, considering it could be really bad, I looked again at the tightness of the spindle nut and here is what I did - using the original pitted nut I tightened it until it was tight to seat the bearing and what ever else might be in there. Of course the rotor didn't turn. I took off that nut and put the Mercedes nut back on and put it on snug which was about 1/8 turn more than the last tightening. the play is gone. I'll monitor wheel/spindle/bearing temperature as I drive it in the next few days. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
old_man Samba Member
Joined: June 19, 2018 Posts: 1382 Location: Newfoundland
Posted: Sat Jun 19, 2021 12:00 pm Post subject: Re: Bad front wheel bearing? play even after tightening. |
I have to ask, are you spinning the wheel as you are tightening the nut? |
Posted: Sat Jun 19, 2021 12:14 pm Post subject: Re: Bad front wheel bearing? play even after tightening. |
yes, for the final tightening. the "set" tightening I mentioned above, the wheel didn't ultimately turn....then I loosed up and spun/tightened. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
the joker Samba Member
Posted: Sat Jun 19, 2021 12:39 pm Post subject: Re: Bad front wheel bearing? play even after tightening. |
You should be able to move the "washer" with slight side pressure( screwdriver) and roll with a good push. |
Posted: Sat Jun 19, 2021 1:21 pm Post subject: Re: Bad front wheel bearing? play even after tightening. |
With everything cold you want to have a very slight bit of wobble in the tire. If after 20 miles of highway driving on a hot day the play is gone then that may well be okay. If the bearing it too tight it will run noticeable hotter, so compare hub temperatures side to side and front to back.
The washers that go under the nut are not very uniform in thickness across their surface and this can throw the feel off when adjusting the nut. I will sometimes adjust the nut while the wheel is on the ground as this seems to help make up for the discrepancies in the surface of the washers.
If you tightened the nut so tight your couldn't spin the wheel, I would be worried you might have harmed the bearings. |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4800 Location: Bemidji, MN
Posted: Sat Jun 19, 2021 2:41 pm Post subject: Re: Bad front wheel bearing? play even after tightening. |
the Mercedes nut has a very flat thrust surface and Mercedes does NOT use a washer between the nut and bearing race.
i left it out on mine. _________________ -dan
www.thefixitworkshop.com |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32638 Location: Reading Pennsylvania
