knewknew Samba Member
Joined: July 06, 2007 Posts: 217 Location: Alexandria, VA
Posted: Sat Jun 19, 2021 3:40 pm Post subject: 914 Fuchs Rims - Original Finish? How to restore? |
Hi all,
I am looking for a set of 914 Fuchs (4 lug) for my '70 Squareback (Type 3). I have seen a number of photos from sellers and it is hard to understand what the stock finish is. I am referring to the all aluminum version that appears to be matte with shiny raised surface.
Are the raised 'spokes' polished? and the rest is raw/cast aluminum? Is any part anodized or painted?
Second question: how should you go about restoring them? Is it as simple as sand blasting them clean and then rebuffing the top section?
Many thanks! _________________ 1970 Squareback
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76889 Location: Sneaking up behind you
Posted: Sat Jun 19, 2021 3:45 pm Post subject: Re: 914 Fuchs Rims - Original Finish? How to restore? |
They are anodized.
Don't forget the correct bolts. Many use the incorrect watercooled lug bolts that have a tapper. The correct have a ball seat like these.
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Jun 19, 2021 9:32 pm Post subject: Re: 914 Fuchs Rims - Original Finish? How to restore? |
Thanks for the tip about the lugs!
Still curious about the finish. Is the top surface polished after being anodized? It’s not very apparent in your photo, but I have seen some that seem to have two different sheens. _________________ 1970 Squareback |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21510 Location: Oklahoma City
Posted: Tue Jun 22, 2021 11:11 am Post subject: Re: 914 Fuchs Rims - Original Finish? How to restore? |
knewknew wrote: |
Still curious about the finish. Is the top surface polished after being anodized? It’s not very apparent in your photo, but I have seen some that seem to have two different sheens. |
Most likely the whole surface is first polished, the top areas are then masked with a peel-able mask...then the whole rim is pre-etched (which you have to do with anodizing)....then anodized.
Yes...anodizing "can" be polished away....but anodizing is harder than the aluminum its on.
If I had to do a bunch or these....I would put the rims in a vibratory polisher and walk away for a day. Then a simple spray stencil to cover the polished areas you want to keep and just spritz on the peel-able mask.
A few minutes in the sodium hydroxide pre-etch...then into the anodizing tank. A couple minutes to peel the mask and you are done.
Ray |
Posted: Wed Jun 23, 2021 5:40 am Post subject: Re: 914 Fuchs Rims - Original Finish? How to restore? |
raygreenwood wrote: |
Thanks Ray, that makes better sense to me now!
When researching ball lugs, I saw a video that explained they come in 3 different radius sizes: #12 #13 and #14
However, most retailers list only the thread diameter and pitch.
Is it general knowledge that all VW/Porsche ball sockets are the same size? Vintage and modern? I'd hate to get the wrong type and booger it up. _________________ 1970 Squareback |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Wed Jun 23, 2021 8:28 pm Post subject: Re: 914 Fuchs Rims - Original Finish? How to restore? |
Sand blasting is too harsh. Why not just get them totally polished? The can be buffed to look like chrome. I've done some by hand but takes 6 hrs per wheel - wet sanding and buffing with jewelers rouge. _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
Joined: December 28, 2016 Posts: 279 Location: atlanta ga
Posted: Fri Jul 02, 2021 9:01 am Post subject: Re: 914 Fuchs Rims - Original Finish? How to restore? |
send to al reed in california for him to re anodize He does marvelous work |
pdm777 Samba Member
Joined: August 06, 2012 Posts: 348 Location: Clovis, CA
Posted: Fri Nov 26, 2021 12:47 am Post subject: Re: 914 Fuchs Rims - Original Finish? How to restore? |
Google:
restoring Porsche Fuchs wheels
1968-1989 _________________ 1990 Westy Full Camper |
