The Volkswagen Ranch Samba Member
Joined: November 24, 2002 Posts: 703 Location: Arizona
Posted: Sun Jun 20, 2021 1:31 pm Post subject: Hubcap dilema |
So.... 1976 Westy, stock wheels. Just sandblasted and powder coated. Existing hubcaps dented, all have significant rust on the inside. Decided to” take the plunge” and replace with new. First set of replacements from WW too deep on the outer lip, second ( only had 2) outer lip too shallow. So , trying a couple from Airhead, ordered Friday. Never ran across this problem before. Anybody else have success?
First pic: the existing caps, fit fine
Second pic: existing cap on left, WW cap too shallow lip on rightj
_________________ 1963 Convertible (Lizzie) and 1964 Convertible (Patience) 1976 Westfalia (Winnie) |
Posted: Sun Jun 20, 2021 1:39 pm Post subject: Re: Hubcap dilema |
And the WW cap that has too tall an outside lip
It may look in the pics that the tape measure tip was not at the same measuring position, but believe me it was! Thanks, Bob _________________ 1963 Convertible (Lizzie) and 1964 Convertible (Patience) 1976 Westfalia (Winnie) |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jun 20, 2021 2:22 pm Post subject: Re: Hubcap dilema |
A 76 should use the fat lip caps, they changed from the thin ones sometime in 73. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Jun 20, 2021 2:40 pm Post subject: Re: Hubcap dilema |
So... the WW caps with the deep lip should work even though the lip is deeper than what is on there? I did not want to “ force” the cap on. It just did not want to pop on when I gave it a good hit my fist.... on the edge of the cap of course. I did not use a dremel to clean the powder coat off the nubs on the wheel, or coat them with grease either..... yet. Let me know, and thanks again! Here we are again this summer 18 miles away from a major forest fire in AZ, the “Backbone”fire. Putting the Westy back together the best I can, as we may need to evacuate this time, and wife takes the Odyssey, packed, I take the Westy with the dogs. _________________ 1963 Convertible (Lizzie) and 1964 Convertible (Patience) 1976 Westfalia (Winnie) |
Posted: Sun Jun 20, 2021 5:18 pm Post subject: Re: Hubcap dilema |
The width of the edge should not matter, it's the small rolled lip around the inside that grabs the wheel, the rest is just along for the ride, if the ID is the same it'll work.
Fingers crossed for you and that fire, sounds like it's getting too close for comfort. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Sun Jun 20, 2021 7:39 pm Post subject: Re: Hubcap dilema |
some places sell the late 251 hubcaps. They have a deeper profile than the bay ones. I believe early Vanagons is when they were first used. I haven't seen a near original new bay hubcap since around 2005. There is a place in Salt Lake City that can re-chrome the old ones if they aren't too bad.
http://saltlakechrome.com/ _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Tue Jun 22, 2021 12:36 pm Post subject: Re: Hubcap dilema |
I have a set of surplus, genuine VW Type 2 chromium-plated hubcaps that were bought for our 1973 VW Type 2 campervan that were used for only one season (hard to remove when regularly checking wheel-nut torque! ) and then put in storage more than thirty years ago. _________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
Posted: Tue Jun 22, 2021 10:53 pm Post subject: Re: Hubcap dilema |
Nigel.... OMG... keep them close! About as rare as you can get! If you could, please take a pic of the rim of one of them showing the two holes for removing the hubcap. I don’t know for sure what year hubcaps I have. Two were painted silver on the inside at some time, the other two are just covered inside with surface rust. They are the same depth, but were very hard to remove when I had the wheels blasted and then powder coated. The PO had just used some brand of silver paint on them ( a lot of paint). I assumed the caps were hard to remove due to the thick paint. BIG screwdriver used to remove them. Broke my hubcap puller tool trying to get the first one off. Thank you, Bob _________________ 1963 Convertible (Lizzie) and 1964 Convertible (Patience) 1976 Westfalia (Winnie) |
Posted: Wed Jun 23, 2021 10:45 am Post subject: Re: Hubcap dilema |
NASkeet wrote: |
I have a set of surplus, genuine VW Type 2 chromium-plated hubcaps that were bought for our 1973 VW Type 2 campervan that were used for only one season (hard to remove when regularly checking wheel-nut torque! ) and then put in storage more than thirty years ago. |
The Volkswagen Ranch wrote: |
If you could, please take a pic of the rim of one of them showing the two holes for removing the hubcap. I don’t know for sure what year hubcaps I have. Two were painted silver on the inside at some time, the other two are just covered inside with surface rust. They are the same depth, but were very hard to remove when I had the wheels blasted and then powder coated. The PO had just used some brand of silver paint on them ( a lot of paint). I assumed the caps were hard to remove due to the thick paint. BIG screwdriver used to remove them. Broke my hubcap puller tool trying to get the first one off. Thank you, Bob |
First I need to find them in my garage, which is about 3 miles from my present place of residence.
Then I shall have to see whether any of my friends (not in self-imposed COVID-19 isolation) has a means of taking digital photographs that they can e-mail to me.
I cannot precisely date the hub caps, but I am reasonably sure they were bought during the latter half of the 1970s; so at least 40 years old! I think I might also have a spare genuine VW Type 2 hub-cap removal tool (i.e. horseshoe shaped with hooked ends).
Looking at your two pictures, I am confident that my set of four hubcaps are of the same variety as illustrated in your first picture and the left-hand one in your second picture.
My long-term plan is to substitute Mercedes C-Class 7 x 16 inch alloy wheels and either 205/65 R16C or 215/65 R16C commercial-van tyres which have virtually been the de facto standard here for medium-sized commercial vans, for about the past 10~15 years. There is a plethora of tyre brands available in these sizes at very competative prices. _________________ Regards.
Nigel A. Skeet
Posted: Fri Jun 25, 2021 4:16 pm Post subject: Re: Hubcap dilema- SOLVED |
Airhead has the correct hubcaps. They “snap” on tight they way they should.They feel about the same weight as my ( for sure) 1 OEM CAP. Chrome is not the best , but not bad either. Good compromise. Bob
L _________________ 1963 Convertible (Lizzie) and 1964 Convertible (Patience) 1976 Westfalia (Winnie) |
Posted: Mon Jun 28, 2021 11:00 am Post subject: Re: Hubcap dilema |
I am pleased to report that I succeeded in finding the set of four chromium-plated, 1971~79 VW Type 2 hubcaps in my garage. When they were put into storage, we coated them with Finnigan’s Waxoyl under-body rust-inhibiting wax treatment (I also injected this with a spray lance into all of the 1973 VW “1600” Type 2 Westfalia Continental motor-caravan’s body cavities), to preserve them as well as possible. Being wax coated, they have gathered dust over the years, so I first need to clean at least one of them, to find out what condition they are in. _________________ Regards.
Nigel A. Skeet
