sb001 Samba Member
Joined: May 19, 2011 Posts: 10399 Location: NW Arkansas
Posted: Mon Jun 21, 2021 12:43 pm Post subject: Re: Car started pinging... |
Starbucket wrote: |
Remove the fuel pump and put a piece of fuel hose on both ports and fill the hoses with gas and watch for dripping. |
Will do thx for the idea! _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
kpf Samba Member
Joined: March 01, 2017 Posts: 847 Location: California, US
Posted: Mon Jun 21, 2021 1:01 pm Post subject: Re: Car started pinging... |
I'm not convinced that low fuel pump output pressure can cause pinging in these cars. I've run out of fuel before, and the engine ran great until it just quit. The fuel pump output pressure is not involved in metering fuel into the carburetor. The metering is controlled by the relationship between the air pressure in the bowl and the venturi.
I would think that pinging would be primarily caused by overly-advanced timing, or overheating. Did you change your spark plugs before this started (maybe they are the wrong heat range)? _________________ 1971 Super Beetle |
sb001 Samba Member
Posted: Mon Jun 21, 2021 2:40 pm Post subject: Re: Car started pinging... |
kpf wrote: |
I would think that pinging would be primarily caused by overly-advanced timing, or overheating. Did you change your spark plugs before this started (maybe they are the wrong heat range)? |
I didn't just change the plugs but they are new within the last 3 years or so- but as I stated earlier the pinging just suddenly started while I was driving, like literally something just became out of whack. I haven't messed with timing or anything. It could be that the plugs are somehow wrong but they are the same Bosch plugs I've used for decades. I guess it's possible my timing slipped, I'll check it again when I get a chance but TBH the delicate balance between carb and timing adjustment on this car has always thrown me for a loop, it's almost impossible to get everything dead on and have it stay that way for any kind of time. _________________ I'm the humblest guy on this board.
1600 SP engine
Starbucket Samba Member
Posted: Mon Jun 21, 2021 4:48 pm Post subject: Re: Car started pinging... |
If you just gassed up you could have got the bottom of the tank and water could be in the tank, remove the top of carb and look for water if nothing else fixes it. |
Zundfolge1432 Samba Member
Posted: Mon Jun 21, 2021 7:37 pm Post subject: Re: Car started pinging... |
Once you hear detonation the damage is occurring and if you keep driving the engine will self destruct. One sure sign right before all hell breaks loose is tight valves and from there the danger of burnt exhaust valve, usually #3 exhaust.
As stated detonation ruin bearings.
It’s a slippery slope for sure. I would not keep driving it. Not trying to be alarmist. I’ve seen the end result it’s not good. |
sb001 Samba Member
Posted: Mon Jun 21, 2021 8:19 pm Post subject: Re: Car started pinging... |
Zundfolge1432 wrote: |
Thanks for the advice, just sent u a PM _________________ I'm the humblest guy on this board.
1600 SP engine
