BFB Samba Member
Posted: Sun Jun 20, 2021 7:42 pm Post subject: plug gap and timing? |
i read somewhere sometime back that plug gap could affect timing or maybe it was talking about dwell?
anyhow, im actually working on a small engine and wondered if plug gap could vary the timing any? _________________ Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1 |
jim martin Samba Member
Joined: January 14, 2004 Posts: 205 Location: Vancouver, BC
Posted: Mon Jun 21, 2021 6:29 am Post subject: Re: plug gap and timing? |
No ,I would not worry about it .
It will not effect anything you will notice
Run the gap at factory give or take a few .001’s regardless of ignition
Brand . Your cap and rotor will last longer _________________ B.C's fastest street legal vw , June 2006 Hot VW's feature car 9.81 sec at 145.26mph.
Sponsored by :
LUCAS OIL PRODUCTS http://www.lucasoil.com
KROC head porting services
Dialedinperformance.com
Airspeedparts.com topic http://airspeedparts.com/forums/index.php?topic=914.0 |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5593 Location: 37.5N 77.1W
Posted: Mon Jun 21, 2021 8:16 am Post subject: Re: plug gap and timing? |
Quote: |
read somewhere sometime back that plug gap could affect timing or maybe it was talking about dwell? |
Dwell is a measure of how many degrees the points are closed. Dwell can be measured on a distributor without even having spark plugs or ignition wires attached. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
