pushkick Samba Member
Posted: Mon Jun 21, 2021 2:09 pm Post subject: Brake light issue |
Does anyone know where the brake light switches
Are physically located ? Are they up in the dash? Can they be accessed without pulling dash? Do i have to remove instrument cluster? Any help is appreciated. 1990 vanagon camper. _________________ i see said the blind man to his deaf dog
i am going to quit smoking and drinking and die a healthy man. gotta laugh
there is no deed to the planet earth
1990 vw automatic camper |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9776 Location: Mt Lemmon, AZ
Posted: Mon Jun 21, 2021 4:10 pm Post subject: Re: Brake light issue |
No need to pull the dash but you'll want to get the dash pod out of the way. This will require disconnecting the speedo cable and the plugs on the backs of some switches. Mine is an 84 but I think the task is quite similar on yours:
Rear one is easy enough but the forward one will needs a combination of a socket, extension, and possibly a wobbly or a U-joint.
Sorry, do not recall the size - metric of course but as I recall there is an SAE size that is pretty close. |
Posted: Mon Jun 21, 2021 8:38 pm Post subject: Re: Brake light issue |
Thanks that really helps! Do i have to worry about brake fluid leaking out when i remove switchs? _________________ i see said the blind man to his deaf dog
Abscate Samba Member
Joined: October 05, 2014 Posts: 22568 Location: NYC/Upstate/ROW
Posted: Mon Jun 21, 2021 11:20 pm Post subject: Re: Brake light issue |
pushkick wrote: |
Thanks that really helps! Do i have to worry about brake fluid leaking out when i remove switchs? |
you don’t have to worry about it but it will run out all over.
😃 _________________ .ssS! |
Posted: Mon Jun 21, 2021 11:40 pm Post subject: Re: Brake light issue |
I would drain the reservoir before removing the switch to reduce the volume of brake fluid that can be lost. Note that there are two switches so if one switch is bad you should still have functioning brake lights so you might want to look elsewhere for your problem. |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3082 Location: ABQ NM USA.... Except when not
Posted: Tue Jun 22, 2021 3:06 am Post subject: Re: Brake light issue |
Abscate wrote: |
pushkick wrote: |
Hehe, true and doesn't have to be a problem.
I've replaced both w.o having to rebleed. Do them separately. Have replacement switch ready. Top off reservoir (above full of ok since you will lose some) Loosen up w.wrench then switch to fingers. Just as the old switch comes out, put finger over hole. Move finger right before inserting new switch. Wipe up spilt fluid.
Notes -
On mine for the rear it helped to remove the fuse box mounting plate. The two big silver screws.
Do NOT over tighten. Too tight is NOT better. You can crack the master cylinder. The threads are tapered to create the seal so it creates an increasing force and will split the master. At least now you have an idea where to look if this happens. Ask me how I know sometimes if replacements didn't have thread sealer I use a couple wraps of Teflon tape to ensure leak free and smooth tightening with lighter tightening torque. Not sure of compatibility but it never caused a leak for me
Consider buying switches from national FLAPS with lifetime warranty. They may go out after a few years and it's nice to have a quick replacement handy w.o shipping wait and cost for the extra $2 to buy local. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Tue Jun 22, 2021 11:26 am Post subject: Re: Brake light issue |
vanis13 wrote: |
...I've replaced both w.o having to rebleed. Do them separately. Have replacement switch ready. Top off reservoir (above full of ok since you will lose some) Loosen up w.wrench then switch to fingers. Just as the old switch comes out, put finger over hole. Move finger right before inserting new switch. Wipe up spilt fluid... |
Me too. Helps a bit to remove the cap on the reservoir, put a piece of plastic (Saran) wrap over the opening then screw the cap back on. That defeats the air vent in the cap and slows the fluid leak even more. |
markf1 Samba Member
Joined: September 21, 2019 Posts: 286 Location: Telluride, Colorado
Posted: Tue Jun 22, 2021 8:39 pm Post subject: Re: Brake light issue |
Our brake lights stopped working. I planned to replace both switches. Could only get the front one loose to replace. That fixed the problem. Very little fluid leaked out during the replace.
Hope this may be helpful to you" _________________ 1986 Westfalia Syncro
2.1 L Waterboxer
Some Westy supported adventure photos:
https://www.openrangeimaging.com/adventure.html |
Posted: Wed Jun 23, 2021 10:32 am Post subject: Re: Brake light issue |
markf1 wrote: |
...Could only get the front one loose to replace. That fixed the problem... |
Yes, as I recall you only lose brake lights once both pressure switches have failed.
But isn't there a warning light that indicates that one has failed? |
Posted: Wed Jun 23, 2021 10:52 am Post subject: Re: Brake light issue |
Thanks to everyone for their help. Just wondering why vw didnt just put one switch and why not a proximity on brake pedal arm instead of master cylinder. _________________ i see said the blind man to his deaf dog
Posted: Wed Jun 23, 2021 12:36 pm Post subject: Re: Brake light issue |
pushkick wrote: |
Thanks to everyone for their help. Just wondering why vw didnt just put one switch and why not a proximity on brake pedal arm instead of master cylinder. |
Two brake circuits, two switches. The design dates back many decades and is actually pretty ingenious as the engineers didn't have to design a new bracket for the brake light switch with every new design of the car body. In 45 years of driving VWs and somewhere around 1.5 million miles I have never had to deal with one on my own VW's, knock on wood. |
