PaulyPaul Samba Member
Joined: August 05, 2005 Posts: 158 Location: Sunny North Norfolk
Posted: Mon Jun 21, 2021 2:38 pm Post subject: Cb rotary fuel pump issue |
Hi Guys,
Its been a few years since I've posted on here as I've been out of the scene for quite some time. During that time, our bus, a '63, 11 window running a Laurie Petitte built 1955cc has been sat idle in the garage.
I have started it occasionally over the last few years but not taken it out on the road. However, last weekend I thought its time to get the bus out and recommissioned.
Unfortunately I couldn't get it started and I've got an idea that stale fuel has gunked up the cb performance electric rotary fuel pump as I'm not getting fuel to the 40 idf's?
My question is: Is there any way I can get the pump working or, is the fact that its not pumping mean I have to replace it?
Thanks,
Paul _________________ Featured in Jan 09 VW Camper and Commercial....does that add value? |
QRP Samba Member
Joined: April 27, 2008 Posts: 1712 Location: NORTH HOLLYWOOD,CA
Posted: Mon Jun 21, 2021 2:52 pm Post subject: Re: Cb rotary fuel pump issue |
I'll ask the obvious silly question, is there fuel in the tank? |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Mon Jun 21, 2021 2:55 pm Post subject: Re: Cb rotary fuel pump issue |
I experienced this once, and was in a situation/location where I had no tools to to do any disassembly. I kept cycling the ignition on/off, and it eventually started pumping again. Maybe try that.
If that doesn’t work, try taking the pump off, draining the old fuel out of it, and flushing it with fresh fuel with the feed/pump hoses in a small gas can. Create some jumper wires with terminals you can bolt on, and try to get the pump running again. Just be careful of any wire arcing near the fuel source. |
Posted: Mon Jun 21, 2021 3:18 pm Post subject: Re: Cb rotary fuel pump issue |
Thanks fellas, yes there is fuel in the tank so I'll try the disassembly option to start with as I've turned it over already for quite some time to no avail. Fingers crossed. _________________ Featured in Jan 09 VW Camper and Commercial....does that add value? |
Lawlessjr Samba Member
Joined: December 03, 2009 Posts: 60 Location: Visalia, CA
Posted: Mon Jun 21, 2021 3:26 pm Post subject: Re: Cb rotary fuel pump issue |
Also try reversing the polarity on the wires and run it backwards for a few seconds. Then flip the wires back. Sometimes this will clear them up as well. |
