Keagan07 Samba Member
Joined: April 04, 2013 Posts: 71 Location: Savannah, Ga
Posted: Mon Jun 21, 2021 7:50 pm Post subject: No spark, chipped distributor shaft |
Hello all,
It's been awhile since my last online presence.
Recently I've put a lot of work into my '71 bus and cleaned up the engine and some wiring to get it ready for the road.
Put in a new coil, tried two different working ones
Installed new electronic ignition module
Replaced the battery (reading 12.4v)
Checked wires for voltage and continuity
Replaced rotor and cap for distributor
Cleaned fuel tank and replaced fuel and filter, fuel is pumping through.
It will turn over perfectly but will not start or get any spark. _________________ '71 Westy, "Leo"
Posted: Mon Jun 21, 2021 7:55 pm Post subject: Re: No spark, chipped distributor shaft |
I took out the distributor and found this. The shaft spins when being turned over. Could this have something to due with the "no spark" issue?
[/img] _________________ '71 Westy, "Leo" |
ImAddicted Samba Member
Joined: April 24, 2012 Posts: 1195 Location: Unorganized Territory, Maine
Posted: Mon Jun 21, 2021 8:02 pm Post subject: Re: No spark, chipped distributor shaft |
If the rotor turns, you should have spark. It might not be at the right time, but it will spark, regardless of that chip. Yes, that chip is bad and makes me wonder where the rest of it ended up.
You have some confusion statements: cranking and turning over are the same thing. If the engine spins when the starter engages, it is doing both. Is it doing that?
You check voltage & continuity where? To the coil? From the coil?
First, verify you have power to the coil.
Verify you have power from the coil.
Verify that module is installed right and the coil is proper for it.
Do you have points you can swap in to rule out the module? _________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
Original condition, which means something different on this forum than anywhere else! |
Posted: Mon Jun 21, 2021 8:13 pm Post subject: Re: No spark, chipped distributor shaft |
Sorry, mean turns over but will not start.
I did mean to mention that I tried timing it with the static method but cannot seem to get a light, no matter how much I tried. but the timing light works.
Figured the issues could also go together. _________________ '71 Westy, "Leo" |
Posted: Mon Jun 21, 2021 8:18 pm Post subject: Re: No spark, chipped distributor shaft |
Then you are not getting either power to the coil, power from the coil, or out of the module.
Start at the coil and move forward. Do you have voltage at the positive terminal at the coil? If no, the trace back. If yes, do you have power out of the coil when cranking? You said you tried multiple coils, right? So if you are not getting power out of the coil, then it’s not getting signal to collapse the field, that would - in my thoughts - point to the module or it’s installation. If there’s power out of the coil, then check cap and rotor. _________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
Posted: Mon Jun 21, 2021 11:35 pm Post subject: Re: No spark, chipped distributor shaft |
You should be able to swap the dog gear for one from another distributor. I would get a light and get a peak at the distributor drive and check that it too isn't badly worn. I am wondering if someone installed the distributor with the shaft turned 180° out and the shafts locked together well enough for the distributor to spin, but caused the wear seen.
If this is so and you have now installed the distributor correctly your timing would be 180° out on the cap, so maybe swap the wires 180° around the cap and see it the engine will start. You can always swap them back if it does not. |
