ZsZ Samba Member
Joined: December 11, 2010 Posts: 1642 Location: Budapest Hungary, Europe
Posted: Tue Jun 22, 2021 12:39 am Post subject: Vanagon Misfire and Stall fault finding |
This vid popped up on my YT start page, looks like it has good info on fault finding:
_________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32433 Location: Reading Pennsylvania
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1477 Location: Victoria,B.C.Canada
Posted: Tue Jun 22, 2021 5:28 pm Post subject: Re: Vanagon Misfire and Stall fault finding |
Ha,ha,ha,.ha. Just watched it in my feed. No longer my engine but interesting. |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4715 Location: Bemidji, MN
Posted: Tue Jun 22, 2021 5:58 pm Post subject: Re: Vanagon Misfire and Stall fault finding |
great skills and use of the scope and gas meter... but i wonder if instead of adding a ballast resistor to a "new" coil he should have checked the spec of the coil installed. there's so many different specs on these Bosch coils with the identical form factor, so maybe one with a high primary current got installed and was causing the ECU to fault.
it was great to find out that the ECU will 'multi-strike' with high coil amperage. it's another parameter i need to check out and find the baseline for. _________________ -dan
www.thefixitworkshop.com |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4020 Location: Redwood City, California
Posted: Tue Jun 22, 2021 11:55 pm Post subject: Re: Vanagon Misfire and Stall fault finding |
Great point. There are many different coils and they specifically list a separate coil for a Digifant or newer van. Makes you wonder if the van just has the wrong coil on it? _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
ZsZ Samba Member
Posted: Wed Jun 23, 2021 1:41 am Post subject: Re: Vanagon Misfire and Stall fault finding |
I think the owner threw on a significant amount of money and preferred "no parts required" repair rather than start buying "maybe this will be good now" parts.
Maybe a VW/Vanagon spacialized shop (or an advanced home mechanic ) would investigate which vendor/brand/partnr coils are good to use. _________________ Zoltan
Robw_z Samba Member
Posted: Thu Jul 01, 2021 6:43 pm Post subject: Re: Vanagon Misfire and Stall fault finding |
Whatever the speculation, this guy seems a lot smarter than me and like he knows what he's doing. I'm now curious if my engine is "missing out" on running better due to an issue like this, I can't pass emissions in spite of many new sensors and a good motor.
I wonder if this thread title is not doing the video contained therein justice, I almost didn't click.
-Rob |
