jbhurley92 Samba Member
Posted: Tue Jun 22, 2021 10:59 am Post subject: On startup, bad idle; nothing changes until warmed up |
So if you go back through my posts you'll see lots of issues but slowly working through them I guess. Figured out my bad idle was a throttle body which I pulled off my parts van. Van ran great then broke down again think it was a vacuum leak?
But new problems.
On start up it idles at around 700-850 poorly. I can turn the idle screw do whatever to it and nothing will change the idle when it warms up it will finally start moving the idle. Thoughts? |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10347 Location: Sunshine Coast B.C.
Posted: Tue Jun 22, 2021 11:33 am Post subject: Re: On crank up bad idle and nothing done to it changes idle |
What year Vanagon? _________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
Posted: Tue Jun 22, 2021 11:36 am Post subject: Re: On crank up bad idle and nothing done to it changes idle |
Vanagon Nut wrote: |
What year Vanagon? |
85 |
Posted: Tue Jun 22, 2021 11:45 am Post subject: Re: On crank up bad idle and nothing done to it changes idle |
ok. I'm only sightly familiar with Digijet but it may be that before the engine is warmed up, the aux. air regulator is allowing enough air in that turning idle screw makes no change?
The Digijet Pro manual gives nice succinct descriptions, relationships, of parts concerned.
Digijet does have idle control devices to compensate for a load like power steering.
VE7TBN |
Posted: Tue Jun 22, 2021 12:49 pm Post subject: Re: On crank up bad idle and nothing done to it changes idle |
Interesting I have never thought of that. I am thinking of replacing all sensors/ vacuum lines as I am hoping to take a trip for the 4th and then I have 3 music festivals in September I need this lil son of a bitch to run and not break down.
Neil. |
Silverghost500 Samba Member
Joined: August 01, 2018 Posts: 1069 Location: Atlanta, GA
Posted: Tue Jun 22, 2021 12:49 pm Post subject: Re: On startup, bad idle; nothing changes until warmed up |
If it has a Temp II sensor like the Digifant system see if unplugging the sensor before starting on a cold engine makes a difference. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
Honda K24A converversion in-progress
3-Speed Automatic
Von Westy YouTube Channel
https://www.youtube.com/channel/UCbhyZYxJEQrUuLnMbLleeIA |
Posted: Tue Jun 22, 2021 12:51 pm Post subject: Re: On startup, bad idle; nothing changes until warmed up |
Silverghost500 wrote: |
If it has a Temp II sensor like the Digifant system see if unplugging the sensor before starting on a cold engine makes a difference. |
I did that made it hard to start without holding the gas down. |
