H6 exhaust Configurations/PIX?
Captain Pike
Captain Pike is offline
PostPosted: Tue Jun 22, 2021 5:26 pm    Post subject: H6 exhaust Configurations/PIX? Reply with quote
On the tail end of this project. I have ideas of what to build but would rather plagiarize something proven.
Smallcar manifold installed. I need the CAT/ muffler pipes.
PIX plz
Coolant system is go(passed 15psi, 24 hours).
Electrical system is go.
Ignition system is go(short a blue IG coil, on the way).
Fuel system is go(good pressure test).
Clutch hydraulics feel spongy.
Replaced: Radiator, Fuel pump, SS coolant pipes. Trans fun done.
If You Build It______It Will Run
1959 Panel bus, 1966 Single cab. 73' 181. 73 Westy. 91' H6 Vanagon 3.3L.
.....................All Current.......................
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Tue Jun 22, 2021 6:32 pm    Post subject: Re: H6 exhaust Configurations/PIX? Reply with quote
H6 is a miss.
Casey--
'01 Weekender --> full camper
y u rune klassik?
wesitarz
wesitarz is offline
PostPosted: Wed Jun 23, 2021 8:14 am    Post subject: Re: H6 exhaust Configurations/PIX? Reply with quote
@Zeitgeyser Boo hoo!
BCgee
BCgee is offline
PostPosted: Wed Jun 23, 2021 10:55 am    Post subject: Re: H6 exhaust Configurations/PIX? Reply with quote
Here you go:
SC header + Magnaflow parts from Summit, welded + 02 bung.
1987 SVX Syncro Hightop
Captain Pike
PostPosted: Wed Jun 23, 2021 12:03 pm    Post subject: Re: H6 exhaust Configurations/PIX? Reply with quote
That an EGR bung?
Captain Pike
PostPosted: Tue Jun 29, 2021 2:38 pm    Post subject: Re: H6 exhaust Configurations/PIX? Reply with quote
It's reborn. Started 2nd attempt. Good rebirth. Small coolant leak up front somewhere.
SHAZAM!
Crankey
Crankey is offline
PostPosted: Tue Jun 29, 2021 7:02 pm    Post subject: Re: H6 exhaust Configurations/PIX? Reply with quote
I think stainless steel headers .com has headers to use as a start point.
After that I would try to mimic the concepts of a 911 header so I'd google image 911 exhaust.
I could show you mine but it's ugly. It does follow the typical route in a T3.
Captain Pike
PostPosted: Tue Jun 29, 2021 7:55 pm    Post subject: Re: H6 exhaust Configurations/PIX? Reply with quote
I got impatient and made my own.
Vanagon Nut
Vanagon Nut is offline
PostPosted: Wed Jun 30, 2021 11:51 am    Post subject: Re: H6 exhaust Configurations/PIX? Reply with quote
Captain Pike wrote:
...Started 2nd attempt. .....
Right on man!
Neil.
1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN
Captain Pike
PostPosted: Wed Jun 30, 2021 12:22 pm    Post subject: Re: H6 exhaust Configurations/PIX? Reply with quote
Vanagon Nut wrote:
Right on man!
Neil.
Thanks,
on to the throttle cable, PS pump goodies. Forgot to trade out the thermo dash sender. Fek. Prolly do the thermostat fer good measure.
Captain Pike
PostPosted: Sat Aug 07, 2021 12:53 pm    Post subject: Re: H6 exhaust Configurations/PIX? Reply with quote
Nice and quiet now
