Pekoe2053 Samba Member
Posted: Tue Jun 22, 2021 6:06 pm Post subject: How Do I Connect Stereo Power Wires to Fuses? |
I’m putting a stereo in a ‘77 Convertible and will connect red and yellow wires to fuses #11 and 8, respectively. Others have said these will work - correct?
Given the design of the fuse holders, how exactly should I connect these wires to the fuse holders?
Thanks! |
bomberbob Samba Member
Posted: Wed Jun 23, 2021 4:47 am Post subject: Re: How Do I Connect Stereo Power Wires to Fuses? |
Red is probably the main power, yellow is the wire that keeps your presets and stuff in memory. Crimp disconnect terminals on the ends of the wire, and plug them into the fuseholder. If you find that all the terminals on the fuseholder are taken, buy one or two of those spades with two males coming off a female, maybe called a piggyback. You will want to run the red to a switched terminal, so the constant draw doesn't kill your battery. Yellow needs to go to a terminal that stays powered all the time. _________________ 1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa |
Posted: Wed Jun 23, 2021 6:23 am Post subject: Re: How Do I Connect Stereo Power Wires to Fuses? |
bomberbob wrote: |
Red is probably the main power, yellow is the wire that keeps your presets and stuff in memory. Crimp disconnect terminals on the ends of the wire, and plug them into the fuseholder. If you find that all the terminals on the fuseholder are taken, buy one or two of those spades with two males coming off a female, maybe called a piggyback. You will want to run the red to a switched terminal, so the constant draw doesn't kill your battery. Yellow needs to go to a terminal that stays powered all the time. |
If I plug them onto the fuse holder, the fuse will not sit correctly in the hole, correct? |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Wed Jun 23, 2021 6:35 am Post subject: Re: How Do I Connect Stereo Power Wires to Fuses? |
Best picture I could find quickly. Also made in insulated crimp on style and as a simple double spade adaptor. Have a look at your FLAPS...
_________________ -Bruce
An ounce of prevention is worth a pound of cure. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Wed Jun 23, 2021 8:54 am Post subject: Re: How Do I Connect Stereo Power Wires to Fuses? |
Another option... check if your local Autozone has this type of piggyback terminal. No crimping needed.
https://www.autozone.com/miscellaneous-non-automot...?rrec=true
I always keep a few in my toolbox. They often come in handy. _________________ AshMan40
