Anybody know type 1 case sump flange thickness?? (For Helicoils)
RandyV
RandyV is offline
PostPosted: Thu Jun 24, 2021 9:50 am    Post subject: Anybody know type 1 case sump flange thickness?? (For Helicoils) Reply with quote
I need to helicoil a couple sump stud holes and want to know how long of helicoil inserts to get. (This is on a 1200 case of it makes a diff)
Thanks in advance.
bugguy1967
bugguy1967 is offline
PostPosted: Thu Jun 24, 2021 10:12 am    Post subject: Re: Anybody know type 1 case sump flange thickness?? (For Helicoils) Reply with quote
M6x1.5 length
"A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine"
RandyV
RandyV is offline
PostPosted: Thu Jun 24, 2021 10:23 am    Post subject: Re: Anybody know type 1 case sump flange thickness?? (For Helicoils) Reply with quote
Thank you! I’m not draining oil til this weekend and had an opportunity to get a kit that has 1x, 1.5x (common) and 2x diameter length helicoils in the kit thinking maybe the 1x was appropriate but that flange is probably thicker than I think it is.
Idea
Ohio Tom
Ohio Tom is offline
PostPosted: Thu Jun 24, 2021 12:48 pm    Post subject: Re: Anybody know type 1 case sump flange thickness?? (For Helicoils) Reply with quote
1/2" long.
3/8" will work as well.
BFB
BFB is offline
PostPosted: Thu Jun 24, 2021 6:36 pm    Post subject: Re: Anybody know type 1 case sump flange thickness?? (For Helicoils) Reply with quote
OP, they make stepped studs so that you dont have to heli coil. studs probably seal better than a heli coil too?
Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1
evanfrucht
evanfrucht is offline
PostPosted: Thu Jun 24, 2021 6:44 pm    Post subject: Re: Anybody know type 1 case sump flange thickness?? (For Helicoils) Reply with quote
Also when/if you use inserts you might also consider using bolts instead if studs as they physically cannot pull out or unthread. They still can strip if you torque the plate nuts too much.
1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder )
RandyV
RandyV is offline
PostPosted: Thu Jun 24, 2021 9:55 pm    Post subject: Re: Anybody know type 1 case sump flange thickness?? (For Helicoils) Reply with quote
Very good point actually! Because once helicoiled the threads are now no longer soft but hardened! No more concern for wearing/weakening case material so bolts would definitely be a good option.
Richard -- I first thought stepped studs too but actually, that can be used as a 3rd option if helicoils ever fail (which shouldn't, at least not anytime soon) but the stepped studs go significantly larger than what Helicoils will so you allow that 3rd option further down the road.
Tom ---- Helicoils work on multiples of the sized diameter. Thus at M6 (approx .240") a true 1.5x (common length for HeliCoils) would be approx .360" which should be good for this repair.
Now I just gotta burn thru this last oil change so I can get to fixin'. Wink
FreeBug
FreeBug is offline
PostPosted: Fri Jun 25, 2021 4:20 am    Post subject: Re: Anybody know type 1 case sump flange thickness?? (For Helicoils) Reply with quote
I think I used M6 x 12 . There is also an M6 x 9.4mm Time-Sert. I don't remember exactly, but if you measure the flange, you'll soon see which length is appropriate.
I would recommend Time-Sert, if you can afford them. Better than a helicoil, it can be well loktited into place, becoming a permanent steel thread.
I did all 6 of the sump threads, for exactly that: bolt things down steel-to-steel, especially a place like sump threads, which will be solicited frequently and regularly throughout the engine's life. It felt safer for bolting on a sump, too.
I wish Time-Sert were more affordable, but you get what you pay for, right?
(I also did the 4 generator stand threads, removed the studs, and use bolts instead. so I could easily remove the alternator/fan. There's little consensus on the value of that, though)
Insert joke here.
FreeBug
FreeBug is offline
PostPosted: Fri Jun 25, 2021 4:25 am    Post subject: Re: Anybody know type 1 case sump flange thickness?? (For Helicoils) Reply with quote
That endorsement must be worth a metric master kit, surely...Hey, Time-Sert! Are you seeing this? Write me a PM, and I'll give you the delivery address... Very Happy
Cusser
Cusser is offline
PostPosted: Fri Jun 25, 2021 6:18 am    Post subject: Re: Anybody know type 1 case sump flange thickness?? (For Helicoils) Reply with quote
I'd do step studs or Time Serts over helicoils myself.
RandyV
RandyV is offline
PostPosted: Fri Jun 25, 2021 6:47 am    Post subject: Re: Anybody know type 1 case sump flange thickness?? (For Helicoils) Reply with quote
Problem as I mentioned before is two-fold for step studs...
#1.) You're still set in soft material
#2.) You're running out of options as your hole is no about as large as you can go
As for Helicoil vs Timesert....(and I do like both, but there's a reason aerospace relies heavily on Helicoil)........
https://www.youtube.com/watch?v=agnim31D5hY
https://www.youtube.com/watch?v=4xgBTunyOq4
Not that VW sump will ever endure these kinds of loads but HeliCoil's design has always had a more consisten load distribution.
Cusser
Cusser is offline
PostPosted: Fri Jun 25, 2021 11:22 am    Post subject: Re: Anybody know type 1 case sump flange thickness?? (For Helicoils) Reply with quote
Hey - I'm afraid to fly ALREADY !!!
RandyV
RandyV is offline
PostPosted: Fri Jun 25, 2021 1:41 pm    Post subject: Re: Anybody know type 1 case sump flange thickness?? (For Helicoils) Reply with quote
Hey, I work with people who making nothing BUT airplane parts and I sometimes wonder to myself how they ever get off the ground with the caliber of work I see. Laughing Wink Shocked
FreeBug
FreeBug is offline
PostPosted: Fri Jun 25, 2021 1:45 pm    Post subject: Re: Anybody know type 1 case sump flange thickness?? (For Helicoils) Reply with quote
1.) Yes, but... the load is now distributed on a larger, .and the idea is that the steel thread now becomes the "working" thread.
2.) I don't know which needs a bigger hole.. a helicoil or a time-sert?
Either way, you're making the hole bigger. Of you don't want to do that, you can use an M6 screw threaded from the inside-down. With good loktite, you should be good to have that act as a stud which can't be unscrewed.
RWK
RWK is offline
PostPosted: Sat Jun 26, 2021 7:43 am    Post subject: Re: Anybody know type 1 case sump flange thickness?? (For Helicoils) Reply with quote
One of the reasons helicoils or any inserts don;t work well is because the holes that are drilled most often in repair situ are hand drilled and typically are over sized and crooked if you want to do a better job try to find a reamer that is the size of the hole you need to put in, it will produce a better hole more to size then a drill especially when doing by hand. VW used helicoils in T4 drain plugs,(no sump plate) and they were used in rear engine mount bolt hole, (places VW knew were going to be used regularly)
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Sat Jun 26, 2021 7:54 am    Post subject: Re: Anybody know type 1 case sump flange thickness?? (For Helicoils) Reply with quote
While the thru bolt idea is a great suggestion. I did just that on the most recent build. Works as planned on a CB Mini sump.
It's damn near impossible to install the bolts on an assembled engine. The oil pickup tube "Bell" is in the way.
It sounds like the OP is wanting to repair the sump studs without disassembling the engine.
If this were my engine and I wanted to repair the sump studs in situ. I'd use timeserts.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
mark tucker
mark tucker is offline
PostPosted: Sat Jun 26, 2021 8:41 am    Post subject: Re: Anybody know type 1 case sump flange thickness?? (For Helicoils) Reply with quote
eye too wood doo the stepping studs. or add new threads and use bolts from the inside going down locktighted in.( I usualy use bolts there on my builds and lock tight them in.be sure the length is correct so the capnuts do not bottom and unscrew the bolts Shocked been there done that. pain in the ass.
