rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
Posted: Tue Jul 13, 2021 7:42 pm Post subject: Re: $99 NAPA Awning- Copy of ARB? |
revolution337 wrote: |
Received my NorthWesty awning brackets from UPS today. Got to work straight away on getting the awning installed. As I suspected, the bolt pattern/hole size that the brackets came pre drilled with was not a direct match up to the NAPA brand awning. Luckily, it was pretty simple to modify the brackets to make them work. All I had to do was enlarge the two top holes to 5/16". Then I also enlarged a spot of the lower long, slotted section to also accept a 5/16" bolt. A trip to my local hardware store, and I got 6, 5/16" bolts that are 5/16" long, as well as washers and locking nuts. Each bracket then got 3 of the nuts/bolt combo.
Once mounted, it is very sturdy. The only thing I noticed is that the single main gutter clamp mounting nut is not sitting flush across the whole face of the nut. The bolt/nut combo does not seem to mate perfectly at a 90* angle in order to do so. So only the lower "6 o clock" potion of the nut is in contact with the bracket surface. I tried loosening it and wiggling and repositioning the bracket to try and correct this, but to no avail. The clamps are still plenty snug, and with the use of the lock nut I don't fear them coming loose.
I have not yet reached out to NorthWesty about this, but I likely will next week. Curious to know if anyone else has had this issue with the NorthWesty brackets? Their website claims that these brackets should work on all styles of rain gutters.
Thanks for posting. Does your slider rub? _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
rmcd Samba Member
Posted: Tue Jul 13, 2021 7:51 pm Post subject: Re: $99 NAPA Awning- Copy of ARB? |
VanAllen_84 wrote: |
I currently have a TRANS-2000 awning. Anyone know if I could get away with using the current gutter mounts for this awning?
And how easy is it to setup? |
Kind of? I used my modified transawn brackets. I didn’t install the new awning high enough on the transawn brackets so the new awning bag drags a little on the sliding door.
Either way You will need to drill holes in both parts.
Use three brackets if you have them. _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
VanAllen_84 Samba Member
Joined: October 17, 2016 Posts: 55 Location: Ventura County
Posted: Tue Jul 13, 2021 8:01 pm Post subject: Re: $99 NAPA Awning- Copy of ARB? |
Use three brackets if you have them. |
Unfortunately, I only have two brackets with my current setup. Can you post some pics of your setup and measurements of the holes you drilled?
Thanks! _________________ 1984 VW Vanagon Westfalia 1.9L Water-cooled (aka "Osmo") |
Timwhy Samba Member
revolution337 Samba Member
Joined: May 23, 2009 Posts: 372 Location: Pennsylvania
Posted: Wed Jul 14, 2021 4:51 am Post subject: Re: $99 NAPA Awning- Copy of ARB? |
rmcd wrote: |
Thanks for posting. Does your slider rub? |
My slider does not rub, although the clearance is quite small.
Also, the pop top is able to clear the mounting bolts as well. I think the key here is to use as short of a bolt/nut combo as possible when attaching the brackets to the awning. _________________ 1982 Westfalia AEB 1.8t
2017 VW Golf Sportwagen
2001 Audi A4 4.2 V8 swapped
2000 BMW Z3 roadster
-Mark |
rmcd Samba Member
Posted: Wed Jul 14, 2021 9:43 pm Post subject: Re: $99 NAPA Awning- Copy of ARB? |
Thanks! |
I will next week. My van is away at the spa spending my money like a drunk sailor. Maybe late next week? _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
gregaz Samba Member
Joined: May 22, 2012 Posts: 407 Location: Phoenix, AZ
Posted: Tue Jul 20, 2021 3:00 pm Post subject: Re: $99 NAPA Awning- Copy of ARB? |
rmcd wrote: |
Also, the pop top is able to clear the mounting bolts as well. I think the key here is to use as short of a bolt/nut combo as possible when attaching the brackets to the awning. |
He's likely asking because of that rub mark on the side of the van, where the slider opens. Check to see if your inside handle is installed properly - you can install them vertically (wrong way) or horizontally (right way). I have a matching stripe on mine, and found out the hard way, it's because I installed the handle vertically ... |
4Gears4Tires Samba Member
Posted: Wed Jul 21, 2021 7:53 am Post subject: Re: $99 NAPA Awning- Copy of ARB? |
It's a little bit of a pain to set up. I don't know how anyone does it as a 1 person job, but with 2 people it's doable. And for $90 with a AAA discount, it's really hard to beat. Seems fairly durable. So durable+cheap, you have to give up easy to use. Solid buy (without considering the effects of subsidizing our luxurious lifestyles on the backs of the 3rd world, lol) in my opinion.
_________________ '87 Syncro
space Samba Member
Posted: Wed Jul 21, 2021 8:22 am Post subject: Re: $99 NAPA Awning- Copy of ARB? |
4Gears4Tires wrote: |
4G tht vans looking great
I followed ur build thread and saw how it was
Mad Skills!
T _________________ 82 westy
w:
2.5 JDM Subie
Rear discs |
Posted: Wed Jul 21, 2021 9:14 am Post subject: Re: $99 NAPA Awning- Copy of ARB? |
Thanks man! _________________ '87 Syncro
Sodo Samba Member
Joined: July 06, 2007 Posts: 9609 Location: Western WA
Posted: Wed Jul 21, 2021 12:18 pm Post subject: Re: $99 NAPA Awning- Copy of ARB? |
You'll figure out how to do it solo if forced to do so a couple times.
It's not so bad if there's no wind. _________________
....KTMs, GasGas, SPOT mtb |
smeeegheeead Samba Member
Joined: February 19, 2021 Posts: 48 Location: Portland, OR
Posted: Wed Jul 21, 2021 9:02 pm Post subject: Re: $99 NAPA Awning- Copy of ARB? |
Yeeeeaaaaahhhhhhh.... they're really easy to bend too. Sooo take your time. Ask me how I know. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Thu Jul 22, 2021 1:29 pm Post subject: Re: $99 NAPA Awning- Copy of ARB? |
I've had the awning for weeks leaning against my fireplace.
It has just been too hot or too wet to mount it!
Today is a top 10 day so I've been doing yard work and decided to mount the awning.
I have the "Hauler Rack" and there were several mount options but I decided to mount the awning on the aluminum verticals from the rain gutters.
I used the supplied bracket as my hole template
To catch the drill shavings (I'm on the grass) I put cheap duct tape to good use as a chip collector!
Holes drilled
Mounted!
There is a balancing difficultly when working alone but I got it done!
Something I didn't notice is the grooves on the aluminum are NOT centered on the rack support.
The grooves are much closer to the top of the rack than to the bottom.
I only found this out when mounting it the bottom of the awning caught on the rack mount.
Oh well, I'll pick up some longer bolts and some spacers, it will work just fine.
Ghia
Vanagon
Beetle
Igeo Samba Member
Joined: September 25, 2018 Posts: 888 Location: Oakland, CA
Posted: Thu Jul 22, 2021 2:37 pm Post subject: Re: $99 NAPA Awning- Copy of ARB? |
Looks great. Like your cargo rack. Does it sing on the highway? _________________ 1987 Westfalia 2.1 WBX Manual |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4789 Location: Bemidji, MN
Posted: Thu Jul 22, 2021 3:28 pm Post subject: Re: $99 NAPA Awning- Copy of ARB? |
smeeegheeead wrote: |
You know, and I know, and Thee know....
-- Charles Bukowski |
Timwhy Samba Member
jimf909 Samba Member
Posted: Wed Jul 28, 2021 7:48 am Post subject: Re: $99 NAPA Awning- Copy of ARB? |
DanHoug wrote: |
It has not occurred to me to bring Bukowski into this forum. Impressive. _________________ - Jim
Abscate wrote: |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Wed Jul 28, 2021 7:54 am Post subject: Re: $99 NAPA Awning- Copy of ARB? |
Yeah there is a sag in the roof. I have some fiberglass tent poles I've kept from old tents. May sew in some velcro straps to hold a center bow arched across the middle. Right now I wouldn't leave it unattended in the rain. I also considered a brass grommet in the center that could serve two purposes. A drain into a rain catchment jug, or a reinforced hole for a pin on the end of a telescopic pole to create a peak so it sheds water. Used it this weekend for shade while camping on the kenai to floss for red salmon. |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2796 Location: North Carolina
Posted: Wed Jul 28, 2021 8:32 am Post subject: Re: $99 NAPA Awning- Copy of ARB? |
alaskadan wrote: |
If rain is in the forecast, lower one pole and raise the other so one corner is a foot or more lower than the other. Think about where the runoff is going to go when you do this. EDIT: This is what I do on my ARB, I'm just assuming it works on these NAPA offerings. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
