djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32634 Location: Reading Pennsylvania
Vana Guy Samba Member
Posted: Sun Oct 03, 2021 5:44 pm Post subject: Re: $99 NAPA Awning- Copy of ARB? Note: 10/21 out of stock |
Got a chance to try my Rube Goldberg awning today.
Expandable painters poles and a COSTCO window shade.
It performed well in a mild breeze. Not for hurricanes, or typhoons. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Oct 03, 2021 6:34 pm Post subject: Re: $99 NAPA Awning- Copy of ARB? Note: 10/21 out of stock |
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2672 Location: East Nassau, NY
Posted: Mon Oct 04, 2021 6:06 am Post subject: Re: $99 NAPA Awning- Copy of ARB? Note: 10/21 out of stock |
My local NAPA still has them and is showing 5 available. |
danfromsyr Samba Member
Posted: Mon Oct 04, 2021 7:21 am Post subject: Re: $99 NAPA Awning- Copy of ARB? Note: 10/21 out of stock?? |
I still see several stores in my area list these as order now pick up in 30minutes.. so some still in stock.
I may pick up another. _________________
Abscate wrote: |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Mon Oct 04, 2021 9:00 am Post subject: Re: $99 NAPA Awning- Copy of ARB? Note: 10/21 out of stock?? |
Here's my Napa awning heim joint mod.
The heim joints or rod ends are from tacoma screw. The threaded inserts were custom made at a local machine shop and cost more than the awning . An hour at the machine shop, I thought they would've whipped em out in half an hour. Oh well support your local businesses I say, and they have done me a couple favors for cheap. The bolts are old cv joint bolts. The small spacers are pieces of 3/8" copper line painted silver. I did have to elongate the holes in the tracks for bolt head clearance. It could actually go lower if the legs collapsed any further, but won't make it all the way to the ground. Its easier to set up by myself now and will shed water as I intended. |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Mon Oct 04, 2021 9:23 am Post subject: Re: $99 NAPA Awning- Copy of ARB? Note: 10/21 out of stock?? |
alaskadan wrote: |
I'm not sure I understand what the reason or purpose was for this? _________________ 89 Westy 2.1 Auto |
Posted: Mon Oct 04, 2021 9:50 am Post subject: Re: $99 NAPA Awning- Copy of ARB? Note: 10/21 out of stock?? |
The main reason is to be able to lower it to shed water when raining. I noticed this when I used it for the first time and couldn't leave it unattended when it was raining. To lower it enough to shed without puddling it was torquing down on the connection with the channel too much. I suppose giving shade from the sun when its lower on the horizon too. One leg can be raised to create a trough to gather rain water too. |
Posted: Mon Oct 04, 2021 3:53 pm Post subject: Re: $99 NAPA Awning- Copy of ARB? Note: 10/21 out of stock?? |
Yes its 7/8" ID. I were to do it again which I would, I'D buy 2 star threaded inserts for 7/8" tube first. 2 star meaning two metal stars that compress upon instal into the tube. Then reverse engineer from there. I found there were only so many sizes as far as the female thread size in them. I did the joints on the legs too. You can see where they would be if they came off of the outer rail at a square angle. |
Corwyn Samba Member
Joined: December 29, 2009 Posts: 2239 Location: Olympia, Washington
Posted: Thu Oct 07, 2021 2:32 pm Post subject: Re: $99 NAPA Awning- Copy of ARB? Note: 10/21 out of stock?? |
FYI - I have one I bought for comparison, but not using, if anyone wants to buy it. _________________ '90 White Westy ("The Longship")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~ |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Thu Oct 07, 2021 9:51 pm Post subject: Re: $99 NAPA Awning- Copy of ARB? Note: 10/21 out of stock?? |
word on the streets is that they'll be back in spring 2022 _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4800 Location: Bemidji, MN
Posted: Fri Oct 08, 2021 6:28 am Post subject: Re: $99 NAPA Awning- Copy of ARB? Note: 10/21 out of stock?? |
here's another possibility after careful measuring of the tube ID... keep the OEM hinge and add an articulated hinge. just install with a tubing cutter and some JB Weld.
https://gemini-products.myshopify.com/products/art...3597082733 _________________ -dan
www.thefixitworkshop.com |
Posted: Fri Oct 08, 2021 7:39 am Post subject: Re: $99 NAPA Awning- Copy of ARB? Note: 10/21 out of stock?? |
Yep that will do it. I considered Teflon rod, but was too impatient to order it. What are you going to use for the spacers to center the rod end? |
Posted: Fri Oct 08, 2021 10:29 am Post subject: Re: $99 NAPA Awning- Copy of ARB? Note: 10/21 out of stock?? |
alaskadan wrote: |
I guess I'm still not sure why this is needed. My awning sets up with the legs at minimum length. The legs just are at a slight angle inward at the same tilt as the awning. They can still be guyed down and function perfectly. Seems like a lot of work for minimal gain to have vertical legs. _________________ 89 Westy 2.1 Auto |
Posted: Fri Oct 08, 2021 11:59 am Post subject: Re: $99 NAPA Awning- Copy of ARB? Note: 10/21 out of stock?? |
PDXWesty wrote: |
alaskadan wrote: |
I guess I'm still not sure why this is needed. My awning sets up with the legs at minimum length. The legs just are at a slight angle inward at the same tilt as the awning. They can still be guyed down and function perfectly. Seems like a lot of work for minimal gain to have vertical legs. |
There is a lot of stress on those tubes, joints and mounting points if you are set up with anything less than or greater than 90°.
Different comfort levels of damage potential.
Ghia
Vanagon
Beetle
Kdj Samba Member
Joined: January 28, 2017 Posts: 142 Location: Naptown
Posted: Fri Oct 08, 2021 6:22 pm Post subject: Re: $99 NAPA Awning- Copy of ARB? Note: 10/21 out of stock?? |
Not sure of everyone's location, but i read headline they where out of stock on monday. Thought to myself what the heck! Jumped on Napa.com and ordered for next day in store pick-up. Order went through monday evening. No e-mail saying come get it tuesday. Thought oh well interweb must be right! Thursday AM inbox said come get it, sorry about the delay. Just food for thought $106.68 out the door. Pretty happy! |
VanAllen_84 Samba Member
Joined: October 17, 2016 Posts: 55 Location: Ventura County
Posted: Sun Oct 10, 2021 12:09 pm Post subject: Re: $99 NAPA Awning- Copy of ARB? Note: 10/21 out of stock?? |
I just checked one of my local NAPA stores and found it available at one that is close by. Still on sale for $99, but with AAA discount, it came out to $85!
Should be able to pick it up tomorrow.
Now I just need to figure out how to mount it using my existing brackets. _________________ 1984 VW Vanagon Westfalia 1.9L Water-cooled (aka "Osmo") |
