Technut27 Samba Member
Posted: Fri Jun 25, 2021 9:38 pm Post subject: Safe flat tow speed? |
What is a safe maximum speed when flat towing?
I have a trip coming up and am thinking about my route. Posted highway speeds here are 60-70 mph so of course that means 75+ for a lot of cars on the road. I have lights and big "in tow" magnet for it but I don't want to be so slow that it feels dangerous. |
Semper_Dad Samba Member
Posted: Fri Jun 25, 2021 11:10 pm Post subject: Re: Safe flat tow speed? |
I think it will depend greatly on the tow vehicle and its braking ability. I've towed mine behind several different RVs. I felt pretty good at 65, OK at 70, 75 for short periods. Probably could have pushed it more.
Always did a safety check at all stops. Checked drum temps with an IR thermometer.
Battery disconnected. Key in, Ignition on. Never needed to bungy cord steering wheel. Ideally use a brake buddy (but I never did ) Oh,...and never attempt reverse on a flat tow _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
Posted: Sat Jun 26, 2021 2:40 pm Post subject: Re: Safe flat tow speed? |
That all makes sense thanks for the tips, I never considered checking the drums, is that incase the pads drag a little or the bearings heat up? It will be behind an F150 so braking power won't be an issue.
There is a ton of good info out there. I wasn't sure if the low top speed driving the stock engine was all due to risk with that component or if there were others that shouldn't hit 75 mph Overall the car is in good shape mechanically and it's only about an hour each way. |
germanbilly Samba Member
Joined: October 18, 2013 Posts: 378 Location: Victorville
Posted: Sat Jun 26, 2021 9:07 pm Post subject: Re: Safe flat tow speed? |
I have flat towed our 73 for over 8,000 miles with no issues. Have had it up to 80 for short time. We tow with a Class C. I bought the front skid pan from the Thing Shop https://www.thethingshop.com/DEFLECTOR-PLATE-NEW-AM/productinfo/181707006/ and it sure works great. The front bumper is bolted to the front axle with this so it is super strong. Don't even know it is back there. If you do need to back up a little ways just lock the front wheels straight. buy pulling the key out. have someone watch. Have backed up over 20 feet with no problem. Have fun. Here is the post of the skid plate installed.
https://www.thesamba.com/vw/forum/viewtopic.php?t=627050&highlight=skid+plate
GB |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17285 Location: Left coast, Canada
Posted: Sun Jun 27, 2021 1:13 pm Post subject: Re: Safe flat tow speed? |
Semper_Dad wrote: |
Battery disconnected. Key in, Ignition on. |
Not necessary.
Just plug in the key, turn it on, then off. Leave the key in the ignition to prevent the steering lock from engaging. _________________
Posted: Sun Jun 27, 2021 2:04 pm Post subject: Re: Safe flat tow speed? |
Works perfect. Do it all the time.
GB |
FJBLF Samba Member
Posted: Mon Jun 28, 2021 5:11 pm Post subject: Re: Safe flat tow speed? |
Technut27 wrote: |
I towed mine all the way from Tucson to Chicago. 60 mph was the max speed I chose and had no problems. Like they said, unhook the battery, open the switch and let the steering roam free. Do not forget to have some towing lights, I had a set of magnetics from harbor freigth hooked into my Dodge Grand Caravan, they worked fine.
The max speed on my '72 manual is published at 110 k/hr which is about 68 mph. So, at least on paper, one should not exceed the max speed the vehicle is designed for.
Be safe. _________________ 1972 VW 181 SAFARI 1500 cc GRB Trans-axle |
Posted: Wed Jul 14, 2021 9:22 pm Post subject: Re: Safe flat tow speed? |
I took it easy and kept it about 60-65. One drum felt hot but I've also never checked them before, or driven it at that speed for any amount of time. I popped the hubcap off and that seemed to be all it needed. The next stop it was just barely warm.
It got lots of attention on the ferry leg of the trip.
kenj06 Samba Member
Posted: Thu Jul 15, 2021 4:33 pm Post subject: Re: Safe flat tow speed? |
Glad to see it went well. Enjoy the trip and safe travels home! |
