bus bruce Samba Member
Posted: Tue Jun 29, 2021 1:01 pm Post subject: hot start issues |
I have a 1982 Westy 2.0. I have replaced the starter and the ignition coil but the van will not start when hot. It makes a slow crank over noise. Do I need to replace anything else like the plugs, distributor cap and spark plug wires? Has anyone else had this problem before? Any help works for me. |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Tue Jun 29, 2021 1:08 pm Post subject: Re: hot start issues |
slow crank : how is the battery? (Voltage at rest, voltage while cranking, voltage after cranking, clean grounds...) _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Wed Jun 30, 2021 6:27 am Post subject: Re: hot start issues |
the battery is about five years old . But i do take care of it in the winter when in storage. I will check though thanks |
4Gears4Tires Samba Member
Posted: Wed Jun 30, 2021 6:52 am Post subject: Re: hot start issues |
I had this issue on my 87. Putting a jump pack (small 12v golf cart battery) on it would get it to crank over normally. I bought the hot start relay and a new starter. The new starter fixed it for me so I didn't add the relay. Since you've already replaced the starter, I would add the hot start relay. _________________ '87 Syncro
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3099 Location: ABQ NM USA.... Except when not
Posted: Wed Jun 30, 2021 7:24 am Post subject: Re: hot start issues |
bus bruce wrote: |
1) did you have this issue before replacing the starter?
2) What is the current starter you put in there?
Btw, having similar problem with 2.5 subi. Had issue before starter replacement. Still working on it. Ambient cold starts better than ambient hot.
https://www.thesamba.com/vw/forum/viewtopic.php?t=750796&highlight=starter _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Wed Jun 30, 2021 9:15 am Post subject: Re: hot start issues |
I did have this issue on my last starter also. My local mechanic told me to get it hot then take the middle wire off of my distributor cap and see if it rolls fast to start. If thats the case then my TDC timing could be off. Any insite on that theory? |
Igeo Samba Member
Joined: September 25, 2018 Posts: 888 Location: Oakland, CA
Posted: Wed Jun 30, 2021 9:29 am Post subject: Re: hot start issues |
Disabling the ignition is a valid diagnostic test for slow cranking. If the ignition timing is too early (advanced) then the igniting fuel mixture can fight the rising piston. Usually if this is the case, the slow cranking is uneven. _________________ 1987 Westfalia 2.1 WBX Manual |
Posted: Wed Jun 30, 2021 10:01 am Post subject: Re: hot start issues |
Igeo wrote: |
Disabling the ignition is a valid diagnostic test for slow cranking. If the ignition timing is too early (advanced) then the igniting fuel mixture can fight the rising piston. Usually if this is the case, the slow cranking is uneven. |
idea how to do this ignition disable on a subi? _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Posted: Thu Jul 29, 2021 4:29 pm Post subject: Re: hot start issues |
So I want to adjust my timing. I found the tension bolt for the distributor cap but the belts are covered. Can I adjust it without taking everything apart to seethe marks?? |
pathao Samba Member
Joined: November 01, 2012 Posts: 291 Location: Montreal, Canada
Posted: Fri Jul 30, 2021 4:38 am Post subject: Re: hot start issues |
bus bruce wrote: |
...Can I adjust it without taking everything apart to seethe marks?? |
Yes you can. Should not have to disassembled anything. You point your timing light thru the licence plate opening to see the mark on the timing pulley.
https://ratwell.com/technical/FindTimingMark.html _________________ 1982 AC P27 - 2.0 FI FED - 091 - BA6
English is a second language to me |
danfromsyr Samba Member
Posted: Fri Jul 30, 2021 5:01 am Post subject: Re: hot start issues |
you of course have cleaned the battery terminals
the ground strap to the battery box bolt
both ends of the ground strap between the transaxle & the chassis underneath
just because your 5yr old battery tests ok in voltage does not mean it is capable of still delivering the needed AMPS
5 year old battery is very near it's End of life. _________________
Abscate wrote: |
Posted: Fri Mar 18, 2022 12:32 pm Post subject: Re: hot start issues |
so I got a new battery a new starter new plugs new distributor cap and rotor and ignition coil. Thanks for the tip on the timing through the license. Bringing it to my guy to make it easy. |
