rks Samba Member
Joined: February 25, 2018 Posts: 29 Location: British Columbia
Posted: Thu Jul 01, 2021 8:27 am Post subject: 1966 single circuit MC to dual circuit MC will OG wiring work |
Apologies ahead of time, sure this topic has already been covered.
August 1965 panel, have converted to 12V everything works as it should. Beginning brake refurbish and switching single circuit MC to a dual MC.
Can the dual MC be wired in to the existing single MC wiring, does an additional wire need to be run for the second switch, perhaps a jumper from one to the other?
Any advice/wisdom will be greatly appreciated, Thanks. |
rking6 Samba Member
Joined: June 08, 2010 Posts: 140 Location: Long Beach Ca.
Posted: Thu Jul 01, 2021 8:34 am Post subject: Re: 1966 single circuit MC to dual circuit MC will OG wiring work |
A jumper from to another works perfectly with a dual MC.. Good Luck!! |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
Posted: Thu Jul 01, 2021 8:54 am Post subject: Re: 1966 single circuit MC to dual circuit MC will OG wiring work |
I would not use a jumper and I would only put one switch in. the one closest to the pushrod. it will activate the lights the fastest. the other port(s) can be blocked with brass plugs. I have done this on a type 3 |
rks Samba Member
Posted: Thu Jul 01, 2021 6:39 pm Post subject: Re: 1966 single circuit MC to dual circuit MC will OG wiring work |
Thanks for the feed back, always good to have some options.
Much appreciated! |
David Raistrick Samba Member
Joined: January 26, 2004 Posts: 539 Location: Geneva, Florida
Posted: Fri Jul 02, 2021 7:34 pm Post subject: Re: 1966 single circuit MC to dual circuit MC will OG wiring work |
I just put two switches in and only use one.
works fine. if a switch goes bad (..it has), I just flip the wiring around. _________________ ...david - '66 SO-44 #231 |
rks Samba Member
Posted: Fri Jul 02, 2021 10:42 pm Post subject: Re: 1966 single circuit MC to dual circuit MC will OG wiring work |
Gotcha, thanks David! |
