legotech7 Samba Member
Joined: May 09, 2009 Posts: 879 Location: North Carolina
Posted: Tue Jul 06, 2021 9:27 am Post subject: column bracket |
Question for the buggy guys. I'm putting in a new column in my buggy, and was wondering if any of you have ever used this bracket to anchor the lower portion of the column, and if so how did you do it. Could you use the back of the fire wall? seems to me the fire wall is pretty strong to hold this up... Any thoughts? And thanks for any feed back..
jbsx127 Samba Member
Joined: February 18, 2015 Posts: 83 Location: FWB, FL
Posted: Tue Jul 06, 2021 11:16 am Post subject: Re: column bracket |
jbsx127, what was the length of your column?. I had to shorten mine from 28'' to 25''. That was a considerable amount of work. But the 2'' tube from the column doesn't go through the fire wall completely. It more or less looks like the one in the picture. I have a ididit upper mount on the column, but I need to brace it better, some where on the lower side. When I turn the wheel from side to side, the column moves slightly as well. Doesn't feel safe , makes me a bit nervous to take it out like that.... The one in this pic, is braced twice, if you notice...
Posted: Tue Jul 06, 2021 11:35 am Post subject: Re: column bracket |
I used a 30" column on a manxter. It ran through the firewall for an inch or 2, and than I set up my u joints and D bar to the steering box. |
Posted: Tue Jul 06, 2021 11:38 am Post subject: Re: column bracket |
If your column comes close to the firewall, you might use a bracket like the link I posted and make spacers secured to the firewall and to the column bracket. It's really only to steady the column and to prevent the column from spinning. |
Posted: Tue Jul 06, 2021 11:44 am Post subject: Re: column bracket |
Thats a thought... I'll have to draw something up and see. Thanks... |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Jul 06, 2021 12:55 pm Post subject: Re: column bracket |
Think this DIY clamp was on my buggy when I first got it, may have been improved during buggy restoration ...
Anyway column appears to go through fire wall... Clamp just appears to be muffler clamp with a tab welded on... _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
y2kbaja Samba Member
Joined: March 07, 2016 Posts: 92 Location: Sacramento
Posted: Tue Jul 06, 2021 1:07 pm Post subject: Re: column bracket |
I love the imagineering of the original buggy builders to come up with something like that. |
Posted: Tue Jul 06, 2021 1:16 pm Post subject: Re: column bracket |
Always a thought to consider! |
EVfun Samba Member
Posted: Tue Jul 06, 2021 3:12 pm Post subject: Re: column bracket |
legotech7 wrote: |
Question for the buggy guys. I'm putting in a new column in my buggy, and was wondering if any of you have ever used this bracket to anchor the lower portion of the column, and if so how did you do it. Could you use the back of the fire wall? seems to me the fire wall is pretty strong to hold this up... Any thoughts? And thanks for any feed back.. |
What are you using for a steering column? Will you need to use 1 or more universal joints? That can have an impact on your choices. Using a stock '62-'67 Bug column and shaft all the way to the box is likely the easiest if possible.
My first buggy was a Manx clone with a stock steering setup. I passed the column through a hole in the dash and bent a strip of aluminum to support the bottom. It was held to the column with a hose clamp and to the firewall with single bolt. I did have to rotate the box a little on the beam to keep the steering box and column in a strait line.
With my Mini-T I needed a longer steering shaft and the stock column wouldn't reach the firewall. A more creative solution was required. It is also based on the common '62-'67 Bug column. I have a couple pictures in my album here on theSamba, but that extended setup doesn't apply to most Manx style buggies. There are no fasteners attaching the steering column to the body. _________________
Wildthings wrote: |
Posted: Wed Jul 07, 2021 9:23 am Post subject: Re: column bracket |
I have a after market column similar to the ididit column's. The buggy has a rack and pinion set up with splines just below the universal joint. Only one joint. The set up was there when I got the buggy, it worked well. The reason for the switch was that it had a tilt, and the tilt gear broke, It would just wiggle up and down. Didn't want to get into repairing it, it was cheaper to get the new column. It has tilt as well. But I had to modify the new column to get it to fit. I have a few options now with the help of everyone here. Still working on it. Will post as I go along. Thank again everyone. |
EVfun Samba Member
Posted: Wed Jul 07, 2021 6:12 pm Post subject: Re: column bracket |
I will be of little help as my buggies have been based on stock VW steering. However, every buggy is different and every buggy builder has unique experiences for it. Hopefully some members with experience using street rod style aftermarket steering columns will be around these parts to help out.
Any additional pictures you can post of the new column, the steering box, the U-joints you have, and anything else that helps others see what you have and how it lines up (or doesn't) should help improve your responses. _________________
Wildthings wrote: |
Posted: Thu Jul 08, 2021 1:22 pm Post subject: Re: column bracket |
With a center mount steering rack you should have 2 u joints to get the wheel to the drivers side. In order for the steering wheel to be secure and not move the shaft connected to the wheel will need 2 supports. I would not mess around and just replace the shaft with new u-joints and supports. Kartek sells all those goodies. |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4026 Location: NW Washington
Posted: Fri Jul 09, 2021 4:15 am Post subject: Re: column bracket |
My Buggy uses a piece of one inch wide 16 gauge steel bent to the angle of the firewall and steering column and dash and column. I bolted it to the firewall and hose clamped it to the steering tube at the dash and firewall.
It's been that way for 17 years and holds it tight. I never even bothered to paint it at the time since I planned to change it ....but never did.
It works great.
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
sailtexas186548 Samba Member
Joined: December 01, 2014 Posts: 423 Location: Kemah, Tx
